OpenAZBox PLi MOD Me Prerelease 3
    • OpenAZBox PLi MOD Me Prerelease 3
      OpenAZBox PLi MOD Me image is fully based on OpenPLi 2.1 Enigma 2
      Prerelease 3
      Kernel: Linux azboxme 3.3.1
      Enigma 2: 8. august 2012.
      Drivers: Sun July 1 14:22:38 CEST 2012
      Download:
      1. http://www.mediafire.com/?4yddtco55mchry6
      What is new (Bugfix list):
      1. ScanSetup: Fix forgotten declaration of postScanService master
      2. Behavior when a movie reaches the end can be configurab...
      3. Navigation: Make true selected reference default
      4. InfoBarGenerics: Use new getCurrentlyPlayingServiceRefe...
      5. ScanSetup: Use new getCurrentlyPlayingServiceReference...
      6. Navigation: Add option to getCurrentlyPlayingServiceRef...
      7. ServiceScan: Fix strange behaviour when scan from playi...
      8. ServiceScan: Derive infobar from session and fix a...
      9. New language files for the rename to 'receiver' and...
      10. change 'satellite receiver' to receiver'
      11. Make code general by renaming references to dreambox
      12. ScanSetup: ALso play postScanService with recursive...
      13. ServiceScan: Add to history when zapped to fresh scanne...
      14. ServiceScan: Play service later as tuner was still...
      15. ServiceScan: Also stop playing PIP before scanning
      16. ServiceScan: If services are found go to 'Last Scanned'
      17. InfobarGenerics: Fix swapPIP when channels are in diffe...
      18. frontend: work around missing DTV_ENUM_DELSYS
      19. frontend: obey preferred frontend setting for all types...
      20. Picon: Made the check for the alternatives a bit easier
      21. servicemp3: fix finding videosink element
      22. MultiEPG: At startup also jump to service that has...
      23. GraphMultiEPG: Use new alternative services tool
      24. Picon: Use new Alternative services Tool
      25. Add a tool for handling alternative services
      26. GraphMultiEPG: Make it compatible to alternative services
      27. Picon: Fix not appearing picon in GraphMultiEPG for...
      28. Navigation: Fix per accident removed newline.
      29. Navigation: Fix zapping along services with alternatives
      30. ChannelNumber: Better way to determain index in channel...
      31. New Slovenian language file
      32. update typo in cs.po
      33. GraphMultiEPG: Fix a cosmetic issue
      34. frontend: query and use delsys list
      35. GraphMultiEPGSetup: properly set screen title
      36. cosmetic: "enigma 2" -> "enigma2"
      37. GrpahMutliEPGsetup: cosmetic naming
      38. Swedish translations
      39. InfoBarGenerics: I missed the wierd ";" in my previous...
      40. Small tweaks to the selection of the default EPG type
      41. update cs.po
      42. pl.po: update translations
      43. de.po: Update German Translations
      44. GraphMutiEPG: refactor picon/channelname handling
      45. Add an extra option to select default EPG type to long...
      46. Add Current Event EPG to EPG Plugin List
      47. GraphMultiEPG: remove piconSize skin attribute
      48. GraphMultiepg: rationalize picon/servicename mode setting
      49. GraphMultiEPG: Change font for service name when only...
      50. GraphMultiEPG: Make one config regards picons/Servicenames
      51. Remember the EPG plugin/type selected by long-INFO
      52. GraphMultiEpg: allow background pictures for channel...
      53. GraphMultiEPG: Adjust to current service when zapped...
      54. GraphMultiEPG: Allow Multi EPG to change bouquet
      55. Navigation: Second try to fix, now check for Infobarins...
      56. GraphMultiEPG: Add access to multi service EPG
      57. Navigation: Fix crash when there is no servicelist
      58. GraphMultiEpg: Add access to single servie EPG
      59. GraphMultiEpg: Make datetext above picons shorter
      60. GraphMultiEPG: Force redraw of time entries when required
      61. GraphMultiEpg: Save space when only picons are displayed
      62. ChannelNumber: A better place to set the reference...
      63. ChannelNumber: Fix for services start by timer and...
      64. ChannelNumber: just a minor optimalization
      65. ChannelSelection: Fix for channelnumber when zapping...
      66. Revert "ChannelNumber: Remove not required code"
      67. whitespace, readability/indentation fixes
      68. ChannelNumber: Remove not required code
      69. ChannelNumber: Far more better way to save resourses
      70. Harddisk: blacklist ram devices
      71. fix whitespace errors
      72. ChannelNumber: Save some resources
      73. dvb: continue when the number of frontends does not...
