Oscam
    • reader za karticu sam već stavio u konfiguraciju.... da li ti ga čita?
      [reader]
      label = Card_reader_1
      protocol = internal
      device = /dev/sci0
      caid = 0500
      detect = cd
      mhz = 450
      cardmhz = 2700
      group = 2
      emmcache = 1,2,2,0
      read_old_classes = 0
      pogledaj sliku, da li ti piše CARDOK (4 entitlements) ili Error ili no card?
    • ja stavim na HRT 2, treba negdje oko minute da autorizira... mislim da imam negdje još jednu neautoriziranu karticu, budem ju stavio pa pokažem log...
      edit, ništa od nje, error mi izbacuje ali sa ovom što sam screenshot napravio uvijek digne autorizaciju
      • 2018/02/07 20:59:45 7FAEC220 r (reader) Card_reader_1 [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [internal] type: Viaccess (standard atr), caid: 0500, serial: ##########
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [internal] providers: 6 (FFF4A0,020A00,020A10,020A20,020A30,020A40)
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [internal] Maturity level [F]=no age limit
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [internal] ready for requests
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [internal] found card system viaccess
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [viaccess] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [viaccess] card detected
      • 2018/02/07 20:59:47 7FAEC220 r (reader) Card_reader_1 [viaccess] serial: ##########
      • 2018/02/07 20:59:48 7FAEC220 r (reader) Card_reader_1 [viaccess] provider: 1, id: ####################, sa: ########, geo: empty
      • 2018/02/07 20:59:48 7FAEC220 r (reader) Card_reader_1 [viaccess] provider: 2, id: #################, sa: ########, geo: FF FF FF FF
      • 2018/02/07 20:59:48 7FAEC220 r (reader) Card_reader_1 [viaccess] class: 04, expiry date: 2018/02/01 - 2018/02/28
      • 2018/02/07 20:59:48 7FAEC220 r (reader) Card_reader_1 [viaccess] class: 03, expiry date: 2018/02/01 - 2018/02/28
      • 2018/02/07 20:59:49 7FAEC220 r (reader) Card_reader_1 [viaccess] class: 02, expiry date: 2018/02/01 - 2018/02/28
      • 2018/02/07 20:59:49 7FAEC220 r (reader) Card_reader_1 [viaccess] class: 01, expiry date: 2018/02/01 - 2018/02/28
      • 2018/02/07 20:59:49 7FAEC220 r (reader) Card_reader_1 [viaccess] provider: 3, id: #####################, sa: ########, geo: FF FF FF FF
      • 2018/02/07 20:59:49 7FAEC220 r (reader) Card_reader_1 [viaccess] provider: 4, id: #######################, sa: ########, geo: FF FF FF FF
      • 2018/02/07 20:59:49 7FAEC220 r (reader) Card_reader_1 [viaccess] provider: 5, id: ##########################, sa: ########, geo: FF FF FF FF
      • 2018/02/07 20:59:50 7FAEC220 r (reader) Card_reader_1 [viaccess] provider: 6, id: #############################, sa: ########, geo: FF FF FF FF
      • 2018/02/07 20:59:50 00000000 s (main) init for all local cards done
    • jel bitan image, od svih kanala radi mi samo na 1,9 bih arenasport, afn i 1w discovery PWU ide ECM nema slike
      openpli 6.1 na vuuno a na dreambox pli4.0 ista stvar je na oba, probo sve configove sa teme isto mi uvijek
      DM7020HD
      gibertini OF105
      Inverto Black Ultra HG single
      i motor Strong SRT DM-2100
      >A journey of a thousand miles begins with a cash advance<
    • samo dodaj u emulator reader liniju
      services = !afn
      prošla stranica napisao sam o tome. ili dodaj tu liniju u svoj emulator reader ili koristi config fajle koje sam stavio na prošloj stranici samo onda ne koristiti ovu liniju services = !afn
    • Kod mene na Octagonu sf4008 ponekada ide samo ton, slika nikada. Što da uradim? Hvala puno.
      DVB-S2/DVB-T2/C
      74,9E do 45,0W
      na VU+ je bitno jedino da su zadnji driveri iz 12. mjeseca (4.12.2017)
      no na nekim VU modelima (uno, solo) iz nekog razloga emulator i AFN reader si međusobno smetaju, zato treba podesiti u readeru jednog da isključi drugog preko services... openATV i openBH isprobano. duo2 npr nema tog problema...
      i stavi si oscam za openpli verziju 11398 ili 11399
    • tmurgel1 wrote:
      dvlajkovic wrote:
      Kolega @dxdy, mislim da kolega @tmurgel1 nema umrežen sat-prijemnik, tako da mora prvo da reši umrežavanje.
      Pa sigurno od tu idu svi problemi. Kako da pretumačim sebi da to ne ide ni kabelom ni UBS WIFI stickom!?! Istina je da nikada nisam imao enigma receiver, ali ipak ne kontam, što radim naopako. Pomalo me ova situacija izluđuje. Svima, koji ste dobrovoljni i spremni pomagati, hvala od srca.
      Evo, malo kasno, ali od srca. Nisam uspio u LJ naći pravi USB stick. Poslao mi ga jedan frend iz HR. Umrežio sam risiver pomoći sticka. Čitajuči ovu temu nisam uspio skužiti, kako da aktiviram SLO karticu. A volio bi i da gledam AFN programe na 9E. U octagonu imam OpenATV 6.2 i koristim Ncam i Oscam. Ima li neka dobra duša da mi preko teamviewera sredi te stvari? Hvala puno.
      DVB-S2/DVB-T2/C
      74,9E do 45,0W
