Pinned AzBox HD Elite i Premium - Nove verzije FW
    • tbudic wrote:
      ni sa ovim zadnjim FW se u advanced scan ne moze rucno unosit frekv transpondera...znamenku po znamenku...jedino sa 0.9.1621 je to moguce
      Moze! ;)
      1 - home
      2 - TV chanel
      3 - DVB-S
      4 - SAT/TP Edit
      5 - izaberi satelit,nakon toga odmah ispod spusti na frekvenciju
      6 - ADD TP = zeleno dugme na daljincu,i nakon toga upisuj parametre koje zelis po svojoj zelji ;)
      7 - e kad si to lijepo uradio sad se vrati na transponder scan i tamo ces naci sve frekvencije koje si dodao,naravno sad samo preskeniraj i to je to...
      Pozz
      svasta nesto
    • New Version 0.9.2238 for AzboxHD
      1. Release Notes
      2. Limitation
      3. - MPEG2 HD 4:2:2 video is supported.
      4. But H264 HD 4:2:2 video is not supported, currently.
      5. Fix
      6. - When you try to configure DISPLAY, system is crashed.
      7. Fix
      8. - Wrong time information of progress bar on youtube
      9. Fix
      10. - Macrovision-protected
      11. Fix
      12. - Can't play the movie with high resolution(over 1280 X 1080)
      13. Fix
      14. - At ISO files, language detection don't work (Audio: English 5.1 / Spanish 5.1 / Portuguese 5.1 ).
      15. Only have English and at subtitles the same (Subtitles: English, Spanish, Portuguese) only show English
      16. (Use root menu for changing audio track)
      17. Fix
      18. - Can't play OGG
      19. Fix
      20. - At Diseqc1.2 add possibility to use stored positions on motor,
      21. for example I already have stored diseqc1.2 positions on motor using other STB or a external positions, like Hotbird at position 12 of Diseqc1.2,
      22. i should be able to go to antenna configuration and define Hotbird Position - 12
      23. Add
      24. - Hot Key for restarting openxcas modules
      25. (Use "Forward Seek Key"(>>|) on Live TV mode)
      26. Add
      27. - Support DVD/CD Drives over USB
      Display All
      rapidshare.com/files/241297467/patch_2238.rar
      rapidshare.com/files/241310511…e_0.9.2238_patch.zip.html
      Pozdrav marinko
    • Latest FW for AzboxHD 0.9.2371
      1. Release Notes
      2. Fixed
      3. - From software 2163 wifi wep 64/128bit doesn't work anymore.
      4. Fixed
      5. - At HDMI mode -> changing the display format (fullscreen, Pillarbox, Pan & Scan),
      6. the video resolution changes to 576p - the output matches no longer with video-resolution in settings.
      7. Fixed
      8. - SCART -> the output is generally Macrovision protected, even at programs that are not protected.
      9. So Recordings via Scart are not possible.
      10. Fixed
      11. - SCART -> If you choose RGB-Signal, you have no output on HDMI at the same time
      12. Fixed
      13. - SCART -> Changes at display format will lead to green-screen followed with picture loss - reboot required!
      14. Fixed
      15. - AT network Services Menu - The displayed name is the current status,
      16. therefore please rename in activated (instead of activate) and disabled (instead of disable)
      17. Fixed
      18. - USALS-Settings are deleted after reboot
      19. Fixed
      20. - Subtitles are not in accordance with the spoken sentence, they stay until the next subtitle appears.
      21. The subtitle fits naturally no longer the situation. They should disappear
      22. Fixed
      23. - AzBox loose memory of historical navigation when change favorite folder or when jump between satellites
      24. Fixed
      25. - When you delete channels from the genre lists, the channel will be completely erased, not just the genre-labeling
      26. Fixed
      27. - In MKVs should be used the yellow button to change the sound, and Red button to select over Subtitles, as in TV menu,
      28. instead of clicking through.
      29. Fixed
      30. - VOB Files are not working(File extension should be .vob)
      31. Fixed
      32. - If you enter text which is longer than entry field, you can't see what you are entering, because text doesn't scroll
      33. Fixed
      34. - Renaming files in ftp is buggy, if you do rename in detail menu for a file which is on ftp.
