Amiko A3 Combo SE HD PVR, Spark2, 4K/UHD output, DVB-S2 + T2/C, Android 4.4.4
    • Amiko A3 Combo SE HD PVR, Spark2, 4K/UHD output, DVB-S2 + T2/C, Android 4.4.4
      Full HD Digital Smart Set-Top Box - Satellite & T2 Terrestrial / Cable Receiver
      • Powered by Spark 2 / Android 4.4
      • High Performance Quad Core CPU
      • High Speed USB3.0 connection
      • MicroSD expansion
      • Google Play! Store
      • Miracast, Airplay & DLNA support
      MAIN FEATURES
      • Full HD Digital Satellite Receiver & Media Player
      • Powered by Spark 2 / Android 4.4 Kit Kat
      • Conax Embedded Card Reader
      • Fast & Easy Installation
      • Multimedia Playback from External HDD, USB, Network or via DLNA
      • Channel Recording to External HDD, USB, or via Network
      • Miracast & Airplay support
      • Remote management and channel streaming through local network/internet via Web Interface
      • Remote management and channel streaming to Android and iOS devices with the Spark Player App
      • Ethernet Connection
      • Web Browsing with Adobe Flash Player support
      • Built-in Wireless-N WiFi connection
      • USB 3G modem support
      • VPN Support
      • Android Games Supported
      • Download Various Applications and Games for free from the Spark App Store!
      • Google Play! Store available
      • One High Speed USB 3.0 & two USB2.0 ports
      • MicroSD Expansion
      • KODI Support - Build your own Media Center
      • Full HD - 1080p Output via HDMI
      • CVBS Video & Audio output via RCA (Jack type)
      • DiSEqC 1.0, 1.1, 1.2 & USALS Support
      • Dolby Digital Bit-Stream out via HDMI & Optical S/PDIF
      • Easy software upgrades via Internet
      • Low Power Consumption in Stand-By Mode
      TECHNICAL SPECIFICATIONS
      System Resources
      Main Processor: ARM Cortex A9 1.5GHz Quad Core CPU
      Flash Memory: 2MB SPI NOR Flash + 8GB NAND Flash
      DDR SDRAM: 1GB DDR3
      Tuner & Demodulation
      Tuner Type: DVB-S / DVB-S2
      Input Connector: F-Type (Female)
      Signal Level: -65 to -25 dBm
      LNB Power: Vertical: +13V/14V, Horizontal: +18V/19V
      LNB Current: 400mA max (overload protection)
      22kHz Tone: Frequency: 22 kHz ±4kHz
      DiSEqC Control: Version 1.0, 1.1, 1.2, USALS (Amplitude: 0.6 ±0.2V)
      Demodulation: QPSK, 8PSK, 16APSK
      Input Symbol Rate: 2-45Mbps, Convolution Code Rate
      FEC: 1/2, 2/3, 3/4, 5/6, 7/8, 1/4, 1/3, 2/5, 3/5, 4/5, 8/9, 9/10, auto
      Tuner Type: DVB-T2 / DVB-C
      Frequency Range: 48~862MHz
      RF Input Level: -80dBm to -20dBm
      Antenna power output: DC 5V at max 75mA, Overload protection
      Demodulation: COFDM 1K, 2K, 4K, 8K normal and extended, 16K normal and extended, 32K normal and extended
      Input Symbol Rate: 1.0 ~ 7.0Ms/s
      Constellations: QPSK, 16QAM, 64QAM, 256QAM / Both rotated and non-rotated
      Guard Intervals: 1/4, 19/256, 1/8, 19/128, 1/16, 1/32, 1/128
      Code Rate: 1/2, 3/5, 2/3, 3/4, 5/6
      Audio / Video Decoding
      Input Rate: Max. 120Mbit/s
      Aspect Ratio: 4:3, 16:9
      Video Decoding: MPEG-2, MP@ML, MPEG-4 Part 10 / H.264, H.265 (8 Bit only)
      Video Resolution: 720*480p/i, 720*576p/i, 1280*720p, 1920*1080i/p, 2160p
      Audio Decoding: MPEG-1 layer I/II, Mpeg2 layer II, Dolby Digital
      Audio Mode: Left / Right / Stereo / Mono
      Sampling Rate: 32, 44.1 & 48KHz
      Interfaces
      HDMI: Ver 1.4, Type A
