RTi core RC4 Enigma 2
    • RTi core RC4 Enigma 2
      Change Log :
      - New Kernel from 26.01.2011 ( Linux AZBox 2.6.22.19-19-the_ripper #216 PREEMPT Wed Jan 26 19:22:07 CET 2011 mips GNU/Linux )
      - New Drivers
      - Added support for .TS file Playback ( Now You are able to play recorded material directly from AzBox )
      - Added support for Timeshift
      - Several fixes on .py files for better stability
      In progress : We will move soon to the
      new structure / skeleton, and we will introduce support for DVB-T, DVB-C
      and second DVB-S2 tuner ( just for Premium+ model ). Result of this
      changes will be better stability and functionality of Enigma 2 in AzBox
      HD Receivers.
      Also, RTi team wants to express big THANK YOU to SIF Team, which also announced support for AzBox HD Devices.
      Please make as much as possible tests, and report them on our forum :
      1. http://www.azbox-enigma.eu/RTi/forum/index.php
      Download:
      1. http://www.azbox-enigma.eu/RTi/forum/showthread.php?186-RTi-core-RC4-Enigma-2&p=1376#post1376
      Dreambox 8000
    • New driver by: The_Ripper
      New driver od The_Ripper za jos bolji Recording/Play TS & Timeshift:
      Novi driver em8634dvb.ko
      Izvadite i ostavite sadasnji i isti zamjenite s postojecim u: /lib/modules/2.6.22.19-19-the_ripper/extra/ ... (nakon toga REBOOT)
      Kod mene sada ... funkcije timeshift kao i pomak stanki je mnogo brzi nego prethodni kript! Iste pogodnosti, trebali biste imati iz drugih funkcija u popis! Iz ociglednih razloga!
      DOWNLOAD: rapidshare.com/files/445163193/em8634dvb_3.zip
      Pozdrav..;)
      The post was edited 1 time, last by Daconi75 ().
    • Daconi75 wrote:
      Evo i mali utisak nakon testiranja nove RC4:
      Prije svega VELIKA ZAHVALA za FIX, naime radi timeshift i snimanje playback fajlova... :thumbsup:
      - Stabilnost image je veoma dobra
      - Radi uredno i Mp4
      -Cak i moja lista ide uredno..;)
      Pored gore navedenog:
      - uspjesno upogonjen Mbox 4.022
      - CrossEPG radi iako imam neka cudna vremena na HRTovim programima
      Problemi koji (jos) nisu rjeseni:
      - 4:3 slika je razvucena cijelom sirinom ekrana (ne reagira na promjene setinga).
      - Subtitle tipka (crvena) mapirana je za snimanje, iako imamo tipku za snimanje na daljinskom.
      - Language tipka (zuta) je mapirana na nasto sto bi moglo biti time-shift ili tako nesto
      - Ne radi teletext
      - Ne radi citac kartica
      Srecom imam Dreambox pa prebacujem na njega kad gledam neki 4:3 program.
      Kvaliteta slike je stvarno fantasticna, super posao rade decki, svaka cast i hvala vam na svemu.
      - Radi uredno i Mp4
      - Ne radi teletext
      Koliko znam, a mislim da znam dobro, i na dreamboxu je crvena tipka za snimanje, pa se stoga islo na to da se i na AzBoxovim RCU, doda Dreambox keymapping, tj da se tipke mapiraju radi sto lakseg koristenja e2, i lakse tranzicije.
