Pinned LAV Filters NEW - sve nove verzije
    • LAV Filters 0.63.0 (released 2014/10/03)
      LAV Splitter
      - NEW: Support for playing AES encrypted HLS streams
      - NEW: Advanced Subtitle selection allows selecting subtitles by a string match on the stream title
      - NEW: Support for rtspu, rtspm, rtspt and rtsph URLs to force the RTSP transport protocol
      - NEW: Animated GIF image support
      - Fixed: Improved timestamp handling of badly muxed/corrupted H.264 streams
      - Fixed: 4K ProRes streams in MKV didn't play reliably
      - Fixed: Some HEVC streams in MKV/MP4 didn't play properly
      - Fixed: VobSubs in MP4 didn't properly export their color palette
      - Fixed: Streaming MP3s through the Microsoft URL filter could result in the last audio frame to be partially repeated
      - Fixed: The duration of MP3 files would be wrong if it contained long IDv3 tags
      - Fixed: TrueHD streams with an Dolby Atmos sub-stream were not demuxed properly
      LAV Video
      - NEW: Experimental support for CUVID and DXVA2 HEVC acceleration
      - Faster: HEVC decoding is up to 100% faster
      - Fixed: DVD subtitle rendering could crash in 64-bit builds
      LAV Audio
      - Fixed: TrueHD streams with an Dolby Atmos sub-stream did not decode​
      ♫ U tako malo nota reći toliko.
    • Latest version:
      0.64.0 (February 13, 2015)
      - NEW: Individual LAV Filters can now be blacklisted through the registry by creating a key with the executable name in HKCU\Software\LAV\<Filter>\Blacklist
      LAV Splitter
      - NEW: Support for RTMP using rtmpdump-style parameter syntax
      - NEW: Support for Opus-in-TS
      - Fixed: The language reported for audio/subtitle streams on some Blu-rays could be wrong
      LAV Video
      - NEW: HEVC Main10 decoding in DXVA2 Copy-Back mode
      - Faster: DXVA2 Copy-Back in direct output mode uses up to 50% less CPU and performance is improved accordingly
      - Fixed: H.264 streams with only DTS timestamps would play out of sync with DXVA2
      - Fixed: DXVA2 could crash on some MPEG-2 streams
      - Fixed: Improved compatibility with a few HEVC streams when using DXVA2
      Download LAV Filters 0.64.0 (direct link) (8.3MB)
      Download LAV Filters 0.64.0 portable
      Download LAV Filters 0.64.0 portable 64-bit
    • 0.65.0 - 2015/04/21
      LAV Splitter
      NEW: Support for MKV subtitle Cues to show subtitles immediately after a seek
      NEW: Attachments and embedded cover art images are exported through the IDSMResourceBag interface
      Fixed: Improved demuxing of HEVC in MPEG-TS and increased the reliability of the SPS/PPS/VPS extraction
      Fixed: Demuxing Blu-rays/MPEG-TS where the first stream was not a video stream could result in broken timestamps
      Fixed: Seeking in MKVs which are currently being written is more reliable
      LAV Video
      Fixed: Improved HEVC DXVA2 decoding on a few samples
      Fixed: Playback of VFR MPEG-4 in AVI had wrong timestamps in 0.64
      Fixed: Improved handling of DVD subtitles without timestamps
      LAV Audio:
      NEW: Native DTS-HD decoding using libdcadec
      Changed: 5.1 audio prefers the speaker mask with side channels, to match recent specifications
      Downloads
      LAVFilters-0.65-Installer.exe
      LAVFilters-0.65-x64.zip
      LAVFilters-0.65-x86.zip
