SAT antene iznad 240 cm
    • Tip od kojeg sam ja kupio AS-2700 je antenu platio 3200€, išao je osobno u Satshop po nju, platio najam kombija, ekipi koja je išla sa njim gablec i onda još kaznu za brzu vožnju.. Kad je antena stigla u Graz Izašla ga je ravno 4000€. Meni je istu prodao za 350€ :D
    • Ovo je najbolji tip takvog programa, napravljen od strane vrhunskog stručnjaka Jurija Filatova.. Program je na ruskom ali nije problem shvatiti kako radi.. Za izračun je potrebno je unijeti što točnije dimenzije, širinu, visinu i dubinu antene..
      Parabola6.zip
      Primjer izračuna za moju Laminas 2,7m:
    • @LambdaKt producer of your antenna states that focal distance of your antenna is 1480mm, that means the depth of the antenna is 276,7mm (not 275,5mm as you've measured) . Of course it does not change a lot, especially knowing the fact that it is not so easy to do precise measurements on such a big antenna. And it is funny that it is impossible to measure focal distance of this dish as the center of original parabola located 87,1mm below the lowest point of the working area.
      And if we use 1480mm as the focal distance than F/D will be equal to 0,55. But, in reality F/D equivalent of AS-2700 is equal 0,64 (1734mm/2710mm)
      Therefore, IBU with it's illumination angle of ~80* (for F/D=0,6) is almost perfect match for Laminas
      Hello RimaNTSS, welcome to our forum. You know very well how difficult it is to precisely measure a large antenna, 0,2 mm is a drop in the sea ;)
    • skala wrote:
      LambdaKt , koliko ti je bio razmak FG na prodelinki ako se još možda sečas ( odprilike)?
      Ne znam napamet, možda negdje nađem taj podatak. Moraš znati da je moja Prodelin antena bila vrlo plitka, tzv. long focus model 1224 i nije nimalo slična klasičnim CM i Prodelin antenama...
      RimaNTSS, did you remember our communications on this subject? sat-dx.club/viewtopic.php?f=14&t=458&start=100
      After a lot of attempts my best result was with the following parameters ... AB = 3018 mm, CD = 2710 mm, EH = 276.0 mm, F = 1481 cm
      In my case, the Inverto black ultra is not working well when I want receive UK beam 28,2 / 28,5E. I get a much better reception with the C-120 Invacom black pro lnb. I think it is a problem in the big boost of black ultra lnb and the interference that is caused by the very strong EU beam signals.
      Evo, našao sam moj stari proračun za model 1224 prema tvorničkim dimenzijama...
    • Nema problema s korotorom, samo moraš imati skalar za offset antenu.. Ja sam imao motoriziranu platformu na toj anteni, nemam bolju sliku ali vidi se otprilike položaj c band lnb-a
      Položaj i visina Ku i C band lnb-a je isti, jedino što je veći feed više isturen prema anteni.
    • Da, nikakav efekt ako ostaviš orginalni skalar od parabole, obavezno kupi novi, nije jako skup... Sa ovakvim sa donjeg linka ćeš dobiti najmanje 10-15% jači signal.. Ujedno dobiješ držač kojim ćeš lnb jednostavno učvrstiti na pravo mjesto.
      ebay.com/itm/New-Conical-Scala…0AAOSwyiFb0~7N:rk:18:pf:0
    • Pošto nemam skalarja za ofset, sem nekako namontiral korotor sa skalarjem za parabolo i to na držač za lnb. Bitno mi nekako da vidim kako funkcionira H-H motor za veče antene i moguča razlika u prijemu signala sa prijašne parabole od 180 na offsetku 240 cm. Zasada još nisam uspeo na podešavanju pravilne putanje satelita, šta je uzrok tome još neznam .
    • Ne znam dali je ta Prodelin antena već bila u funkciji.. Ja bi prvo podesio putanju s orginalnim ku band lnb-om i feed-om. Nakon toga bi podesio antenu na poziciju gdje emitira i Ku i C band, npr. 10e, skinuo orginalni feed i po najboljem signalu namjestio položaj korotora..
