DVBViewer Pro
    • To se jedino dešava kad se SVE ne očisti od predhodne instalacije.
      DVBViewer Pro 4.9.5
      Windows XP/Vista/Windows 7
      Activated. Just CLEAN install (as Administrator) and use.
      READ THIS:
      CLEAN installation is BEST if you have a previous version of DVBViewer installed:
      Completely uninstall any previous DVBViewer software...
      or:
      Delete the Registry key avec regedit.exe :
      HKEY_LOCAL_MACHINE\SOFTWARE\CM&V
      Delete all of these folders:
      C:\ProgramData\CMUV
      C:\Program Files\DVBViewer
      C:\Program Files\Common Files\DVBViewer Shared
      C:\Documents and Settings\All Users\Application Data\CMUV
      DVBViewer Pro 4.9.5
      READ THIS:
      or:
      C:\ProgramData\CMUV
      ma jok,nece pa nece,vratio sam se na 4.5....
      2X VU+ZERO
      Fuba 90 cm dish
      39.0 E-28 E-23.5 E-19 E-16 E-13 E
      Centar 19 E
    • Hame wrote:
      fantom wrote:
      To je trenutno predzadnja verzija. Najnovija trenutno je 5.0 licencna.
      Ma kakvi "predzadnja", bile su još tri posle nje a prije aktuelne petice (4.9.6, 4.9.6.11 i 4.9.6.20).
      Da ali i neke bete na mesec dana sto ne smatram verzijom.
      nix.rs wrote:
      Ja se vratio na 4.5 kod mene ova nova,ne radi kako treba.... a i dok je radila,nisam video neku razliku.... :)
      Nisi pratio uputstva za deinstal tj video snimak i program za deinstal.
      Ne znam kako niste videli promene pa citajte sta je promenjewno od v 4.5 nije bitno menjanje interfejsa i sminkanje vec ispod haube/
      We have released the new DVBViewer Pro 4.6 today.
      ATTENTION: You can download the DVBViewer Pro 4.6 only from dvbviewer.tv/members/
      We introduced a new protection system with Version 4.5, if you haven't already got the new user credentials please read also: dvbviewer...ew-credentials/
      Mit der Version 4.5 wurde ein neues Benutzerdatensystem eingeführt, wer die neuen Daten noch nicht hat bitte unbedingt hier lesen: dvbviewer...-benutzerdaten/
      The changelog:
      General
      Reworked: Start-up: Completely reworked the start-up sequence of the DVBViewer.
      Add: Shader menu: Added a new menu item: "Last Shader". This recalls the last used shader.
      Add: Actions: "No Shader" and "Last Shader" actions added. See actions.ini.
      Fix: WOL: Fixed a potential memory leak if no network was present.
      Change: Reworked the status messages of the splash screen.
      Change: Reworked the about window.
      Fix: Input Options: Export only user defined commands didn't work.
      Fix: Channel Scan: A corrupt PAT could cause problems in some situations. (fixed by Griga).
      Fix: A docked channel list window was not brought to front together with the main window.
      Fix: EPG Window: Reworked the tab order.
      Fix: Recording Stats window: A running recording in the recording service wasn't shown under certain circumstances.
      Fix: Unicode: Fixed several problems with Unicode and timers.
      Reworked: Recording Stats window: Reworked the display of the recording stats window.
      Fix: Options window: Cleaned up the tab order in the options.
      Add: Configuration files: The configuration (xml) files are now first saved to a temporary file and then renamed to the actual file name. This should prevent corrupt files if the PC crashes on writing.
      Add: Subtitles: Christian added support for ISDB subtitles.
      Add: Recording window/ EPG window: Added an improved time entry component by griga.
      Fix: Instant recordings: Instant recordings are not saved to the timers.xml and not added to the scheduler anymore.
      Fix: Streaming renderer: Christian fixed some bugs in recordings of streaming content.
      Fix: Custom Renderer: Fix for wrong aspect ratio when zooming with the custom renderer.
      Fix: Channel Autoupdate: Fixed several problems with the auto update for LiveTV and recordings.
      Fix: Forced channel switch by recording service: If a channel switch is forced by the service and UseFav is set to 1, the DVBViewer tries to find a fitting favorite. This may or may not work.
      Fix: Options window: Several usability and optical improvements.
      Fix: Channel editor window: Setting the LOF for a root entry didn't work.
      Fix: Recording info file: Reading the recording info file didn't work if no title was present. In this case the filename is now used.
      Change: Several optimizations for the D3d renderer.
      Fix: Fixed the worst problems with font sizes > 100% in Vista/Win 7.
      Fix: Fixed problems if the screen saver timeout is set to one minute.
      Fix: Fixed the DVBViewer main window doesn't have the focus after start.
      Add: Recording Stats window: If deleting a running timer a warning/confirmation dialogue is now shown.
      Updated the DVBSource Filter to version 3.5.4.
      Updated to current sqlite3 version.
      Several corrections and optimizations.
      Language files updated.
      Hardware
      Add: Grigas new hardware detection integrated. Please do a manual hardware search in the hardware options!
      Fix: In some cases the DiSEqCCount parameter wasn't initialized correctly.
      Fix: The IPTV Client device can now detect and ignore extended RTP headers (> 12 byte).
      Add: BDA Hardware: Support for Geniatech devices ( DiSEqC and DVBS-2).
      Fix: For Digital Devices devices the unicable button is now displayed in the hardware options.
      Add: The Digital Devices devices handling detects if Unicable is activated in the driver. If it is activated it discards the internal unicable handling.
      Add: Basic support for DVB-T2.
      Fix: DiSEqC didn't work for Anysee devices.
      Change: *star devices: Lowered the Tunerlock-Timeout for B2C2-based cards with WDM-drivers from 2 seconds to one second.
      Removed: BDA devices: Removed the Tunerlock-Timeout for FireDTV-devices.
      Add: BDA devices: Added CI support for KNC One DVB-S2 Dual cards. Attention: MMI/CAM Menu does not work, there seem to be problems with the driver and/or SDK dll.
      Warning: Users with KNC One devices should use the current driver!
      OSD
      Change: OSD main window: OSD-Yellow displays the channel list or the favorites list based on the UseFav tweak.
      Add: Datamanager: #CurrentShader contains the currently used shader.
      Add: Datamanager: The Last Shader name is now stored in the OSDDatamanager under "#LastShader". To change the shader via script you can change the value to a valid shader name and call the Lastshader action.
      Change: Weather OSD: The images are now forced to keep the aspect ratio.
      Fix: OSD Slide show: The Slide show was not stopped, if a playback via menu was started.
      Fix: OSD Slide show: Blending transition of the images didn't work.
      Add: OSD main window: With OSD-Blue you can open the shaders menu (if custom renderers are used).
      Playback
      Fix: Drag and drop of playlists onto the DVBViewer icon didn't work.
      Fix: Shoutcast: Christian fixed problems with shoutcast in the VODFilter.
      Add: File playback: Files with the TS4 extension are now handled as TS stream.
      Add: The DVBViewer handles link files to media files or folders via drag'n'drop or command line.
      Fix: DVD playback: On DVD playback timeshift was stopped without asking/warning the user.
      Recording service related
      Add: Now you can download the favourites.xml from the service on start up. See Service options in the options window. (needs the current service 1.6.8.2+).
      Add: Service Options: You can download the favorites in the service options with the favorites button (needs the current service 1.6.8.2+).
      Add: Service Options: You can activate sending WOL to the PC with the recording service on start up.
      Add: Service Options: You can define the wait time for WOL. It defines the maximal wait time the DVBViewer will pause until he can contact the recording service. Default is 2 minutes.
      Attention: The DVBViewer will block the defined time if the recording service is not running or the PC takes too long to wake up. If it fails to contact the recording service all following downloads (EPG, channel list, favorites etc) will fail!
      Add: Service Options: You can initiate WOL with the WOL button in the service options.
      Removed: The background EPG download from the service. (needs the current service 1.6.8.2+).
      Removed: Service Options: Remove the max days EPG download. The EPG will now be downloaded in one go in binary form.
      DVBServer
      Please see hardware changes for the DVBViewer for more information.
    • Changelog DVBViewer Pro 4.6.0.1 Hotfix
      General
      Fix: The Splash screen collided with the wizard.
      Fix: IPTV device: The detection of extended headers could lead to dropped packets.
      Fix: Subtitle-Options: Fixed and improved the language selection of Subtitles.
      Fix: VCR: Under certain circumstances an instant timer was send to the scheduler.
      Fix: BDA devices: Fix for more than one CI filter in the BDA graph for Digital Devices devices.
      ATTENTION: You can download the DVBViewer Pro 4.8
      General
      Change: Teletext Subtitles: The language of TTx subtitles is now detected by examining the PMT. This should result in a more accurate detection than before. Thanks @Griga.
      Add: Subtitles : Added support for Arib8 (Japanese) subtitles.
      Change. Favorites: Changed to the 64bit Favorites ID as used in Grigas GE and the Recording Service. The old IDs will still work.
      Change: Options channels (Sky Germany): Changed the way how the options channels are detected. Now the list of the channels can be opened if you have tuned a active option channel. No need to tune the portal channels first.
      Change: Options channels (Sky Germany): If a options channel is not found in the DVBViewer channel list, it will not be shown in the options channel list anymore, instead a entry about the missing channel is written to the log files.
      Fix: EPG HTML Export: The event wasn't exported.
      Fix: Problems with W2k : The DVBViewer work again with W2k.
      Fix: Wizard : The check for the D3D support dll is now executed in the wizard.
      Fix: Installer : The sample jumplist.ini wasn't installed.
      Add: Timeshift : H.264 Filler data removal added, can be activated in the timeshift options. Careful, this can make the jumping in timeshift less accurate.
      Fix: GUI Skins : The translation didn't work correctly, if started in GUI Skin mode.
      Change: Teletext Options : Now only valid fonts can be selected in the TTx options.
      Change: Teletext Options : Added support for Arabic, Serbian (Cyrillic) and Ukrainian charsets.
