Selfsat oprema i 16.0 satelit los signal
    • Selfsat oprema i 16.0 satelit los signal
      Imam slijedecu opremu: SelfSat RotorHH90 i SelfSat H21D2
      Problem je kod pojedinih TP na 16.0 Satelitu. Npr Hayat, BN FaceTV, OBN nista od toga navedenog ne radi, dok npr HRT i SLO kanali rade. Isto tako sve sto gledam na 19.2 radi bez problema.
      Jel ima neko neki savjet kako ovu opremu dobro podesiti pa da radi i ovaj problematicni TP? Predlaganje neke druge opreme (osim ako nije u stilu Selfsat) nije opcija, ne smijem staviti nista drugo.
      Npr 5% kod Hayat HD:
      1. $ sudo svdrpsend PLUG femon INFO
      2. 220 vdrvdpau SVDRP VideoDiskRecorder 2.2.0; Wed May 27 20:49:19 2015; UTF-8
      3. 900-CARD:0
      4. 900-STRG:84
      5. 900-QUAL:5
      6. 900-TYPE:0
      7. 900-NAME:Conexant CX24116/CX24118
      8. 900-STAT:1F
      9. 900-SGNL:D9C0
      10. 900-SNRA:4999
      11. 900-BERA:000110C1
      12. 900-UNCB:00000000
      13. 900 CHAN:HAYAT PLUS;TEAM|SAT:11262:HC23M2S0:S16.0E:30000:61=2:63=@4:55:500:2:366:1:0
      14. 221 vdrvdpau closing connection
      15. $
      Display All
      A ovdje kod ostalih kanala
      1. 250 61 A1 HD TV - [713] frontend 0/0 timed out while tuning to channel 61 (A1 HD TV), tp 111304
      2. 250 62 BN SAT - [713] frontend 0/0 timed out while tuning to channel 62 (BN SAT), tp 111262
      3. 250 63 BN BIH - [713] frontend 0/0 timed out while tuning to channel 63 (BN BIH), tp 111262
      4. 250 64 HAYAT HD - [713] frontend 0/0 timed out while tuning to channel 64 (HAYAT HD), tp 111261
      5. 250 65 HAYAT PLUS - [713] frontend 0/0 timed out while tuning to channel 65 (HAYAT PLUS), tp 111262
      6. 250 66 Boka TV - [713] frontend 0/0 timed out while tuning to channel 66 (Boka TV), tp 111262
      7. 250 67 FACE TV - [713] frontend 0/0 timed out while tuning to channel 67 (FACE TV), tp 111262
      8. 250 68 Hayatovci - [713] frontend 0/0 timed out while tuning to channel 68 (Hayatovci), tp 111262
      9. 250 69 OBN - [713] frontend 0/0 timed out while tuning to channel 69 (OBN), tp 111304
      10. 250 70 OBN+ - [713] frontend 0/0 timed out while tuning to channel 70 (OBN+), tp 111304
      11. 250 71 Posavina TV - [713] frontend 0/0 timed out while tuning to channel 71 (Posavina TV), tp 111304
      12. 250 72 RTRS plus - [713] frontend 0/0 timed out while tuning to channel 72 (RTRS plus), tp 111262
      13. 250 73 Shutel TV - [713] frontend 0/0 timed out while tuning to channel 73 (Shutel TV), tp 111304
      14. 250 74 K3 - [713] frontend 0/0 timed out while tuning to channel 74 (K3), tp 111304
      15. 250 75 Atlas TV - [713] frontend 0/0 timed out while tuning to channel 75 (Atlas TV), tp 111304
      16. 250 76 Canal Motor/FilmNet+ OBSOLETE - [713] frontend 0/0 timed out while tuning to channel 76 (Canal Motor/FilmNet+ OBSOLETE), tp 111304
      17. 250 77 Fight Channel OBSOLETE - [713] frontend 0/0 timed out while tuning to channel 77 (Fight Channel OBSOLETE), tp 111304
      18. 250 78 Hayat Folk TV - [713] frontend 0/0 timed out while tuning to channel 78 (Hayat Folk TV), tp 111262
      19. 250 79 BN Music - [713] frontend 0/0 timed out while tuning to channel 79 (BN Music), tp 111262
      20. 250 80 Hayat HD TEST OBSOLETE - [713] frontend 0/0 timed out while tuning to channel 80 (Hayat HD TEST OBSOLETE), tp 111304
      21. 250 81 Hayat Music - [713] frontend 0/0 timed out while tuning to channel 81 (Hayat Music), tp 111262
      22. 250 82 Al Jazeera Balkans HD TEST - [713] frontend 0/0 timed out while tuning to channel 82 (Al Jazeera Balkans HD TEST), tp 111304
      Display All
      [ VDR: Morex Cubid 3688B | POV/ION330-1 | G.Skill DIMM Kit 4GB (4GBPQ) | TeVii S650 DVB-S2 USB | Selfsat Rotor HH90 + Selfsat H21D2 | Panasonic TX-L50ETW60 ]
      VDR: Raspberry Pi 2 Model B | Sundtek SkyTV Ultimate 5 2015 (DVB-S/S2) ]
      W≡T≡K . openelec DVB-S2 STB ]
      The post was edited 1 time, last by crov ().
