Oscam
      • 2018/01/24 17:02:02 0776223D c (dvbapi) PMT6: Trying connect to enigma CA PMT listen socket...
      • 2018/01/24 17:02:02 0776223D c (dvbapi) PMT6 CA PMT Server connected on fd 18!
      • 2018/01/24 17:02:07 0776223D c (dvbapi) Demuxer 0 ecmpid 0 CAID: 4AEE ECM_PID: 0C55 PROVID: 000000
      • 2018/01/24 17:02:07 0776223D c (dvbapi) Demuxer 0 found 1 ECMpids and 2 STREAMpids in caPMT
      • 2018/01/24 17:02:07 0776223D c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 0
      • 2018/01/24 17:02:07 0776223D c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 4AEE PROVID 000000 ECMPID 0C55 ANY CHID PMTPID 08CB VPID 08C9
      • 2018/01/24 17:02:07 0776223D c (dvbapi) Demuxer 0 found 1 ECMpids and 2 STREAMpids in PMT
      • 2018/01/24 17:02:07 0776223D c (ecm) user (4AEE@000000/0000/01D4/4F:730CDD8C26E219FB8F5DC52A7BDEE1FD): found (78 ms) by XY(P/4/4/4) - PRVA
      • 2018/01/24 17:02:09 0776223D c (ecm) user (4AEE@000000/0000/01D4/4F:BE43D34279E2C53A5AAF028CFCEBD002): found (204 ms) by XY (P/4/4/4) - PRVA
      • 2018/01/24 17:02:19 0776223D c (ecm) user (4AEE@000000/0000/01D4/4F:129598D5B358510B63F2AFEA06006B8F): found (272 ms) by XY (P/4/4/4) - PRVA
      • 2018/01/24 17:02:29 0776223D c (ecm) user (4AEE@000000/0000/01D4/4F:B3FAC73E60B53D3BADCB3E353A9342EC): found (213 ms) by XY (P/4/4/4) - PRVA
      • 2018/01/24 17:02:39 0776223D c (ecm) user (4AEE@000000/0000/01D4/4F:D82FF63D798DC8416F3DB670D4714FB9): found (205 ms) by XYl (P/4/4/4) - PRVA
      • 2018/01/24 17:02:49 0776223D c (ecm) user (4AEE@000000/0000/01D4/4F:FA6709859F293432FBB86D34B3C353B3): found (224 ms) by XY (P/1/2/4) - PRVA
      • 2018/01/24 17:02:59 0776223D c (ecm) user (4AEE@000000/0000/01D4/4F:755C20AACAA9FF152E95278C5227B4A3): found (234 ms) by XY (P/1/2/4) - PRVA
      Kod mene toga nema :)
      Ako ovoga nema u logu - onda u oscam.conf staviti
      pmt_mode = 0
      Stvar rijesena ;)
    • Evo posle ubacivanja extended_cw_api=0...
      (Hvala Zox) :)
      • 2000/01/01 01:02:13 1F9B8C36 c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 0
      • 2000/01/01 01:02:13 1F9B8C36 c (dvbapi) Demuxer 0 trying to descramble PID 0 CAID 4AEE PROVID 000000 ECMPID 0C58 ANY CHID PMTPID 08E0 VPID 08DE
      • 2000/01/01 01:02:13 1F9B8C36 c (dvbapi) Demuxer 0 found 1 ECMpids and 2 STREAMpids in PMT
      • 2000/01/01 01:02:13 1F9B8C36 c (ecm) user (4AEE@000000/0000/01D7/4F:69611F63AEF6009C9D98E55A1FF52E00): found (73 ms) by XY (P/6/6/6)
      • 2018/01/24 18:19:20 1F9B8C36 c (ecm) user (4AEE@000000/0000/01D7/4F:12E30C8CDAD827673D7E63725CE2EF21): found (425 ms) by XY (P/6/6/6)
      • 2018/01/24 18:19:30 1F9B8C36 c (ecm) user (4AEE@000000/0000/01D7/4F:31DCDB0532761F3DDCD321C93950036F): found (354 ms) by XY (P/6/6/6)
      • 2018/01/24 18:19:40 1F9B8C36 c (ecm) user (4AEE@000000/0000/01D7/4F:14FE42A0553D1C20289E5B20BA54B1A9): found (304 ms) by XY (P/6/6/6)
      • 2018/01/24 18:19:50 1F9B8C36 c (ecm) user (4AEE@000000/0000/01D7/4F:6AA1C25BB0B75D8AB0A1C899C8957495): found (370 ms) by XY (P/6/6/6)
      • 2018/01/24 18:20:00 1F9B8C36 c (ecm) user (4AEE@000000/0000/01D7/4F:93501D33E0D600CFE061C87D754AF4F4): found (276 ms) by XY (P/6/6/6)
      • 2018/01/24 18:20:10 1F9B8C36 c (ecm) user (4AEE@000000/0000/01D7/4F:6E0DD5D49E175BD9780E48CC43EC97AE): found (320 ms) by XY (P/1/2/6)
      Gebertini 150cm 91.5E-45W..SuperMount SMR1224EL.. BG
    • Sad mi cudno nesto.. vratio extended_cw_api=1 resetovao totalno..
      Diskaveri i dalje ne radi...
      -Menjali su kljuceve, ja ubacio, nisam video dal je radilo pre promene...
      Dal su kljucevi losi.. AFN radi... opet restart Diskaveri ni da cuje... pise emulator (0.027s ) a slike nema.. :S
      • 2018/01/24 19:10:11 6A1D8715 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
      • 2018/01/24 19:10:11 6A1D8715 c (-) -- Skipped 1 duplicated log lines --
      • 2018/01/24 19:10:11 6A1D8715 c (ecm) user (0E00@000000/0000/0514/40:5D87EAACB09F10751D483082A348BB06): found (30 ms) by emulator (L/1/3/3)
      • 2018/01/24 19:10:12 6A1D8715 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
      • 2018/01/24 19:10:12 6A1D8715 c (-) -- Skipped 1 duplicated log lines --
      • 2018/01/24 19:10:12 6A1D8715 c (ecm) user (0E00@000000/0000/0514/40:5D0F0FA83A7300CA80D676FCD85FB09F): found (30 ms) by emulator (L/1/3/3)
      • 2018/01/24 19:10:13 6A1D8715 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
      • 2018/01/24 19:10:13 6A1D8715 c (-) -- Skipped 1 duplicated log lines --
      • 2018/01/24 19:10:13 6A1D8715 c (ecm) user (0E00@000000/0000/0514/40:C41A93F89D8F124A66C06D0904C35E96): found (31 ms) by emulator (L/1/3/3)
      • 2018/01/24 19:10:14 6A1D8715 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
      • 2018/01/24 19:10:14 6A1D8715 c (-) -- Skipped 1 duplicated log lines --
      • 2018/01/24 19:10:14 6A1D8715 c (ecm) user (0E00@000000/0000/0514/40:DDB66C5D9B97642C6C9B747BB24D39F3): found (30 ms) by emulator (L/1/3/3)
      • 2018/01/24 19:10:15 6A1D8715 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
      • 2018/01/24 19:10:15 6A1D8715 c (-) -- Skipped 1 duplicated log lines --
      • 2018/01/24 19:10:15 6A1D8715 c (ecm) user (0E00@000000/0000/0514/40:6A0CFE39BACD8150CB25ACA6783180C7): found (31 ms) by emulator (L/1/3/3)
      • 2018/01/24 19:10:16 6A1D8715 c (dvbapi) ERROR: ioctl(CA_SET_DESCR_MODE): Invalid argument
