Pomoć za podešavanje svjetla na ekranu LAPTOPA
    • Pomoć za podešavanje svjetla na ekranu LAPTOPA
      Probao sam ovo . sve sam radio u terminalu. možda treba neki drugi program.
      Ili ako netko zna neki drugi način za podešavanje svjetline da ne bude full nakon rastarta .
      First install xdotool
      sudo apt-get install xdotool
      This will allow you to change the brightness easily from the command line with out admin privileges.
      Check whether the brightness is changing with the following command
      xdotool key XF86MonBrightnessDown
      Now we have to find the file where the brightness value is stored, try doing
      cat /sys/class/backlight/acpi_video0/brightness
      If
      you get an integer value then your good to proceed, else you have to
      find the appropriate file in your system. In that case check in
      /sys/class/
      Adjust the brightness and find your desired brightness level using the above command E.g. 9
      In this example I have used 9 as my brightness level change it according to you.
      #!/bin/bash
      myBrightness=9;
      currentBrightness=`cat /sys/class/backlight/acpi_video0/brightness`;
      count=$(( $currentBrightness - $myBrightness )) ;
      while [ $count -gt 0 ]
      do
      let count=$(($count-1));
      done
      Save this as brightness.sh
      Then make this file to be an executable, by running
      chmod +x brightness.sh
      Save this as brightness.sh OVO NE ZNAM KAKO SNIMITI.
      VU+Uno 4K SE
      HRT
