AXAS HIS 4K E2 Combo 1x DVB-S2/1x DVB-C/T2
    • AXAS HIS 4K E2 Combo 1x DVB-S2/1x DVB-C/T2
      Technical specifications:
      - Web browser
      - Hisilicon 3798MV200 chip
      - CPU: ARM Cortex A53, quad core 64bit, 15,000 Dmips
      - GPU: High-performance multi-core Mali GPU
      - 8 GB eMMC Flash
      - 1 GB Ram DDR4 SDRAM
      - E2 Linux system in Flash
      - 1x DVB-S2
      - 1x DVB-C / T2
      - 2x LED indicator
      - 4 digit 7 segment display
      - RJ-45 LAN jack 10/100 Mbps
      - HDMI 2.0a, HDCP 2.2, HDCP1.4
      - Wifi built-in, IEEE 802.11b / g / n / ac, 300Mbit, incl. 2x WiFi antennas
      - S / PDIF Optical
      - AV socket for analog audio / video
      - Bluetooth 4.0 + EDR
      - COM port (RS232)
      - 1x USB 3.0 (back)
      - 2x USB 2.0 (left side)
      - 1x card reader (laterally right)
      - Micro-SD-Cardslot (left side)
      - A / V decoding: H.265 / HEVC & H.264, MPEG-2, AVS & AVS +, VC1, VP6, VP8, VP9
      - Profile Level: H.265 Main 10 Profiles L5.1, MPEG-2 MP HL
      - Video Resolution: 10bit, Up to 3840 x 2160 60fps, HDR10 Support
      - Audio decoding: MPEG I & II, MP3, Dolby Digital Plus, AAC-LC, HE-AAC, V1 / V2
      - Voltage: 12V, 2A
      - Power switch
      - Stand-by mode: below 0.5W
      - Dimensions: 195mm X 115mm X 20mm
      1x remote control
      1x HDMI cable
      1x AV cable
      1x power supply
      1x user manual
      ima i plus verzija sa E2 I ANDROIDOM
      129,90 eura
      ZGEMMA H7S(2 x DVBS2X,DVBT2(HEVC 265) multistream
      ZGEMMA H9.2H(DVBS2X,DVBT2(HEVC 265) multistream
      redline ts 140 super hd