      35. You can't exit the rename option only with home button
      36. Fixed
      37. - YOUTUBE: Timeline works not properly - longer as necessary
      38. Added
      39. - When adding a record from EPG, at reserved recording list there is no option to edit the timing.
      40. (Like start X minutes before and stop Y minutes later, from the EPG time).
      Display All
      rapidshare.com/files/247525151/patch_0.9.2371.rar
      Pozdrav marinko
    • Firmware Patch 0.9.2880
      1. Changelog:
      2. Fixed - SmartCard driver is updated because internal smartcard is sometimes reset or crashed
      3. Fixed - Using at least the 3 last firmware releases (0.9.2163, 0.9.2371 and 0.9.2372), the WIFI has some problems related with WEP(64/128) encriptation 1. Prevented the box from booting 2. Not possible to use the wireless connection
      4. Fixed - DVB-C - Search of frequenz < 177 Mhz is not possible ("Out of range")
      5. Fixed - DVB-C - Search-Mode Automatic ist not working
      6. Fixed - When selecting GUIDE on TVP sports, Box hangs up.
      7. Fixed - Moving of more than one channels shows error message
      8. Added - Germany DVB-C Frequency
      9. Added - Turkish OSD language
      10. Added - AC3 audio file is supported.
      Display All
      rapidshare.com/files/260176339/patch.rar.html
      Pozdrav marinko
    • AZBox NEW Firmware - rev. 0.9.3177 Test version
      1. AZBox NEW Firmware - rev. 0.9.3177OpenSAT is proud to present
      2. AZBox HD Firmware - rev. 0.9.3177
      3. (2009.08.19)
      4. this is only Test version
      5. RELEASE NOTES
      6. # FIXED
      7. - CI can not support HD channel
      8. - CI can not send the reply of ENQ
      9. - Subtitles are transparent when menu is set to transparent
      10. - Unicable is not working
      11. - If playing recorded contents on movie player, recorded contents have no sound
      12. - Can not add new SAT/TP on SAT/TP Editor
      13. - Can not play with After recording
      14. - If the channel has the subtitle language, which was selected on setting, subtitle
      15. should be showed, automatically
      16. # ADDED
      17. - DVB-T/C NIT Search
      18. - DTS decoding
      19. - The menu of "Fixe Interlace on/off" on channel manager
      20. For supporting the encoder, which may not respect the spec on this matter.
      21. "When progressive_frame = 1 the picture is progressive, the two fields represent the
      22. exact same time, and you should not see any comb effect when displaying the frame.
      23. Moreover, when progressive_frame = 0, top_field_first is used to indicate which field
      24. has to be displayed first."
      25. - Satellite Nile Sat 101/102/Altantic Bird4 (7.0W) is missing in the satellite list
      26. - Telefonica transponder on Amazonas(61.0W) is missing
      27. - Always start in TV mode
      28. - "Automatic Reboot Option" to Timer menu
      29. # IMPROVED
      30. - If you choose a movie from hard disk and in the same folder where the movie is stored
      31. there is an .srt or something else the box loads subtile automatically ordered
      32. by .smi/.srt/.txt.
      33. Best Regards,
      34. The OpenSAT/AZBox Team
      Display All
      rapidshare.com/files/269618648/patch_0.9.3177.zip Test version
      http://rapidshare.com/files/269618648/patch_0.9.3177.zip
      The post was edited 4 times, last by amano ().
    • evo sta nas ceka u sledecoj verziji
      0.9.3281
      # FIXED
      - Records of HD-Channel are freezing about all 10 Seconds. Tone also is less.
      Often this is also at recording from SD-Channe
      - When playing recorded contents on movie player, "Unsupported format" window is popup, to infinity
      - Subtitles are fail on following channels
      TP 10892Mhz 27500 SID 4801 V160 A80 // CANAL+
      TP 10892Mhz 27500 SID 4802 V161 A84 // CANAL+ FILM
      TP 10892Mhz 27500 SID 4805 V164 A96 // Ale Kino!
      - Channel scanning of DVB-T/C NIT is not working
      - When playing some MOV contents, STB hangs up
      - SmartCard is sometimes reset
      - From the EPG pressing OK and then select PLAY to zap to a channel totally block the AZbox
      (when the program is currentely broadcasting)
      - In manual time setting, GMT is not effective
      - Inaccurate synchronization of subtitles on Astara 28.2E
      - Invalid screen capture on 4:2:2 feeds
      # ADDED
      - Added "subtitle off" option in setting
      - Added "audio default" option in setting
      - Freesat EPG is supported
      - Screen capture on movie player
      - At setting menu, more options for audio are created, like:
      DTS: PCM <--> RAW
      AC3: PCM <--> RAW
      AAC: PCM <--> RAW
      Others: PCM <--> RAW
      Best Regards,
      Betatester
    • AZBox HD 0.9.3281 Beta firmware
      For download by special dispensation.
      THIS FIRMWARE IS RELEASED AS IT HAS NO MAJOR PROBLEMS.
      It is unfinished but has been determined not to cause any major problems with receivers. There are known bugs, so don't be surprised if it does not behave as expected.
      AZBox HD BETA Firmware - rev. 0.9.3281
      (2009.09.01)
      RELEASE NOTES
      # FIXED
      Often this is also at recording from SD-Channel
      # ADDED
      DTS: PCM <--> RAW
      AC3: PCM <--> RAW
      AAC: PCM <--> RAW
      Best Regards,
      rapidshare.com/files/279204201…are_AzBox_HD_0.9.3281.zip
    • ilje wrote:
      tomokiller wrote:
      Slažem se...
      A i čini mi se da je puno sporiji...
      Uglavnom, ja se vratio na 0.9.3180
      Pozdrav !
      kako to da je spoiji kad meni SirOliversys neko vece rece samo tebi ne valja svi drugi primjete razliku
      Ne bih ulazio u vasu diskusiju, samo prenosim kako jeste.
      Inace je spor sam po sebi, ali ovaj novi FW ga je ucinio jos sporijim.
      Imam antenu sa USALS motorom. Npr. Kad stisnem OK i udjem u listu, i odem u neki drugi paket i stisnem OK na nekom programu, treba mu cca. 4-5 sekundi da uopce pokaze na ekranu onu poruku "vrtim motor...", a jos da ga otvori sa cccamom treba mu jos cijela vjecnost.
      Uglavnom, sto se tice multimedije receiver je OK, uredno pusta sve sa mreze i USB HDD-a, ali za SAT TV je drek na sibici.
      CCcam moram svako malo prebaciti naprijed-nazad po jedan program jer zasteka ( i V0.2 i 2.1.1 patchirani ).
      Zivcira me sto ne mozes odmah stisniti OK vise puta da zatvori listu, nego moras pricekati 3-4 sekunde pa onda stisnes OK da skloni OSD grafiku.
      Sto se mene tice, ja cu pricekati jos do Bozica, nisam bas toliko nasekiran, ali ako ne naprave stabilni CCcam i ne ubrzaju FW, ovaj box nema buducnosti. Ponavljam, za multimediju je cisto OK, iako mu u audio player-u fali da mozes slagati playlistu nego moras imati predefinirane m3u fajlove.
      Pozdrav !
    • New Firmware Azbox 0.9.3501 (Beta)
      Firmware 0.9.3501
      AZBox Beta HD Firmware 0.9.3501
      (2009.01.10)
      RELEASE NOTES
      # FIXED
      - USB memory stick without partition is now supported
      - Movie Player: Bookmark option works better.
      - Using the bookmark function does not work after the 1 hour mark.
      - No recognition of audio languages in mkv files
      - TTX menu hangs when attempting to view teletext on "Canal+ Film HD" on HotBird 11278Mhz.
      - TELETEXT Polish Characters
      # ADDED
      - USB keyboard is supported (Not yet available for browser)
      - 70.0W & 180W satellite TPs
      - Audio API for plugins
      # IMPROVED
      - MKV Movies with high bitrates cannot be correctly reproduced
      - Optimized FORMAT procedure
      Now Formatting 1TB disks takes under 20 minutes
      - Copy speed (HDD, USB) is 30% faster than older versions
      server.az-box.co.uk/0.9.3501/patch.bin
      Nisam testirao
