Dream Elite BH 1.3 OE1.6 DM800 Multiboot Usb Tuner
    • Dream Elite BH 1.3 OE1.6 DM800 Multiboot Usb Tuner
      WHAT IS NEW ?
      Updated: Dreambox Dvb drivers: 20100414
      Updated: Enigma2 CVS: Experimental 15 april 20010
      New Skin: Army Class Plus HD
      Fixed: Device Panel minor bugs
      Included: networkbrowser, mytube, videoenhancement, autoresolution and DVDPlayer
      NEW NEW NEW NEW NEW NEW NEW NEW NEW NEW
      Usb tuner Dvb-T native support and dedicated panel in Extra-settings.
      TO BE SURE THAT YOUR USB TUNER IS SUPPRTED USE:
      Hauppauge WinTV-Nova-T (HD)
      Instructions to use Usb Dtt Tuner:
      1) Insert your usb tuner stick
      2) Goto blue -> blue -> Usb-Dvb-T Tuner Panel
      3) Activate
      The Usb Drivers will be Extended and Updated via Addons Manager.
      Currently included Anglofsky1980 Driver Module DIB0700:
      AVerMedia AVerTV DVB-T Volar
      Compro Videomate U500
      Uniwill STK7700P based (Hama and others)
      Leadtek Winfast DTV Dongle (STK7700P based)
      AVerMedia AVerTV DVB-T Express
      Gigabyte U7000
      Hauppauge Nova-T 500 Dual DVB-T
      Pinnacle PCTV 2000e
      Terratec Cinergy DT XS Diversity (Test OK)
      Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity (Test NOK )
      ASUS My Cinema U3000 Mini DVBT Tuner
      Pinnacle PCTV DVB-T Flash Stick
      Artec T14BR DVB-T
      ASUS My Cinema U3100 Mini DVBT Tuner (Test NOK)
      Hauppauge Nova-T Stick (70019) (test OK)
      Hauppauge Nova-T MyTV.t
      Pinnacle PCTV Dual DVB-T Diversity Stick
      Warning: DON'T INSTALL EXTERNAL DRIVERS IN THIS IMAGE OR THE USB TUNER PANEL WILL STOP TO WORK. YOU CAN INSTALL IN THIS IMAGE ONLY DEDICATED DREAM ELITE DRIVERS PACKAGES
      Warning: Old plugins for OE 1.5 cannot work in OE 1.6, you have to ask to plugin authors to update. This is not an image problem. DON'T REPORT HERE FOR PLUGINS. WE ARE NOT PLUGINS AUTHORS
      Warning2: THIS IMAGE HAVE THE NEW DRIVERS AND CANNOT BE INSTALLED IN MULTIBOOT USING PREVIUS IMAGES. THIS IMAGE HAVE TO BE INSTALLED IN FLASH
      Warning3: AFTER IMAGE INSTALLATION GOTO DEVICES PANEL AND MAP YOUR DEVICES. REMEMBER TO INSTALL MEOBOOT ONLY AFTER YOU HAVE MAPPED YOUR DEVICES.
      Warning4: ONCE YOU HAVE INSTALLED MEOBOOT DON'T MOVE DEVICE IN WICH MEOBOOT IS INSTALLED. (AS FOR EXAMPLE IF MEOBOOT IS INSTALLED ON USB DON'T REMAP THE DEVICE OF MEOBOOT ON USB2)
      Warning5: YOU CAN INSTALL IN MULTIBOOT WITH THIS IMAGE ONLY IMAGES OE 1.6 WITH THE NEW KERNEL.
      This image is a final Black Hole serie, to have maximum stability and performance.
      We remember that black hole serie images have the best epg system available:
      - Integrated Openepg for Sky-it Sky-uk Sky-Au
      - Latest CVS enigma2 Epg features
      - New external epg.dat system.
      Therefore, each board or community can create its favourite EPG data files, and upload it to a web space. Community members can then download it from that server.
      This feature offers additional benefits, such as:
      EPG download increased speed
      EPG download from any channel
      EPG scheduled download also during standby
      User set EPG Providers Add/Remove
      WARNING: THIS IMAGE INCLUDE THE NEW KERNEL 2.6.18-7.3. FOR THIS REASON YOU HAVE TO INSTALL IN MULTIBOOT ONLY LATEST IMAGES BASED ON OE 1.6 WITH NEW KERNEL.
