OpenPLi 3.0: new alpha experimental images!
    • OpenPLi 3.0: new alpha experimental images!
      ""Hello all,
      As you can read in several topics, in our development email list and via our twitter account we are working on: OpenPLi 3.0.
      These 3.0 images are at some risk at these moments, so don’t use and flash them if you don’t want any trouble!
      What are the benefits of OpenPLi 3.0:
      We are just moving the current openpli openembedded recipes to an oe-core layer, and adjusting them to the new bitbake requirements.
      The new 3.0 images will come online in a few hours, the buildproces at our build server is running at the moment.
      There will be no new user features or real user changes, we just updated the build environment (update to openembedded-core).
      When the 3.0 images are at beta stage you need to reflash, you can not upgrade to 3.0 from earlier versions.
      Greetings,
      The OpenPLi team.""
    • Imam T90 antenu sa 8 LNB i Vu+ solo 2
      molio mi da mi netkoobjasni kako iskonfigururati toner i kako ubaciti emulatore
      već sam pokušavo ali mi ne ide
      i dalje koristim BH imafe jer sam se na njega navikao pa bi sad promjenio neki dergi
      jer su mi dosadili dopli meni i 100 put stiskanje tipke exit
      ,,Ostavite svaku nadu vi koji ulazite''
    • Re: OpenPLi 3.0: new alpha experimental images!
      Ubaci Openpli 4 i Bog da te vidi. Onda udji u Menu, pa u Plugins, pa na zeleno dugme pa udji u softcams i ubaci Oscam i izadji skroz.
      Zatim idi na plavo dugme i idi na softcam setup i ako već nije izabran oscam onda idi strelicama lijevo-desno dok se pojavi oscam i zatim dolje na Restart softcam.
      Kad sve to završiš javi se za dalje.
      Sent from my A536
      The post was edited 1 time, last by radja1 ().
    • Tuner podesavas kako su ti spojeni LNB-ovi po DiseqC sklopci.
      E1 - DreamBox 500s - Gemini v4.70 BackUp by SATmax
      E2 - DreamBox 800HD SE Sim2.10 SSL#84b - OpenPLi OE2.0 v4.0
      E2 - GigaBlue 800HD SE - OpenMIPS OE2.0 v4.1
      E2 - SkyBox F3s Full HD + GPRS
      _______________________________________________________
      Panasonic Viera Plasma PDP TV TX-P42CX3F
      Dream Sat LiveTV™ Android aplikacija
    • ako nisi voljan pomoći nema pogtebe za gomilanjem beskorisnih potova.
      Nisam ja u ovom hobiju od juče. Pitam za konkretne stvari koje mi ne sjedaju kako treba i za njih tražim konkretnu pomoć.
      Jer mi je sam image nov i prilično nepoznat.
      Zato možemo nastaviti dalje
      Freone onaj Mgcamd mi ne otvara polaris
    • Doticni mgcamd ukoliko imas sve svoje fileove u /usr/keys radi 1000%
      DDamir plugin kako kolega navodi ces morati skinuti s dadenog linka i kako sam naveo u mom predhodnom postu FTP programom ili preko Sambe rucno ubaciti.
    • ubaco damirov plugin i fercera za 10
      imam freone liniju koju sam ubacio u usr/keys i dodijelio prava 755 ali ne otvara polaris a tvojim mgcamom pa ću još mali istraživati sitaciju i vidjeti može li se namjestiti sve na jedan emulator
      na bh je to sve uredno radilo ali na tu "rupetinu" se ne vraćam potrošio sam jedan daljinski bespotrebno stiskajuć dugmad
      ovaj pli 4.0 je na prvu ruku odličan image
    • d@nte wrote:
      Satelite sam posložio i to mi radi
      Freone neće sa Mgcamd 1.38 polaris
      još mi svakao treba Damirov plugin
      a kako do njega ?
      DDamir subtitle player v4.01
      Sve mu obelezis i linkujes i jos dislike. Pa stvarno sta ti u stvari hoces? Znas li sam sta hoces?
      Ako ne znas da pretrazujes sajtove i net okani se tog hobija. Drugo to nije razlog na pitanje gde i kako da ubacim ddsuptitle player kada ti neko od clanova kao ja sazvace sve
      sa kritikom da treba da naucis nesto da lupas dislike zar ne?
      Samim tim cinom si dokazao da si prost malo je reci TUP
      A posto nisi u hobiju od juce i sve znas onda sam slozi mgcamd mislio sam objasniti zasto ne radi ali guslaj malo hobisto.
    • Rekli bi u mom kraju bolje je ispast gl*p nego iz autobusa.
      Toliko o tebi samo ti nastavi laprdat meni to ne smeta.
      Koristim priliku zahvaliti dvojici forumaša na PM.
      Na kraju je sad sve uspješno posloženo i uredno fercera, zahvaljujući dobroj duši i team viewer programčiću.
      Uspjeli smo podesiti da sve radi sa jednim emulatorom.
    • Nedostaje ti memorije u prijemniku. Oslobodi ili prebaci na USB stick plugina i sučelja.
      Poslano sa moje drvene skatule golubom pismonosom / Taubtalk3
