Dream Elite BH 1.3 OE1.6 DM800 Multiboot Usb Tuner
    • Nova-TD stick problem
      Uredno ga prepozna al poslje ponovnog startanja prikazuje dm booting i tako se vrti vec pola sata. Izgleda problem sa fw dvb-usb-dib0700-1.10.fw .
      usb 1-2: new high speed USB device using brcm-ehci and address 3
      usb 1-2: configuration #1 chosen from 1 choice
      dvb-usb: found a 'Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity' in cold state
      , will try to load a firmware
      dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.10.fw'
      dib0700: firmware started successfully.
      dvb-usb: found a 'Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity' in warm state
      dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
      DVB: registering new adapter (Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity).
      DVB: registering frontend 1 (DiBcom 7000PC)...
      MT2266: successfully identified
      DVB: registering frontend 2 (DiBcom 7000PC)...
      dvb-usb: could not initialize remote control.
      dvb-usb: Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity successfully initialize
      d and connected.
      attaching virtual tuner 0
      Nasao sam fw 1.20 sad cu da probam s ovim.Mozda proradi :whistling:
      The post was edited 1 time, last by faja ().
    • Da ponovim jos jedanput nasa slova moraju da rade na svim Beyonce skinovima
      pa i na Beyonce 10 .
      Ako ti neradi znaci da ili nisi ubacio valjane ili nisi napravio restart.
      Nek brate stavi neko samo font ko je testirao za skinut i ubaci rucno
      ali tek posto si instalirao skin ako ga vec nemas u image.
      Ne zaboravi ako ponovo dodas/instaliras neki skin i izgubis nasa slova onda opet moras ubaciti svoj font.
      font ide u /usr/share/fonts
      Restart enigmu ili image.
      vuplus-community.net
    • Dane30 wrote:
      daj neko nek stavi ispravan font... da mozemo probat.. hvala...
      Zanči nakon instalacije @Mirinog skina zamijeniti font u \usr\share\fonts sa ovim iz privitka, te restartati enigmu2. Nakon restarta imat ćete naša slova na EPG-u!
      VU+ solo + WinTV-MiniStick HD Hauppauge DVB-T USB + Hard Drive 1TB / Black Hole 2.0.4
      DM800HD + AF9015 HD USB DVB-T Tuner + Hard Drive 250 GB / Dream Elite 4.0
      DM500S + Marwensat v2.7
      SkyStar2
      Triax 110 + 2x Quad Sharp LNB - 19e/13e
      Multiswitch TV-MAX 9/4
    • zabuko02 wrote:
      Odličan image...čestitke!!!
      Miro...jedno pitanje?...kako izbacit nepotrebne pluginse i tako ubrzat rad i smanjit RAM?
      Na BH bilo je po menu/plugins/...itd....ali tu kad upotrebim isti način, imam mogučnost samo manage extension/ ali nema opcije brisanja?
      Thx
      Image leti sam po sebi, tako da mislim da neko posebno "čišćenje" apsolutno nije potrebno, osim eventualna promjena defaultnog Armyevog skina sa nekim nopig skinom od @Mire (naravno iz Beyonce seriala).
      P.S. Osobno preferiram Beyonce 9 črlenu :D
      SkyStar2
      Thx
      Moze se ponesto brisati i dodavati sa software managerom i u njemu Packet managment
      kako se to koristi ima slikovno na DE forumu.
      Inace sa Packet managment se moze mnogo toga
      instalirati/brisati pluginsi,updates drivera i slicno ali pazi moras znati da ga koristis.
      jer ako pogresne stvari skidas kao recimo skinove mozes oboriti image
      isto vazi i ako pogresne stvari brises.Naime paketi su zavisni jedni od drugih.
      No vrlo je bitno da svak nauci da koristi Packet Managment a i inace
      software manager krije mnoge dobre stvari recimo za backup.
      Pa je vrjedno nauciti ga koristiti cak i po cjenu pada image
      dok naucis.
