OE2.0 Experimentals DM 500HD
    • OE2.0 Experimentals DM 500HD
      Date: 2012-04-30 14:12
      Enigma2: 3.999git20120430-r1.0
      Distro: opendreambox 2.0.0
      Machine: Dreambox dm500hd
      Link: dreamboxupdate.com/opendreambox/2.0.0/ipk
      MD5: c0ae93c349252719a39d3b0b893f26b6
      SHA256: a991386c482896c899900357fcd8bd0cce9384eee2412125d7 4052843d8a2f6a
      Description:
      CHANGELOG DM500HD EXPERIMENTAL OE2.0 20120430
      enigma2 (20120327 rel32 -> 20120430 master)
      - added default HD skin
      - worked on input device detection
      - fixed broken live to timeshift transition
      - fixed transponder scan problems with broken NIT entries (zero symbolrate)
      - optimized transponder scan (non-DVB transponders are now skipped much faster)
      - fixed RASS picture download
      - added option to use custom spinner pictures
      - fixed teletext subtitle crashes
      - bugfixes for storage device manager
      - fixed erroneously removed repeated timers via instant record button
      - fixed repeated timer handling via instant record button
      - added notification queue / manager
      - small skin engine improvements (menu entry description)
      - added HDMI CEC core support
      - added hebrew translation
      - added (expert) menu option to enable SCPC transponder optimized search ranges
      - fixed slow zapping times between motor-connected LNBs and non-motor LNBs
      and added a (expert) menu option to switch back to the old behaviour
      - added support to playback unprotected "blu discs"
      - show current ip address in about screen
      - fixed multi-language epg support (broken since arte/arteHD workaround)
      - added initial UPnP-Client Support for plugin-developers (enigma2-plugin-systemplugins-upnp), take a look at the available demo plugins for some examples
      hardware drivers (20120322 -> 20120415)
      - added HDMI CEC support for dreamboxes with HDMI connector
      - added support for synchronized PCM playback (7400,7405 based dreamboxes)
      - HDMI hotplug improvements/changes
      - various vtuner improvements (added ACK timeouts)
      - added new vtuner MSG_GET_TUNE_SETTINGS to set the linux tv api min_delay_ms value
      other
      - updated runtime environment
      - updated from linux kernel 2.6.18 to linux kernel 3.2(.16)
      download
    • Kod mene je u flashu. ext.HDD pronasao i mountovao auto. ubacio BA 7.0.1 i rade stari image u multibootu bez problema.Zatim sam se vratio u flash,raspakovao od Oozoona Korisnicku skriptu i **cam i sve to ubacio po folderima,radi sve ok. key cita ali **cam confing ne cita iz etc foldera i tu sam zapeo.
    • entusiasti wrote:
      Ajde javi boga ti kako si uspeo da pokrenes bilo koju emu... A kolega @otes jesi uspeo sa tim problem gde si bas bio zapeo...
      U medjuvremenu je izasao geminiplugin i radi kao i na OE1.6.Naravno da sam uspio ali vidim nema zainteresovanih pa djaba pisati.Posto u flash jedva da se ugura gemini to bi moglo biti alternativa.
      Evo ukratko,ustvari kao sto se nekad ubacivao u cisti CVS,znaci Userscripta iz Oozoona,stim sto se ovdje mora izbrisati iz usr/bin dccam i u var ordneru napraviti simlink etc-->etc/ da bi povezao confing, ostalo je isto kao i ranije.
      Instalirao image,gp3 wizard,zatim gp-cam-feed,onda skinuo cccam 221 ubacio u etc cfg i sve normalno ide .
    • Malo samo sumirao šta je nova
      - added webkit based webbrowser
      - various changes for hbbtv integration
      - added support to burn and playback unprotected "blu discs"
      - added DLNA Mediaserver
      Više-manje fataju konkurenciju tj. segmente koji su ovi nadodali :)
    • Pozdrav
      Evo ja sam ga jucer ubacio.Zadnju verziju (dreambox-image-dm500hd-20120612).i fercera bez ikakvih problema,samo nema pordsku za neke skinove sto bi htjeo metnuti,ali i to ce se valjda promjenuti inace je super.l
      evo upute uzeto sa stranice satfriends.com
      1/ install an image with OE2.0 (Experimentals OE2.0)
      Latest Experimentals OE2.0 DM500_HD : http://www.dreamboxupdate.com/opendr...d-20120602.nfi
      2/ Open DCC => FTP => etc =>opkg and edit "arch.conf" with adding "arch mips32el 26".
      3/ Put g3wizard_0.16-r0_all.ipk in /tmp
      4/ with telnet : opkg install /tmp/g3wizard_0.16-r0_all.ipk
      5/ After rebooting box you will find Gemini3 Wizard in plugins.
      6/ Put gemini-mips32el-feed.conf in etc/opkg.
      7/ Reboot Box
      8/ Go to Menu=>Plugins=> and install Gemini3 Wizard
      9/ After rebooting you will find Gemini blue panel.
      10/ When you do that try to install OneStep_GP3_Cam_Feed by telnet, you have to put OneStep_GP3_Cam_Feed in /tmp and then with telnet opkg install /tmp/gp-cam-feed_0.3_all.ipk... reboot the box with blue panel co to Addons and you will have a list of camds. :thumbsup:
