Nova generacija AB Ipbox uređaja - AB Ipbox 55Hd, 99HD, 9900HD, 9900HD+
    • U mene je 99HD a ččini mi se 55-tica čak i oblja opcija nego 99 (kome ne trebaju 2 tunera) i to iz razloga većeg flesha.
      Igram se ima par dana sa raznim emulatorima i njihovim konfiguracijama i čini mi se oscam zasad najbolji - otvara vrlo brzo.
      Koje su najbolje verzije emua se vama pokazale da ne šaram previše??
    • Novi PKT je out
      PKT IP9900/IP99/IP55 E2 HAARP v2 Image
      Enigma2 OpenSource SH4 Duckbox Project GIT-2705 PKT mod SVN-1153 HAARP v2 Image
      Image is designed for installation only in SATA or FLASH device
      Added by sh4 Duckbox Team:
      - [stm24] OSS SND kernel configs not needed any more (e.g. CONFIG_SND_PCM_OSS)
      - [stm24] added lzma patch for squashfs
      - [stm24] ext4 can now be used for ext2/3
      - [make/ffmpeg] - updated ffmpeg 0.6.1
      - [multicom-3.2.4_rc3] add new multicom driver
      - [eplayer3] playback aac-he streams with aac-lc
      - adding opkg binary to default build
      - fix timing problem in filepush
      - [Player2 179/191] possible fix for chopped DTS sound on some files
      - [libeplayer3] support for OSD 3D modes for subtitles
      - [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
      - [stm24] added squashfs-tools 4.0 lzma patch
      - add busybox 1.18.5 stable
      - extend streamproxy to support linuxdvbapi5
      - [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
      - [player2_191] fsynth bugfix
      Added by PKT:
      - first build on stm24 kernel
      - add new WebInterface v 1.6.7
      - new function "live ecm" in infobar
      - show Channel Number on Front Pannel + ON/OFF in setup menu
      - fast switching channel
      - upgrade CrossEPG svn 268
      - fix qwerty VirtualKeyboard
      - fix Backup/Autorestore function | LABEL=RECOVERY required
      - fix channel number showing on VFD if long channel name
      - set home directory to /root
      - EPG description on channel list -> ON
      - change reading of ecm.info
      - new converters and skins modifications
      - fix dimmer action when channel switch
      - fix parsing PROV, CAID, PID
      - moving EPG support to KeyMapper
      - ReferencePKT optimization
      - set PKTGoldHD as default skin
      - fix CIFS mount if passwd is empty
      - MPlayer fix GS of EOF
      - upgrade formating device in Install Manager
      - update API of MyTube based on last CVS source
      - update EmuManager v1.0.6: add sh4Cam support & gbox fix
      - font FIX moved to Skin setup
      - remove unnused files or BP menu settings modification
      - fix showing processes
      - res_emu in standby add in BP->Settings
      - tune and fix sys_info
      - add showing /Loaded modules/ in BP ->Menu ->System
      - update WIFI scripts:
      * add detecting of supported USB WLAN adapters
      * user is informed about unsupported device
      * optimize selecting WLAN driver
      * optimize starting WLAN driver
      - fix show event-progress in channel selection
      - fix crossEPG
      - PKT InstallManager 1.2.2
      - PKT KeyMapper 1.5
      - update Permanent Clock
      - fix EMUManager russian translate
      - add green button support in Media Player
      - fix Inappropriate ioctl for device
      - add auto flash cleaner
      - fix streamproxy after reboot
      [IP99XX] - add WIFI drivers in flash version
      Known issue:
      - USB version is temporarily not support
      - TNK HD work but many reset is needed
      - subtitles in MediaPlayer not working good
      - PIP is temporarily not work
      - teletext temporarily not work
      Advice:
      - SoftCAM is needed: "ufs910" or "duckbox" boxtype
      FTP login: user: root, passwd: pkteam
      Aktualizacja (UPDATE -> SVN-1157)
      BP->Addons->Actualisation
      - fix SCART [IP9900/IP99]
      - fix 3D channels [IP9900/IP99/IP55]
      DOWNLOAD 9900 SATA
      DOWNLOAD 9900 FLASH
      DOWNLOAD 99 SATA
      DOWNLOAD 99 FLASH
      DOWNLOAD 55 SATA
      DOWNLOAD 55 FLASH
      Pozdrawiamy Polish Koders Team
      Ja ga pičim u 55HD pa javim doživljaje..
      The post was edited 1 time, last by zupy ().
    • zupy,kako bi ove nove IP BOX recivere(99hd i 55hd) usporedio sa drugim reciverima koji isto imaju .sh4 procesore.
      da li na IP BOXU Enigma2 radi bolje od npr.Amiko Alien,Kathrein idr.?
      da li si probao instalirati Damir plugin i kako radi na IP BOXU?
      na kraju,po tebi od ova tri recivera sa .sh4 proc.,da li su slični po performansama ili bi ipak IP BOXU dao malu prednost ispred Aliena i Kathreina.
    • Od kathreina je sigurno bolje a mislim i od Amika ( nisam se previše igrao sa ovim zadnjim).
      Postavit ću video zappa kad uspijem uplodovati....
      Što se tiče subtitle playera 100% radi ok jer probao sam na prijašnjim verzijama imagea ( na ovoj nisam probao jer nisam mogao vremenski).
    • Na zadnjem Nocturnu nerade subtilovi na madiaplayeru (na siftem beta 0,6 rade solidno). Zap sa mgcamd je puno brzi nego na oscam a i stabilnost oscam mi je upitna. Iz nekog razloga nakon veceg broja zapova oscam se rusi, dok mgcamd (u kombinaciji 2.0.11) moze raditi do bezsvjesti.
    • Pozz, evo dobio i ja jednu 55-icu na test ali sam mu odmah uspio doći glave :). Radio je ok sa softom koji je došao s njim, pokušao sam ubaciti ovaj noviji što je tu postavljen sve je odradio i na kraju je napisao "upda" i tu stajao dugo vremena. Isključio sam ga i pokušao startati ali nakon toga zaglavi na "boot" i ni makac. Probao sam ponovno, pa i sa drugim softom, ali ništa. Upgrade prođe ali uvijek isto na kraju priče. Ima neko rješenje ?
    • Ovi resiveri se fleshaju malo duze, i ako image ne prelazi 27MB, npr. PKT ili Siftem beta na Ipbox99 zna fleshat preku USB i do 30-40 minuta.
      Mozda postoji sansa da ga vratis sa nekim softverom odavde abcomeu.com/download-software , ako ne ..vracaj ga odakle si ga i dobio.
      Za ubuduce, osnovno je kod flesanja ipboxa da se saceka restar resivera ma koliko to tralalo. Nije lose koristiti i online update. Puno je brze a i sigurnije.
    • Hvala, formatiran je bio i prije na fat32,full, procedura je jasna i poštivana :) jedino je moguče da mu je duže trebalo nego sam mislio pa sam ga prekinuo, ali sam čekao sigurno bar pola sata. Sad ću probat opet. Ima li neko iskustva, koliko mu treba vremena, baš za 55-icu ? Za vračanje nije problem ( CATV ) ali sam ga mislio malo testirat kad sam ga već dobio:)