      Skalar od parabole ne bi trebao imati nikakav utjecaj na offset anteni, signal s njim i bez njega bi trebao biti isti tj. bitno slabiji nego uz upotrebu offset skalara...
    • Da , bila u funkciji na jednom satelitu kao fiksna antena, a ja nju preradio i motorizoval sa H-H motorom. Pa sada mi je problem dobiti pravo putanju satelita, jer dobijem raspon tek od 5E pa do 40E.
      Cev od motora je ravna tako na istoku kao zapadu , jedino je nešto nagnuta prema jugu.
      Ovaj H-H motor nisam dosada još koristio, a sad kad je u funkciji vidim da mu je verižni lanac labav lijevo desno za za 1 stupnju , tako da moram kao prvo zategnuti verigu .
      Nemam više ideja kako ustvariti putanju satelita, kao da sam početnik u tome.
    • Samo strpljivo, u biti nema neke razlike u podešavanju velike i male antene.. Razlika je zapravo samo u tome što je 2,4m bitno usmjerenija pa proporcionalno tome treba sve preciznije podesiti.. Sasvim mali pomak antene i motora na nosaču izaziv jako velike pomake kod lnb-a i zbog toga je to mukotrpan posao. Trebaš pratiti signal na samo 3 satelita, najviši centralni i najdalji koje možeš uhvatiti na istoku i zapadu. Na svakom od tih pozicija utvrdi dali je antena višlje ili niže od idealne te poduzmi protumjere prema uputama za podešavanje diseqc motora. Kad idealno podesiš te 3 pozicije automatski će se pojaviti signal i nekih udaljenijih pozicija pa onda njih uzmeš za orjentir sve dok ne dođeš do kraja optičke vidljivosti antene i motora.
      Nagib noseče cijevi je jako bitan, ako ikako možeš izravnaj taj krivi položaj. Ako ne postoji takva mogučnost, slažem se da je daleko bitnije da cijev stoji okomito u smjeru istok-zapad nego u smjeru sjever-jug, ovo drugo se ipak može kompenzirati nagibom centralne osovine i deklinacije tanjura ali će sve ipak biti teže za napraviti nego da je nosač strogo okomit..
      Luft na motoru je dodatna sol na ranu, 1° na anteni koja može razdvojiti dvije iste frekvencije na udaljenosti od samo 0,6° je blago rečeno totalna katastrofa.. Ako je pužni prijenos u pitanju to se vjerojatno da dotegnuti inače sve skupa neće biti za upotrebu.. Samo jedna desetinka milimetra zazora na zupčaniku na više od 2m udaljenom lnb-u izaziva pomak od nekoliko centimetara, takav pomak bi i na anteni od 60cm izazivao probleme u prijemu a ne na 2,4m..
    • 25 inpulsa mi je taman za 1* .
      Nisam posve siguran, ali nekako se mi čini da je problem u tome, da mi je previsoko namontiran korotor na originalnom nasaču ( od originalnog nosača pa do sredine skalarja je oko 10 cm i to zato jer njega bar sada nemogu spustiti niže zbog skalarja i C banda koji je več naslonjen na original nosač lnb). Sad po mom razmišlanju , ako je korotor usmeren iznad sredine antene , i prima signal iznad sredine antene, nikako ne možeš ustvariti pravilne putanje satelita . Dal sam u pravu?
    • Po meni ne, ako je lnb više ili niže od prave fokusne točke signal će biti slabiji ali to neće utjecati na putanju.. Jer primjera radi, ako imaš na motoriziranoj anteni još jedan lnb van fokusa, npr. namješten da hvata satelit koji je od centralnog 3° istočno, gdje god okreneš antenu taj lnb će biti u istoj putanji...
      Prema ovom što si do sada opisao, ja bi na tvom mjestu prvo riješio centriranje korotora na jednom satelitu, sve dok se ne izvuče maksimum signala a tek onda krenuo na podešavanje putanje..
      Ne bi bilo loše da postaviš neke slike, na njima bi se puno lakše moglo vidjeti dali si eventualno negdje pogriješio...