      Main Function Keys
      Button 1xOK = Light Info Skin
      Button 2xOK = Extra Info Skin
      Button Blue = Dream ELite Blue Panel
      Button 1x Blue + 1x Red = Dream Elite Epg Panel
      Button 1x Blue + 1x Yellow = New System Monitor Panel
      Button Blue-Long-Push = Extensions
      Button Green = Dream Elite Green Panel
      Button Green-Long-Push = Subservices
      Button 1x Green + 1x Red = CCcam Info
      Button Yellow = Time Shift
      Addons
      Dedicated Addons Server
      Download and install additional packages from Dream Elite server
      Infobar/OSD
      Enigma2 Analogic Clock
      Channel Orbital Position
      Advanced Tuner Info: Sr Freq Pol Fec
      Signal SNR, BER
      Infobar Picons
      LCD/OLED Picons
      Advanced EMU information
      Dream Elite Panels features
      Blue Panel
      Extra Setting
      Black Hole Cron Manager
      OSD Settings
      Devices Manager
      Kernel Modules Manager
      Fast Plugin Settings
      Inadyn Settings
      Swap File Settings
      Hard Disk Setup
      Black Hola Mount Wizard
      OpenVPN Panel
      Samba/Cifs Panel
      NFS Server Panel
      Telnet Panel
      FTP Panel
      Info
      CCcam Info
      Service Info
      Enigma2 Settings
      About
      Memory
      Space
      CPU
      Process
      AutoCam
      Select EMU by Channel
      EPG Panel
      Global setting
      Provider Setting
      Green Panel
      CCcam info
      Fast Plugin
      Addons
      Addons Download Manager
      Manual Install Del packages
      Manual Install IPK packages
      Addons Uninstall Panel
      Dream Elite Statistics
      Scripts
      Many thanks to the Beta Testers Team.
      Many thanks to Rytec for all the epg servers providing precompiled Epg.dat for Dream Elite Image (add skyIta and SkyDe).
      Credits
      Many Thanks to Rytec for external epg
      E2 Sky Epg loader integration by MaxZ4.
      Many Thanks to lukkino (VDR-Italia) for opentv source code.
      Many thanks to Reinh@rd for the satellites.xml file.
      MANY THANKS TO ANGELOFSKY1980 FOR USB DVB-T DRIVERS
      ATTENTION!
      THIS IMAGE HAVE TO BE INSTALLED IN FLASH.
      THIS IMAGE CANNOT WORK IN MULTIBOOT WITH DIFFERENT IMAGES IN FLASH. DREAM ELITE TEAM WILL NOT SUPPORT IMAGES NOT INSTALLED IN FLASH.
      Known bugs:
      Hdd temperature is not working in OE 1.6 and the result is unpredictable
      Backups or other modified Images are not supported!
      This Images doesn't contain any keys nor softcams.
    • Ovo izgleda jako zgodno ukoliko je i potpuno funkcionalno, nažalost iako imam USB dvb-t tuner, nemam original DM800HD tako da ne mogu probati (dok ne izadje neki patch za clon box) :(
      VU+ solo + WinTV-MiniStick HD Hauppauge DVB-T USB + Hard Drive 1TB / Black Hole 2.0.4
      DM800HD + AF9015 HD USB DVB-T Tuner + Hard Drive 250 GB / Dream Elite 4.0
      DM500S + Marwensat v2.7
      SkyStar2
      Triax 110 + 2x Quad Sharp LNB - 19e/13e
      Multiswitch TV-MAX 9/4
    • dekimk10 wrote:
      da li ce raditi ovaj usb,na ovom imidzu?
      http://75.125.46.66/proizvod/leadtek-dtv-dongle-h/comp_comp_tuner/87/220
      ili mi preporucujete da uzmem neki drugi usb?
      Gigabyte U7000
      Pinnacle PCTV 2000e
      Artec T14BR DVB-T
      ovo su ti trenutno tuneri ko bi trebali radit...
      The post was edited 1 time, last by gile84 ().
    • @Miro
      da li znaš rade li srt titlovi na ovom imageu?
      Hvala unaprijed!
      SkyStar2
    • samac7 nije ovo vise nabilo tim niti ce ikad vise biti.
      Mi nemamo nista vise sa Nabilosat.Imamo nas tim i nasu stranicu koja se razvija ogromnom brzinom.
      Za USB tuner drivere radi se jako mnogo na njima tako da je isuvise rano reci koji USB tuner ce imati podrsku a koji nece
      pratite razvoj na DE forumu.
      Za srt titlove ja pojma nemam kao sto znate ja to ne koristim i neznam.
      SRT titlovi se moraju fixirati u CVS ako vec nisu.Dakle BH tim sa njima nema nista.
      Kad budu fixirani u CVS bit ce i u BH images.
      vuplus-community.net
    • Hbvala ljudi na brzom odgovoru, kad završi LP moram i ja probati to čudo od image-a :thumbsup:
      SkyStar2
    • samac7 wrote:
      izvini salko ali nerade subtitl na ovome image evo ja sad probao i nece obara enigmu,a koristim ovaj zadnji subtitl 2.55 pozz
      @samac7 ne mislim na Damirov Subtitle Player, nego da li rade srt titlovi kad se pusti neki mkv film sa hard diska od DM 800 HD???
      Možeš li mi to provjeriti, molim te? Ako nemaš hard disk možeš staviti naki mkv film na usb stick sa srt titlom pa da provjeriš da li rade titlovi.
      Unaprijed hvala!
      SkyStar2
