OpenAZBox PLi MOD MiniMe Release - 1 -
    • OpenAZBox PLi MOD MiniMe Release - 1 -
      Enigma 2 of 15. november
      Kernel 3.5.5
      What is new:
      - Fixed khdmi issues on all models
      - Fixed i2c issues on all models
      - Fixed "tune" problems on Ultra and Premium+
      - Fixed blindscan in Premium+, Ultra, Me and MiniMe
      - SPDIF Enabled
      - Added AC3/DTS downmix Yes/No switch in A/V Settings (all models)
      - Fix and additions in AZPlay:
      Add scalling
      Add Audio lang. sel
      Add Subtitle lang. sel
      Add set volume/mute after switching
      Add right filter for extension
      extended window , now you can see more info (large names od files)
      Increase font size to max 90
      change way to show parameters in setup menu - now all is sorted
      STOP command now completly close player and jump to filelist
      Fix BUG - show prev. subtitle if you use more then one video
      Add : mts extension
      Add : ac3 extension
      Add change value from setup menu in real time
      Fix BUG - Green screan , when you doenst setup tuners
      Fix problem with changing parameters (fix in rmfp_player)
      Add - show infobar when play ts , mts, ac3 files - without time info/index
      What is comming next:
      - USB DVB-T Support (all models)
      - AzIPTV (Fully based on AZPlay, better compatibility with all kind of streams)
      - CI Support (OLD models)
      Download:
      http://www.mediafire.com/download.php?qrepckee91jc3dc
    • OAM Team je objavio fix-eve za uočene probleme:
      • Fix for switching different resolutions
      • Fix for AC3/DTS downmix on Satellite, Terrestrial and Cable channels
      Potrebno je pokrenuti Menu -> Setup -> Software Update
      i onda odabrati prvu opciju, pričekati da se odradi online update i nakon toga Azbox će se sam restartati.