      Dreambox 8000
      E da bas neradi nebi se slozio satobom
      Evo ja sam malo poigro se sa oscamom i slo tv i cita je malo jes veci ECM al boze moj tako je kako je
      1. 2011/01/29 18:25:28 2C6E14A0 r reader thread started (thread=2C6E14A0, label=rtvslo, device=/dev/sc0, detect=cd, mhz=500, cardmhz=500)
      2. 2011/01/29 18:25:52 2CF314A0 c client connected to 50000 port
      3. 2011/01/29 18:25:52 2CF314A0 c encrypted newcamd:50000-client 127.0.0.1 granted (keka, au=rtvslo)
      4. 2011/01/29 18:25:52 2CF314A0 c user keka authenticated successfully (CCcam)
      5. 2011/01/29 18:25:52 2CF314A0 c AU enabled for user keka on reader rtvslo
      6. 2011/01/29 18:25:59 2CF314A0 c keka (0500&031000/0C82/28:4FDE): found (400 ms) by rtvslo (of 1 avail 1)
      7. 2011/01/29 18:26:09 2CF314A0 c keka (0500&031000/0C82/28:4FDF): found (231 ms) by rtvslo (of 1 avail 1)
      8. 2011/01/29 18:26:19 2CF314A0 c keka (0500&031000/0C82/28:9E23): found (282 ms) by rtvslo (of 1 avail 1)
      9. 2011/01/29 18:26:29 2CF314A0 c keka (0500&031000/0C82/28:9E22): found (231 ms) by rtvslo (of 1 avail 1)
      10. 2011/01/29 18:26:39 2CF314A0 c keka (0500&031000/0C82/28:9E66): found (249 ms) by rtvslo (of 1 avail 1)
      11. 2011/01/29 18:26:49 2CF314A0 c keka (0500&031000/0C82/28:9E67): found (251 ms) by rtvslo (of 1 avail 1)
      12. 2011/01/29 18:26:59 2CF314A0 c keka (0500&031000/0C82/28:C831): found (236 ms) by rtvslo (of 1 avail 1)
      13. 2011/01/29 18:27:09 2CF314A0 c keka (0500&031000/0C82/28:C830): found (253 ms) by rtvslo (of 1 avail 1)
      14. 2011/01/29 18:27:19 2CF314A0 c keka (0500&031000/0C82/28:45EC): found (264 ms) by rtvslo (of 1 avail 1)
      Display All
      Vu+ duo2
      Vu+ zero4k
      DM920
      WeTek Play 1,2 Core Hub
      Raspberry pi 1,2,3
      Na Dreamu je snimanje Radio gumbom ispod kojeg je nacrtana crvena tockica, a crvena tipka sluzi za premotavanje unatrag (rewind).
      Na AzBoxu postoji crvena tipka ispod koje pise REC, a ispod crvena pise SUB-T.
    • Pozz
      Ja imam problema sa C+ Hd kanalima iz paketa D+ na astri 19.2e, C+ HD, C+HD futboli C+xtra HD(svi na frekvenc 11435 V) tona ima slike nema a kad ponekad uspem da dobijem sliku, ista secka, trza i javlja se videoaudio desync, dok su ostali HD kanali iz tog paketa koji su na drugim frekvencijama ok,
      -isti problem sa Nova Helas Hd kanlima na hotbirdu,
      -isto i sa Redlight HD na Hotbirdu
      Sve ovo me muci na svim verzijama E2 dok na oficijelnom Fw svi gore pomenuti kanali rade ok i bez problema.Neki kazu da je hardwerski problem pa mi malo nejasno, ako jeste onda kako to uredno radi na originalnom fw?!
      Reciver je Elite
      Pozdrav,
      Nije tacno, pokusaj ubaciti bilo koji gemini na dm 800 / 8000 i pritisni crvenu tipku i vidi sta ce ti biti ponudjeno, nazalost nisi u pravu, evo imam pred sobom DM 8000 i probavam, a i probavao sam prilikom testiranja snimanja za AzBox i hvatanja logova.
      Znaci Gemini 5.1 DM 800 / DM 8000 , pritisnes crveni button nudi ti se vise opcija snimanja :
      Snimaj do kraja dogadjaja
      Snimaj neprekidno
      itd
      itd.
      Sa radio tipkom u Geminiju ulazis direktno u Radio mod, mozda ja grijesim, ali pravilno citam sto pise na daljincu i pravilno pritiscem.
      Dreambox 8000
    • Ludi Pera wrote:
      Ovo je daljinski od dm 800 i tu je crveno dugme za snimanje, dok na dm 8000 nije tako jer resiver ima posebnu tipku za snimanje a ova crvena tipka koju vi spominjete služi za podešavanje quickbutton-a.
      Vu+Duo također ima daljinski koji radi na principu ovoga od dm 8000.
      Quick Button je zelena tipka Pero.
      Crvena tipka je za snimanje !
      Dreambox 8000
    • Ouote MickeySa :
      Uz svo dužno poštovanje, ali velika većina korisnika AzBoxa nisu korisnici DreamBoxa, nego su naviknuti na raspored tipki po Opensatovom firmware, zato bi po mojem mišljenju bilo svrsishodnije da se raspored tipki prilagodi tome.
