Oscam
    • @ dydy... probao sam kako si rekao.. ali i dalje prekida i zamrzava, mislim da je do oscam-a ovo ispisuje u log-u
      • 2018/11/07 20:10:37 04BF6227 c (ecm) user (1802@000000/0000/2B12/92:ACF4145CDC7D5AB66A17B02807AE4100): found (461 ms) by xxx (P/2/3/9) - RTS1
      • 2018/11/07 20:10:46 04BF6227 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
      • 2018/11/07 20:10:46 04BF6227 c (ecm) user (1802@000000/0000/2B12/92:F303D37A8F1D619ACBE3637EB7BBF6B0): found (444 ms) by xxx (P/2/3/9) - RTS1
      • 2018/11/07 20:10:57 04BF6227 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
      • 2018/11/07 20:10:57 04BF6227 c (ecm) user (1802@000000/0000/2B12/92:9076957AB7612393BA6688E555EB2383): found (503 ms) by xxx (P/1/2/9) - RTS1
      a ovo ispisuje na discovery kanalima na 1W
      • 2018/11/07 20:18:45 35447EDB c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:18:45 35447EDB c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:18:45 35447EDB c (ecm) user (0E00@000000/0000/0C80/40:23D932838629A0B1ABF11B4359A7BEA9): found (1 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:18:46 35447EDB c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:18:46 35447EDB c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:18:46 35447EDB c (ecm) user (0E00@000000/0000/0C80/40:7AD93638BDD055B248B2F60D48D59069): found (1 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:18:47 35447EDB c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:18:47 35447EDB c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:18:47 35447EDB c (ecm) user (0E00@000000/0000/0C80/40:2E96CC1075F7DFC9DDDD36E125AC494A): found (4 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:18:48 35447EDB c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:18:48 35447EDB c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:18:48 35447EDB c (ecm) user (0E00@000000/0000/0C80/40:9520F8CF31C222B629DC4A4C81D99D9D): found (2 ms) by emulator (L/1/2/2) - Science Europe HD
      sta bi moglo da bude problem ?(
      DreamBox920.. TBS5925
    • Guglao sam na internetu i stavio
      extended_cw_api = 0 (bilo je 1)
      sad u logu ispisuje
      • 2018/11/07 20:33:33 071AB942 c (ecm) user (4AEE@000000/0000/01CD/4F:68E4271E87EFA77FE1179AD75A602DE0): found (71 ms) by xxx (P/2/3/9) - RTS 1
      • 2018/11/07 20:33:40 071AB942 c (ecm) user (4AEE@000000/0000/01CD/4F:A071A8DA73CC082664997F7507AC109D): found (325 ms) by xxx (P/2/3/9) - RTS 1
      • 2018/11/07 20:33:50 071AB942 c (ecm) user (4AEE@000000/0000/01CD/4F:4347A135A9216AFD740FA289C0A6F3B6): found (326 ms) by xxx (P/2/3/9) - RTS 1
      i dalje zamrzava
      dok discovery ne radi uopste...
      i pise ovo:
      • 2018/11/07 20:36:00 2A4C47A3 c (ecm) user (0E00@000000/0000/0C80/40:552993F41FCA7E8EFC694CCEDEAC65E6): found (2 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:36:01 2A4C47A3 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:36:01 2A4C47A3 c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:36:01 2A4C47A3 c (ecm) user (0E00@000000/0000/0C80/40:22F93880B02DF01EEB38CEB8C5560BB2): found (2 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:36:02 2A4C47A3 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:36:02 2A4C47A3 c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:36:02 2A4C47A3 c (ecm) user (0E00@000000/0000/0C80/40:3FC98D2A20A331F8A6DBC64890EBCE03): found (1 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:36:03 2A4C47A3 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:36:03 2A4C47A3 c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:36:03 2A4C47A3 c (ecm) user (0E00@000000/0000/0C80/40:FA64A5B987498C9FD3379A35501E024A): found (2 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:36:04 2A4C47A3 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:36:04 2A4C47A3 c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:36:04 2A4C47A3 c (ecm) user (0E00@000000/0000/0C80/40:41F237B18D23D57AE771710D53A38938): found (1 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:36:05 2A4C47A3 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:36:05 2A4C47A3 c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:36:05 2A4C47A3 c (ecm) user (0E00@000000/0000/0C80/40:891201519E0187050743CECDE06F987C): found (2 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:36:06 2A4C47A3 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:36:06 2A4C47A3 c (-) -- Skipped 7 duplicated log lines --
      • 2018/11/07 20:36:06 2A4C47A3 c (ecm) user (0E00@000000/0000/0C80/40:B9E5018B16AB2C7A8D9ADB1DC7B33477): found (2 ms) by emulator (L/1/2/2) - Science Europe HD
      • 2018/11/07 20:36:07 2A4C47A3 c (dvbapi) ERROR: ioctl(CA_SET_DESCR): Invalid argument
      • 2018/11/07 20:36:07 2A4C47A3 c (-) -- Skipped 7 duplicated log lines --
    • ništa posebno, ne utječe na rad.. kod svakog je tako
      • 2018/11/07 21:22:39 0C27FF1F c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
    • o areni sam već govorio, samo su modovi premjestili postove pod oscam u VU+ temi, ako imaš liniju, makni caid 1010 iz emu readera da ti otvara preko linije... nešto zeza emu sa novijim oscamom
    • dxdy wrote:
      kod nekog biss kod nekog tandberg zeza...
      meni biss radi OK... ali ja biss otvaram preko constant.cw, ne softcam...
      Posto su kod mene tvoje postavke onda vjerovatno i kod mene trazi kljuc u constant.cw. A ja ga stavljam u softcam.
      Neznam ga u constant.cw staviti . neznam znacenja svih onih brojeva, dok kod softcam-a sam to savlladao :).
      Prebacim na ncam pa onda radi biss.
      Posto su kod mene tvoje postavke onda vjerovatno i kod mene trazi kljuc u constant.cw. A ja ga stavljam u softcam.Neznam ga u constant.cw staviti . neznam znacenja svih onih brojeva, dok kod softcam-a sam to savlladao :).
      pa ubaci caid 2600 u emu reader da ti otvara sa softcam....
      a u constant.cw upisuješ SID i PMT PID
      npr
      2600:000000:SID:PMT:1FFF::xxxxxxxxxxxxxxxxxxx
    • vulevule wrote:
      meni na arenama stalno vrti ključ zato i neradi kad nevaljaju ključevi vu zero je resiver
      ključevi su ok ali meni ne otvara...
      no linija otvara pa ne brinem oko toga
    • Meni su prordile Arene na zadnjem Oscamu. Najbolje je sve od pocetka raditi. Bekap celog oscam foldera , pa stop Oscama i nazad softcam sa AS kljucevima samo. I Bingo (meni je vec tu proradilo). Posle sve dodavati jedno po jedno (full sofcam.key, server, config...) i videti koji fajl je pravio smetnje. U mom slucaju server i config. I btw kod mene TREBA ostaviti proveru checksuma CW za 1010!! Sto je i logicno jer je na OP keyu od TB zadnji bajt 00 ili 01 ne mora da znaci da je i na CW pogresan ceksum.
      The post was edited 1 time, last by dvbzavisnik ().