    • palco wrote:
      Ja vise volim sa pigom, i cekam public Beyonce 10 na server.Jos nije tu, ide na 1.3 image za DM8000
      Pozdrav od Palca
      Pa sad neznam bas da li je Beyonce10 podesan za DM800 zbog brzine jer to je ipak tezi skin
      no moces probat kad bude.
      Ja licno vise volim brzinu pa vecinom koristim skinove iz serije ako se nevaram 5,6,7,8,9
      jer svi koriste stvarno jedno od najboljih kodiranja za E2 po pitanju brzine a u isto vrjeme
      gotovo 100% potpore za sve vaznije dodatke.
      The post was edited 1 time, last by Miro ().
      Prvu stvar posle ubacivanja image in namještenje drive managerja je bio zamjena na Beyonce skin....tu na forum sam več dosta godina...ali ta serija skina od našeg mira je čista 10-tka....to je majstorija!
      @miro...znam kako to..isto bilo na E1...dok nisam 100 image ubacijo nisam znam..tek kad stvar zapne..tek onda se čocjek nauči. Sad E2 je malo drugčija....svejedno pitao sam zbog plugina kojeg nikad ne upotrebljavam...recimo Modem, CCccam switch, my Tube..itd
      Neznam dali se sječaš ovog tvog citata:
      Nabilo BH0.12 Lite
      Kako izbaciti iz image stvari koje ti eventualno nisu potrebne i sa time
      prilicno ubrzati dizanje image i smanjiti upotrebu resursa unutar image.
      Ja cu staviti listu sta sve mozes izbaciti a da ne utjeces na bazne
      funkcije
      naravno ako nesto od svega koristis onda to ne treba ni da izbacujes.
      Neke stvari mozes direkt da izbacis sa Plugin u Main menu
      sa funkcijom Remove Plugins .
      Kada startas Remove Plugins tamo imamo systemplugins
      i Extensions
      kada kliknes na jednu od ovih dvije grupe
      onda vidis sta je sve instalirano a sta moze da se izbaci.
      Dakle sta sam ja izbacio i po mome mjerenju drasticno
      smanjio brzinu dizanja image preciznija mjerenja cu naknadno objavit.
      Dakle sa plugins managerom mozemo izbaciti sljedece :
      cleanupwizard
      autoresolution
      genuinedreambox
      crashlogautosubmit
      vlcplayer
      softwaremanager
      wirelesslan
      videoenhacment
      videotune
      cutelisteditor
      mediaplayer
      mediscaner
      pictureplayer
      mytube
      networkbrowser
      networkwizard
      Kroz telnet mozemo izbaciti sljedece :
      Prvi paket python-gdata nemozes izbaciti ako neces da izbacis mytube
      Ovo su telnet komande koje koristis da bi izbacio doticne pakete
      i dodatke.
      ipkg remove python-gdata
      Kada si sve izbrisao naravno na vlastitu odgovornost
      restart i mozes testirati utanjeni Nabilo image.
      Moji rezultati testa .
      Pod kojim uslovima sam testirao
      U oba image instalirano sve isto ali bez gore navedenih djelova.
      Oba images na USB
      oba images na FTA kanalu bez ukljucenog EMU
      oba mjerenja od momenta aktivacije image U BA Menu
      (ali pocetna pozicija je ugasen box)
      do pojave slike na FTA kanalu.
      Razlika u dizanju image +- 30 sekundi
      sto je jako mnogo u odnosu na totalno vrjeme.
      Relativni test sa ram oko 10% do 15 % manje
      prilicno manje sa utanjenim image.
      Experiment se nastavlja i vjerovatno cu za njega posebno
      utanjiti i skin codiranje.
      Osim toga trba vidjeti da li se jos da sta izbaciti od instaliranih
      paketa.
      I na kraju testirati brzinu i upotrebu resursa kad je image direkt u
      flashu.
      Tako sam mislio, da bi nepotrebne stvari izbacijo...inače image je več sada ferrari :)
