Pinned How to repair dreambox / Upute za popravak
    • How to repair dreambox / Upute za popravak
      poWeReD bY SaTeLiTsKi FoRuM
      Thanks to @Freon, @Miro all my friends from _ww.satelitskiforum.com
      You have to know some PCs have problems with LPT chance is bigger with
      old PC and i have info if you use Linux tool working better.
      HOW TO Reapair DM500 bootloader.
      1) Interface
      DB25 male printer connector
      6 wieres + 5 resistors of 100 ohms (you have to use short connection wieres between LPT and Dreambox
      from dreambox to resistors about +- 10 cm and from resistors to LPT use LPT cable but not to long.)
      ON printer connector short connect pin 18 to 25 and connect the last wire.
      rest of the wieres connect the resistors and use the schematics
      LPT <---------------> Dreambox
      2 --> 100 ohms --> 11
      3 --> 100 ohms --> 9
      4 --> 100 ohms --> 7
      5 --> 100 ohms --> 3
      11--> 100 ohms --> 1
      25 -->-->-->-->--> 16
      18
      2) Computer and BIOS configuration:
      BIOS COMPUTER >> LPT Printer >>ECP+EPP
      Windows XP >> Contr.panel-System-Hardware-Device>Porten>>Printer port>>i never use an interrupt!
      3) Start program >>Connect (important) When You hit the connect simultaniously place the power to dream.
      No Connection, Try Again (again) >>Connect then (important) When You hit the connect simultaniously place the power to dream.
      If you have connect >>(important) Write right dm500...bin for a boot of 500 alps (what must be all the clones).
      (boot file for DM500)
      After you can USE standard DreamUP to put new image
      The post was edited 6 times, last by hispasat ().
    • Sta reci odlicno @Hispa
      @Hispa 10+ ocjena. :thumbsup: 8o :thumbsup:
      Sobzirom da ja nisam ovo sve testirao niti imam cime par pitanja.
      Prvo ovaj file blimg i drugi file dm500_alps_boot_00_00_00_00,,.bin u Boot_loader ...dm500 mapi
      da li su to isti fajlovi odnosno da li su oba dobra za clone dm500 ili samo jedan od njih
      ako su oba ok onda treba jedan izbacit a ako nisu onda treba zamjenit i izbacit suvisan.
      Ako nisam u pravu koriguj te me.
      U tom slucaju bi trebalo proceduru korigovat .
      Drugo trebalo bi malo jasnije napravit razliku izmedju sad u pdf u prisutne seme
      jednostavnog JTAG i ovog sa samo 5 otpornika jel ce dolazit do zabune kod onih
      koji nemaju neko znanje o materiji,
      i da li ste vi testirali rad svega sa normalnim JTAG.
      Ako niste onda bi trebalo izbacit normalni JTAG,ustvari mozda je bolje izbacit normalni JTAG
      oni koji ga imaju ce vjerovatno znati i da ga koriste.
      Onda ova slika od @torcide bi bilo dobro da se doda u pdf izgleda odlicno
      mozda bi onda trebalo dodat da mozes na plocu zalemit konektor
      ili direkt zice kao na prvoj slici.
      Sobzirom da ja nisam nista testirao mozda samo mlatim praznu slamu.
      Koriguj me ako nisam u pravu.
      Sve u svemu hvala u ime ostalih clanova na trudu i dobro je da smo zajednicki
      kao SAT forum za sviju.
      Miro
      vuplus-community.net
    • Ao je moj file (skinut sa RDI-a) nema potrebe nista mijenjat - samo udri .exe i vozi.
      eto i ovdje file jos jednom.
      Ovdje nemam za Linux - na njemu nisam radio, pa ne mogu niti potvrditi.
    • Hispa evo vidim @Freon je napravio novi file
      pa bi onda trebalo stavit njega.
      Thx Freon
      Mislim da sad imamo sve.
      Ja bih izbacio onaj za normalni veliki JTAG
      ostavio samo ovaj sa par otpornika dodao sliku od @torcide
      i korigovao shemu na strani dreamboxa jer ne treba lemiti sve
      to samo otezava i uvecava sansu da netko napravi kratak spoj na ploci.
      Dakle samo minimum.
      Moja ideja a ti si da odlucis.
      The post was edited 1 time, last by Miro ().