      74. frontend: preset frontend details with fe_info
      75. fix whitespace errors
      76. ChannelNumber: Only number it when we are in a userbouquet
      77. ChannelNumber: Completely rewrite a new Renderer
      78. update po files
      79. GraphMultiEpg: Make "Zap" for red button translatable
      80. Revert "counting channelnumber from service reference...
      81. MoviePlayer: Leave movieplayer also with exit/esc key
      82. About: fix latest upgrade timestamp for OpenPli3.0
      83. Split long customize setup menu into three sub setup...
      84. picload cosmetics
      85. fix update in picload to actually fix the possible...
      86. genre converter: recode and return empty strings on...
      87. EventName converter: Add "All Ages" class to parental...
      88. GraphMultiEpg: allow background images for events boxes.
      89. picload: allow to resize without keeping aspect ratio
      90. own skin_user_skinname.xml
      91. ServiceList: Give python more controll over location...
      92. Ipkg: check /var/lib/opkg/status
      93. counting channelnumber from service reference not from...
      94. display sorting status in movieplayer with icon
      95. Add new MovieSelectionsList icons to the image
      96. playback status in movielist, Text button programeable too
      97. added playback in loop optional message added string...
      98. Genre and rating display updates.
      99. Add parental rating and content descriptors to epgcache
      100. UsageConfig: Add missing bracket introduced by previous...
      Display All
      Dreambox 8000
    • Postoji li neki svecani datum kada se ocekuje finalna verzija.Beta 2 radi odlicno pa je mnogo prakticnije odmah preci na finalnu verziju nego stalno flesovati nove bete pa na to jos pakovati svaki put plagine i emulatore.
      Da li ce buduci azplayer biti plagin kao dodatak ili sastavni deo imiga .
      4K UHD Android Smart TV Box:Amlogic S905/2GB/DVB-S2/DVB-T2/DVB-C/CA Slot/Oscam/Smart Home alarm Free 100 GB prostora za vase podatke: degoo.com/g/Ov7nAz0
      Pozdrav,
      Udjes u RTi Panel preko Z buttona na RCU, imas opciju Image Backup, gdje mozes odabrati sta zelis da backupujes, ubacis USB, sve ti snimi na isti, kasnije samo restoruješ.
      Dreambox 8000
    • NenadX wrote:
      Gledam update proceduru i nisu mi neki detalji jasni:
      1. Kaze da ga stavim na "Boot (0)". Jel moze na "Boot (1)?
      2. Stizu 3 fajle u paketu. image0.jffs2, update.ext i zbimage-linux-xload
      Ako zbimage-linux-xload stavim u .tar i posaljem ga na box preko weba, koja 3 fajla idu na USB?
      Nenade,
      zbimage-linux-xload, image0.jffs2 i update.ext odmah prebaci sada na USB. Zatim na računaru spakuj zbimage-linux-xload fajl sa 7zip-om u zbimage-linux-xload.tar. Ugasi resiver, upali ga i drži VOL+ tipku na daljinskom upravljaču. Kada se pojavi IP adresa, ukucaj je u web browser, odaberi BOOT 0, pronađi zbimage-linux-xload.tar file, klikni na upload, zatim na Flash.
      Kada je flash gotov, ubaci usb stick na kojem se nalazi zbimage-linux-xload, image0.jffs2 i update.ext ugasi resiver, pa ga upali i čekaj da ti se na TV-u pojavi Update GUI, odaberi BOOT 0 i sačekaj da se sve završi. Zatim odeš na dno i odabereš reboot, i kada si stisnuo OK na daljincu izvadiš taj USB.
      To je to!
      P.S: Evo okacio sam ti sliku u attachu da se bolje snadjes.
      Dreambox 8000
    • NenadX wrote:
      Kad sam tri put promislio, dosao sam do tog zakljucka, ali me muci taj BOOT0. Tamo mi je vec OpenRSI i nebi ga htio pogaziti.
      Moze li MOD na BOOT1?
      Preimenuj image0.jffs2 u image1.jffs2 i izaberi boot 1 kad fleshiras preko usb i ostat ce ti rsi na boot 0 a taj image na boot 1 i radit ce ti oba ali samo pod uvjetom da koriste isti kernel
      Dreambox 600 ,VU+ Uno,VU+ Solo2
      Svejedno, OpenRSi radi na starom kernelu (2.6.22) te kada ubaciš Open AZBox MOD koji radi na kernelu 3.3.1 svakako nećeš moći bootati OpenRSi. Uostalom OpenRSi je po meni jako loš u odnosu na Open AZBox MOD koji je čisti PLi image za AZBox Me i ostale modele.
      Dreambox 8000
      Sta je s Aztrinom? Zar nebi trebalo biti moguce koristiti 3 razlicita sistema, svaki na svojoj BOOT particiji?
    • OpenRSI ima tri beta verzije sa kernelom 3.3.1 tako da ovisi koju on ima verziju sa starim ili novim kernelom
      Aztrino 2.0 takodjer koristi kernel 3.3.1 pa ako sva tri koriste isti kernel radit ce sva tri
      Kernel fleshiras samo jedanput na bilo koji boot