      AV: Jack Type (CVBS Video & L/R Audio output)
      S/PDIF: Digital Audio / Dolby Digital Bit-Stream Output
      Ethernet: RJ45 (10/100M)
      WiFi: Embedded IEEE802.11 b/g/n (up to 150Mbps)
      USB: 1 Type A USB 3.0 port, 2 Type Micro A USB 2.0 ports
      SD Card: Micro SD Card reader
      CA: Conax Embedded Smart Card Reader
      Remote Control
      Type: Infrared
      Power Supply
      Type: External
      Input Voltage: 110-230V AC
      Output Voltage: 12V DC / 2A
      Physical Specifications
      Size (WxDxH): 160mm x 120mm x 30mm
      Operation Temperature: 0ºC - 45ºC
      Storage Temperature: -10ºC - 70ºC
      Storage Humidity: 5% - 95% RH (Non Condensing)
      Android version
      4.4.4
      Processor
      Memory (RAM)
      1GB - DDR3 SDRAM
      Storage
      No
      Receiver type
      Basic terrestrial (also free HD channels), Basic cable (also free HD channels), Basic satellite (also free HD channels)
      HD & pay-tv compatibility
      Terrestrial free & pay-TV SD,
      Cable free & pay-TV SD, Terrestrial free HD, Cable free HD,
      Satellite free SD & HD, Satellite Canal Digital (FI/SE/NO/DK) HD
      DVB-compatibility
      DVB-C (cable), DVB-S (satellite), DVB-S2 (satellite HD), DVB-T (terrestrial), DVB-T2 (terrestrial HD)
      DVB tuners
      1 x DVB-C (cable), 1 x DVB-S2 (satellite), 1 x DVB-T2 (terrestrial)
      DVB decoding
      MPEG2, MPEG4 AVC / H.264, HEVC / H.265
      Resolution
      480i, 480p, 576i, 576p, 720p, 1080i, 1080p, 2160p
      Aspect ratio
      16:9, 4:3
      Encryption
      Programmable smart card reader, Conax, Oscam
      Viewing card slots
      1
      CI slots
      0
      Timeshift
      Yes (add disk drive)
      Record
      Watch and record on same mux 2 channels
      No
      Record all channels in same mux with 1 tuner
      No
      Hard disk and slots
      MicroSD, USB
      Channels
      No
      Favorite channel list
      Yes
      Blindscan
      No
      Internet connection
      RJ-45 (+ WiFi option), WiFi
      Bluetooth
      No
      Video play
      AVI, DivX, H.261, H.263, H.264, mkv, MOV, MPEG2, MPEG4, Ogg-Theora, RM, RMVB, TS, VC-1, VOB, WMV, Xvid
      Music play
      3GP, AAC, AC-3, ACC, FLAC, MP3, OGG, WAV, WMA
      Picture view
      BMP, GIF, JPEG, PNG, RAW, TIFF
      Receiver manual languages
      English
      Menu languages
      English
      EPG
      Yes
      DVB subtitles
      Yes
      Teletext
      No
      DiSEqC compatibility
      1.0, 1.1, 1.2, 1.3 (USALS)
      Unicable compatibility
      n/a
      Games
      Yes
      Linux OS
      No
      Internet browser
      Yes
      Youtube
      Yes
      Web video player
      Yes
      Web radio
      Yes
      Front panel connectors
      USB 2.0
      Back panel connectors
      HDMI out, AV out (3.5mm), Digital Audio out (Toslink), F in, IEC in, MicroSD, USB 2.0, USB 3.0, Ethernet, DC 12V in
      Product height (mm)
      30
      Product width (mm)
      160
      Product depth (mm)
      120
      Product weight (g)
      No
      Included with receiver
      Manual, Remote control, External power supply
      Posti shipping in Finland
      Yes
      Posti shipping to abroad
      Yes
      Matkahuolto Near Parcel shipping
      Yes
      Matkahuolto Bus and Delivery Parcel shipping
      Yes
      Manufacturer product link
      http://amikostb.com/
      ZGEMA H7S(2 x DVBS2X,DVBT2(HEVC 265) multistream
      Xtrend - ET - 9500
