Oscam
    • @dxdy, hvala puno na pomoći i vremenu, što si ga odvojio. Zaista si Veliki Jack! Mislim da možeš biti za primjer, kako se stvarno treba ponašati prema onima, koji trebaju nečiju pomoć.
      DVB-S2/DVB-T2/C
      74,9E do 45,0W
    • jel netko moze poslat javno ili privatno na poruku, gdje je oscam konfiguriran da otvara discovery power vu na thoru i na 4,8e
      ovo sto imam otvara AFN na 9e
      [reader]
      label = AFN
      protocol = emu
      device = Emulator
      services = afn
      cacheex = 1
      cacheex_maxhop = 1
      cacheex_allow_request = 1
      caid = 0E00
      ecmwhitelist = 0E00:91
      detect = cd
      group = 1
      emmcache = 1,5,31,1
      emu_auproviders = 0E00:000000
      auprovid = 000E00
      ako ovime krsim pravila foruma nek se post obrise, a ako mi netko na privatnu poruku moze napisati sta treba discovery kanale u power vu na thoru i 4,8e
    • Po X-ti put!
      [reader]
      label = emulator
      protocol = emu
      device = emulator
      caid = 0D00&0F00,090F,093E,0500,1801,0604,0648,0D98,0650,0D95,0D02,0E00,1FFF,2600,4AE1,1010
      detect = cd
      ident = 0D00:000000,000004,000010,000014,000020,0000C0,0000C4,0000C8,0000CC;0D02:000000,00008C,0000A0,0000A4,0000A8;090F:000000;0500:000000,030B00,023800,021110,007400,007800;1801:000000;0604:000000;2600:000000;FFFF:000000;0E00:000000,000002;1010:000000,030B00,023800,021110,007400,007800;1801:000000,001101;0604:000000;2600:000000;FFFF:000000;0E00:000000;4AE1:000000;1010:000000,FFFF000;0D95:000000
      group = 1,2,3,4,5,6,7,8,9
      blockemm-g = 1
      [reader]
      label = constant.cw
      protocol = constcw
      device = /etc/tuxbox/config/oscam/constant.cw
      [reader]
      label = AFN
      description = AFN-EMU
      protocol = emu
      device = Emulator
      cacheex = 1
      cacheex_maxhop = 1
      caid = 0E00
      detect = cd
      emmcache = 1,5,31,1
      auprovid = 000E00
    • jednostavno neki receiveri ne otvaraju discovery a otvaraju AFN.... kod nekih pali fora sa service pa onda AFN i Discovery rade, kod nekih ne.... izgleda da je to samo problem u imageu kao što je npr na VU+ problem sa BISS kanalom EFB1... u biti dekodira kanala a ne pokazuje sliku a to se lako preko VLC vidi...
    • ma možeš ga ti postavati i na glavu ali jednostavno neki receiveri neće pa neće.... lako je ovako na internetu djeliti savjete ali probaj složiti koji problematični... i ja sam ovako ka ti mislio jer na većini na kojima sam slagao je radilo bez problema.... ali ima par modela koji neće pa neće što god mijenjao confige i druge stvari...
    • Ma razumijem ja tebe - nije nesporazum.
      Znam da ima XY recivera i da bi svi gledali sto je vise moguce...
      Ono sto ti i ja postavljamo radi (10000%) provjereno na Dreamboxovima i na podrzanim Vu+ reciverima.
    • djakac65 wrote:
      al ovi drugi na 4,8 i 0,8 i 13 idu al samo ako se restarta box i tako prilikom povratka
      Restartao ja risiver sto puta i ništa od toga.
      BTW: A o čemu se zapravo radi na 13E? Oprostite mojoj needuciranosti. Hvala.
      DVB-S2/DVB-T2/C
      74,9E do 45,0W
    • ma on mora cam resetirati a ne box.. npr gleda discovery i sad prebaci na KŠ ili neki drugi paket pa ne otvara... i onda mora resetirati cam da bi proradilo... znalo se to i meni nekad događati nakon puno kopanja i instaliranja raznih camova... reset na tvorničko i friško cam instaliran mi je uvijek riješilo taj problem
    • djakac65 wrote:
      a na 13 e rade powervu kanali UNIRE i SNAI tv kanali
      A na kojim su to frekvencijama? Hvala puno.
      DVB-S2/DVB-T2/C
      74,9E do 45,0W
    • Meni ove Talijane na 16E ne otvara niti Ncam niti Oscam. AFN ide "normalno", a Discovery na 4.8E i na 1W isto tako NE.
      DVB-S2/DVB-T2/C
      74,9E do 45,0W
