SKYBOX S9 HD PVR receiver
    • SKYBOX S9 HD PVR receiver
      SKYBOX S9 HD PVR
      General Specifications:
      1) 300 MHz MIPS Processor - Linux Operating System
      2) Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;
      3) Fully compliant MPEG-2 MP@HL & MP@ML;
      4) Fully compliant MPEG-1 Layer I & II & III, Dolby Digital Audio(AC3);
      5) SCPC & MCPC receivable from C/Ku band satellites;
      6) multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable/1.2/1.3(USALS) supported)
      7) NIT search supported;
      8) Support MHEG-5;
      9) Support HDMI 1.3;
      10) Support PVR(store in USB disk);
      11) Multimedia files playback(by USB);
      12) Support Electronic Program Guide(EPG) for 7 days;
      13) Teletext and subtitle out through OSD;
      14) Support multi-lingual DVB subtitle and teletext;
      15) Automatic and manual channel scan options;
      16) automatic service scan
      17) channel-change time < 1 second
      18) OSD in many languages and skin-support
      19) Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable;
      20) LED Display
      21) Multiple display mode: 1080i/720p/570p/576i/480p;
      22) MPEG-2 / H.264 Hardware decoding
      23) Videotext Decoder
      24) Analog audio output: stereo(L+R);
      25) Digital audio output: S/PDIF by coaxial and optical;
      26) S/PDIF Interface for digital bit stream out (AC-3)
      27) YCbCr available;
      28) 2 x Scart (RGB, FBAS or S-Video)
      29) Screen format:auto, 4:3, and 16:9;
      30) Upgrade software through USB2.0 port;
      31) Powerful program management function, parent lock;
      32) CA 1x slot and CI 1xslot
      33) 10/100Mbit Ethernet Interface
      34) directly bouquet-lists
      Packing:
      Gift box:32.5*31.5*8.5CM
      1x User Manual
      1X Skybox S9 HD PVR satellite receiver
      1X Remote Control
      MORE
      1. DVB-S2
      2. Input Frequency:950~2150MHz
      3. Loop Out Frequency:950~2150MHz
      4. Input Level:-65~-25dBm
      5. Input Impedance:75¦¸
      6. LNB Power: Auto/14v/18v/OFF, Imax = 500mA
      7. Video decoder
      8. Video Compression MPEG-2 and MPEG-1 compatible, H.246
      9. Video Formats 4:3 / 16:9
      10. Letterbox for 4:3 TV-Device
      11. Audio decoder
      12. Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3
      13. Audio Mode Dual (main/sub), Stereo
      14. Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
      15. Output digital
      16. Output Level 0,5 Vss on 75 Ohm
      17. Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
      18. S/PDIF-Output optical, Toslink
      19. Video parameter
      20. Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
      21. Teletext filter in conformity with ETS 300 472 Standard
      22. TV-Scart
      23. Output: FBAS, RGB, S-Video
      24. Serielle Interface RS 232
      25. Typ RS232 bidirectional
      26. Bit rate 115,2 kBit/s max.
      27. Plug Connector SUB-D-9
      28. Function: Update of Firmware
      29. Ethernet
      30. 10/100 MBit compatible interface
      31. Function: Update of Firmware
      32. USB
      33. 1 x USB 2.0 Host ,PVR
      34. LNB power and polarisation per tuner
      35. LNB Current 500mA max.; short-circuit-protected
      36. LNB Voltage vertical < 14V no load, > 11,5V at 400mA
      37. LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
      38. Count of active satellite position
      39. DiSEqC 1.0/1.1/unicable/1.2 SAT POSITION / SAT OPTION
      40. DiSEqC - Rotor Control
      41. External PSU
      42. Input:110-240V AC / 50-60Hz / 0,6A
      43. Output: 12V = / 3,0A
      44. Physical specification[color=#ff0000][/color]
      45. Ambient Temperature +15 °C...+35 °C
      46. Humidity < 80%
      47. Size (W x D x H): 300 mm x 220 mm x 56 mm
      48. Weight: 1,8 kg without HDD
      49. Power
      50. AC input range:100-240VAC 50/60Hz
      51. PowerConsumption (Standby): Max. 10W (<1 W)
      Display All
      cjena oko 1000 kuna ...