      Change: Teletext : Added support for the Nation Option Bits to detect the charset of a page. Sometime the bits are not unique then you have to adjust the settings in the Teletext options manually.
      Removed: Teletext : Removed the Language popup menu.
      Change: Subtitle Options : Now only scalable fonts can be selected.
      Change: Mosaic Options : Now only scalable fonts can be selected.
      Add: Languages : The DVBViewer now tries to detect and use the windows user language on first start.
      Fix: DVBSpeak.vbs should work again.
      Hardware
      Add: BDA Devices: Support for Turbosight CI . You need to install the TBS support dll with the downloader at the end of the installation.
      Add: BDA Devices: Support for Anysee E7 series with CI.
      Add: BDA Devices: Griga added DiSEqC support for Omicom devices.
      Add: BDA Devices: Added detection of the Digital Devices Cine S2 V6 .
      Add: Hardware detection : Support for variations of Digital Devices Octopus, Terratec Cinergy 1200-S and Terratec Cinergy S added.
      Add: BDA Devices : Added support for RealTek DVB-T/C Hybrid USB devices.
      Improved: DVB-IPTV Device : Optimized and improved by Griga. It should now handle extended RTP Headers correctly.
      Fix: BDA Devices : For TT devices the Unicable settings were not shown in the hardware options.
      Add: BDA Devices : Added detection of the Technisat Skystar eXpress HD.
      Change: BDA Devices: Several Hauppauge devices were wrongly detected as hybrid devices.
      Add: BDA Devices: Added support for Qbox 3 devices.
      Windows
      Fix: Channel List Editor : The automatic scrolling on moving an entry didn't work anymore.
      Change: Favorites Menu Main window: Favorites entries which can not be associated with a channel are shown deactivated.
      Change: Recorder Window : Clicking on a timer selects the associated channel in the channel list on the left.
      Change: About window : Completely reworked.
      Fix: Recording window didn't close on pressing ESC.
      Change: EPG window : The EPG search now defaults to „from now“.
      Fix: EQ Window : Rearranged the text a little bit, so it is not cut off anymore.
      Change: Channel List Editor : If the channel list editor is opened from the channel list window, the currently focused channel is selected in the channel list editor.
      Add: Recording statistic window . Added the removed Filler data amount display (only if active).
      Fix: Recording Stats window : Fixed some translation problems.
      Change: Channel list editor: If a channel is moved in the channel list, the detail view is now updated correctly with the new root/category.
      Change: Channel list editor : Changed the label “Service PID” to “Service ID” (English/German language file).
      Recordings/Timer
      Add: Recordings : Optional removal of H.264 filler data while recording. (see recording options).
      Thanks to forums user Martin K for contributing the concept and code and to Griga for adapting it to the DVBViewer!
      Some (not all) HD channels, particularly Das Erste HD, ZDF HD, arte HD and ORF HD, are inserting filler data in the H.264 video stream in order to keep a constant bitrate. The percentage of filler data depends on the broadcasted content. E.g. in low motion scenes 50% or more of the H.264 stream may consist of filler data, and in case of movie opening or closing titles even more than 90%. So removing the H.264 filler data may decrease the size of TS recordings with H.264 content considerably, in some cases to 50% and less.
      Fix: Channel auto update : Sometimes the channel auto update for recordings didn't work correctly.
      Change: The default name scheme for recording is now: %date_%time_%station_%name
      EPG
      Fix: D+ EPG (Spanish MHW EPG) works again.
      Add: EPG: Support for the Japanese Arib8 EPG format.
      Fix: EPG Options : Reworked the language selection in the EPG options.
      Change: The ISO language is now shown in the EPG language options .
      Add: Tweaks : Added “DVBEPGAsAnsi” Tweak (see Tweaks.txt). Determinates if the DVB EPG Parser ignores the language settings in the EIT and converts the text from the local charset to UTF-8. May help if you get strange chars in the EPG.
      You have to set the locales setting of the system account the recording service is running in to the same locales your user account is using.
      OSD
      Change: OSD Timer window : The askdeletetimer setting now also works for the OSD timer window.
      Change: OSD channel list window : OSD Left/Right on a channel group now jumps one group forward/backward.
      Change: OSD Default skin : Some fixes and small changes.
      Playback
      Add: DVB/Bluray/HDDisk images : can be played by Drag'n'Drop into the main window or “open media file” (still needs Daemon Tools or Virtual CloneDrive).
      Fix: Tag reader/Flac files: The Vorbis Comments tags were not read correctly for flac files.
      Change: EPG loaded from the Service : Is now handled again as external EPG.
      Change: Sending WOL to the Recording Service PC on program start up: Now the messages pump is kept working while waiting for the WOL. No more “... doesn't respond” messages.
      DVBServer
      Updated to the current hardware handling, please see above for changes.
      I've uploaded Hotfix 4.8.0.1.
      Changes:
      - Fix: Favourites: fixes problems with favourites.
      - Fix: Timer: fixes all timers are shown red in the recording window if recorded locally.
