OpenPli 6.0
    • Radi se RC izdanju (release candidate) i to za određene resivere.Uvijek je bolje držati stabilnu verziju imidža ovo je još sve test tako da treba pričekati malo.Naravno ovo će biti za određene resivere,nažalost podrška za dreambox modele je stala.
      OpenPLi is proud to present the next release of our image, OpenPLi 6.0. A
      lot has changed since OpenPLi 4, so we made a releasenote with all the
      changes. OpenPLi 5 was not released to the public, because we used it
      for our development to make OpenPLi 6. The images can be downloaded at: openpli.org/download
      In the future we're continuing developing which results in new releases, but there will be a difference in releasing...
      We
      will only be releasing stable versions now. So changes that you'll
      notice is when there is an update from OpenPLi 6.0 to 6.1 and future
      versions. Developing will be done internally and home builders can also
      make an extraction of our develop version.
      Should you wait for a
      long period for a new release? Well, that depends.. If a new feature is
      ready, that feature will become public. It can sometimes take weeks, but
      also months before a feature becomes available.
      We also have
      rebuild our Wiki and made a lot of new articles to read. We will
      continue to expand our wiki to make it a handy knowledge base for our
      supported receivers. Have a look at: wiki.openpli.org
      To be clear, for the following brands/models there won't be an OpenPLi 6.0:
      DM800SE, DM500HD (insufficient flash space), DM7020HD (no member has the appropriate Hardware)
      Golden Interstar (all models, no BSP support from the manufacturer for the OE upgrade)
      Wetek Play (no BSP available with Gstreamer 1.x support)
      OpenPLi
      4 will remain available for these models, once OpenPLi 6.0 Release is
      available, we'll have a look to see if we can find a way to refresh
      things like satellites.xml, channel lists, picons, etc for OpenPLi 4
      without having to build new images.
      New features:
      - Changed menu structure and reintroduce user levels. Default is basic.
      - Remove any (default) cam from the setup wizard. Let the user decide if, and if yes which cam to use.
      - Upgrade Gstreamer version to 1.12.1
      - Center DVB subtitles per service (which also solve the 'destroyed' subtitles on some services e.g. ARD, ZDF)
      - New ECM info screen that includes provider IDs (at menu->about->serviceInfo->green) - See: Tips and Tweaks
      - Multistream support for DVB-S2X tuners
      Pluginbrowser - Allow two digit number selection in plugins. - When you
      are in the Plugin browser menu and want to use the 11th plugin, you can
      press 11 to open the 11th plugin directly.
      - Default the bouquet
      numbering is changed to Alternative numbering mode. - To alter this, go
      to user interface and set Alternative number mode to no.
      Notice to HDMI-CEC users:
      By default the HDMI-CEC option is turned off. If you want to use the HDMI-CEC function...
      Go to Menu->Setup->System->Customize
      Put the Setup mode to Advanced and press green (OK)
      Select Audio / Video->HDMI-CEC setup and Enable the function.
      Notice to Autobackup users:
      This tool can only be used when no major upgrade has been done in Enigma eg. OpenPLi 4 backup and restore with OpenPLi 6.0
      Vujo@1981
    • Evo nabacih ga i ja na svoju Japhar karticu i nisam nešto impresioniran.Po onome što sam vidio samo kozmetičke promjene,čak su malo i zakomplicirali menu za obične korisnike pa se ljudi namuče dok nađu recimo sučelje ili ti skin.
      Kad sam sve fino posložio i htjeo da istestiram wi fi pojavi mi se čudna stvar na listi kanala.Naime na njoj sam mogao da biram samo određene kanale dok su mi ostali bili zatamnjeni kao da ne postoji tuner.Pretežno se radilo o HD kanalima.Mislio sam da je nešto do liste pa sam sve ponovo brisao pa opet instalacija ali ništa.
      Morao sam vratit provjerenu stvar Open Pli 4.0 zasad.
      Sve u svemu nije loše za istestirat naravno ali ipak se ovdje radi tek o kandidatu za public.
      Vujo@1981
    • Ti skriveni menu nisu ništa novo tako radi i bh sa uključicanjem expert dodatnog otvaranja skrivenih menija.
      Uključiš expert snimiš i restart i to je to sve je vidljivo.
      U pravu si da je OpenPLi extra dobar image, medjutim u njemu je stari python i jednostavno vreme ga gazi. Sve je vise streamova koji traze novi python, tako da nema nazad, mora se ici napred, i hvala bogu da je neko odlucio da radi OpenPLi za 800se, box koji ja imam, a za koji je zvanican OpenPLi tim obustavio razvoj image-a.
      Problem sa listom kanala imaju svi, nije do tebe, a isti problem se desava i na drugim image-ima, a niko ne zna zbog cega je to, cak ni Ciepf.
      Problem ces resiti tako sto ces sa programom eSettings ubaciti neku drugu listu kanala, npr.Satvenus, uraditi restart, a potom sa tim istim programom ubaci Ciepf-ovu listu, uradi restart i sve ce raditi kako valja.
    • pa onda da bi radila moras ici u telnet
      init 4
      pa u userbouquet.esp10 koju je kreirao esettings po takvim imenima moras kopirati rucno iz userbouquet.buket_powervu.tv u nju jer esettings skrati te http i delove u listi.
      pa onda snimiti userbouquet.esp10
      i na kraju
      shutdown now -r
      da odraadi reboot
      e onda radi kompletna.
    • Open Pli 4.0 sa gstreamerom 1.12 radi kod mene odlično i nemam niakvih problema.IPTV lista od Japhara radi super kao i streamovi od IPTV player plugina.Ciefp listu koristim dugo na OP4 i sve pići power vu+iptv kanali.
      Ova verzija 6.0 je tek RC tako da me ne čudi što ima nedostataka tako da ću sačekati stabilno izdanje.
      Pitanje: Ako je u Open Pli 4.0 verzija python 2.7.3 zanima me koja je verzija u ovom 6.0 imidžu ?
      Vujo@1981
      The post was edited 1 time, last by camillo12345 ().
    • Ta verzija je realese candidate i pitanje je da li će biti driga verzija. Nije to pli sa zvaničnog sajta. Napisano je. Imaš na slici od freona karakteristike. Najnoviji drajveri od svih images izašlih do sada, najnoviji gstreamer i najnoviji python