      Cosa Nostra - Samo Techno (Promo)
      youtube.com/watch?v=7BI8pxR57Fs
      The post was edited 4 times, last by zupy ().
    • kako sam na jednom stranom forumu pročita :
      one restriction is 4 cccam lines maximum.
      The good thing is As client cccam is solid. Tested with nagravision and seca channels on Hispasat 30 w
      NewCamd List
      Just extract and copy file to usb pen.
      Mavigate to
      Menu/
      Tools/
      Upgrade by Usb/
      Upgrade Mode-Misc Files/
      Select&Upgrade(ok)/
      NewCamd.list(MGCamd Plug)/
      Yellow to upgrade
      CCcam config for Usb Update
      Mavigate to
      Menu/
      Tools/
      Upgrade by Usb/
      Select&Upgrade(ok)/
      CCcam.cfg(CCCam Plug)/
      Yellow to upgrade
    • novi firmware .
      firm du 20/10/2010 (EU)
      1. Solve France HD channels cann't be played well
      a. upgrade the firmware.
      b. edit the replace.list like this:
      X: { { 1811 } { 0100 } }
      c. update the replace.list by mgcamd
      2. Add hungarian ,correct french and russian language
      3. solve the cccam's short characters problems, add from 17 to 32
      4.Add much more CCCAM accounts,it can support 9 at most
      5 Add NEWCAMD Server Setting,it can be taken as server
      1. http://rs978l32.rapidshare.com/#!download|978|426315349|NM_HDS2_CMT_1010200755.rar|1344
      setting lista
      Solomend/SatHawk/Openbox S9-Settings
      settings sortiert von Astra19,2 u. hotbird13 sortiert für solomend HD800-Sathawk4000 u. Openbox S9
    • antoxx1 wrote:
      MickeySa wrote:
      E anto,
      Ovo ti je onaj sto sam spominjao pod temom oko Amika i Opticum 9600, svi su bazirani na istom chipu.
      Ima i OpenBox isto :)
      sve ploce su iste.
      sve je to isto pakovanje i sathawk/solomend
      pisali su za tog da je u rangu dm 800 nije mu ni do ispravljača.. 8o 8o
      Stigao mi je juče ovaj box. Ima problema na nekim kanalima se restartuje, ali probaću novi softver. Mislim da se isplati definitivno za ove pare.130usd sa troskovima slanja, a vidim sad je i jeftniji. Ne može se mjerit sa dm800 , ali kome treba HD klijent box... bolji neće naći za te pare. Za cijenu jednog dm800 kineza može se uzet 2xOpenbox.
    • NDS ne trza niti je trzao. Novi softver je ispravio neke random reboot momente, mada i sad zna da se desi ali je podnošljivo. Mana je možda što ne otvara nova gr i viaccess 3 i 4. Takođe nema podršku ni za platforma hd 9e. Vrijeme otvaranja kanala je ok kao dm , ali je nekad potrebno više vremena. Nekad ga otvori odma...
    • ivanjica wrote:
      ima li iko ko mi moze pomoci da ubacim c linije u ovaj box?
      u postu broj 5 imaš način preko usb-a i CCcam cfg za ubacit znači samo unutra upiši c liniju i ubaci preko usb-a
      To upgrade it, go to
      - Menu/
      - Tools/
      - Upgrade by Usb/
      - Upgrade Mode-Misc Files/
      - Select&Upgrade(ok)/
      - CCcam.cfg(CCCam Plug)/
      - Yellow to upgrade
      - GO to Network Local setting and set it up with dynamic or fixed internal ip
      - Check CCcam and you will see connection getting active
      Might need a reboot for alterations to apply
      As per pictures bellow
