Black Hole duo2 2.1.7
    • Black Hole duo2 2.1.7
      Black Hole duo2 2.1.7 MultiBoot
      WHAT IS NEW
      New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
      New skin MX i6p By Matrix10
      Vu+ drivers 20150623
      - Fix tuning problem(AVL6211, duo2, solose)
      - Improve vtuner(satip support)
      - Fix scrambling bit in recording
      - Improve transcoding
      Xbmc Support 576/720/1080 resolution
      Updated Vuplus-Blindscan
      Updated HbbTv
      Updated WebManual
      Added Sat>Ip Client
      Included UiPositionSetup
      Removed MeoBoot
      Added OpenMultiBoot
      Updated Lcd4Linux
      Updated MediaTree (usb tuners drivers)
      Fixed random socket error
      [ScanSetup] fixed error on complete scan with T2 tuners
      [ScanSetup] fixed TT3L10 automatic scan problem
      [unicable] support JESS(EN50607) and update unicable.xml
      AnimationSetup: set default to animations disabled
      povzeto:
      vu+ community
      The post was edited 1 time, last by skala ().
