TBS 6922 PCI-E DVB-S2 TV
TBS 6922 is a PCI Express interface digital satellite TV Tuner card for watching and recording Free to Air satellite TV on PC. It supports both DVB-S2 and DVB-S programs receiving. It’s ready with Windows BDA driver and Linux driver up to the latest kernel 3.X(Tested on Ubuntu,Fedora,Opensuse and other Linux distributions). It’s compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
Description:
TBS 6922 PCI-E DVB-S2 TV Tuner card is the latest release of TBS PCI Express series satellite TV cards. It uses advanced DVB-S2 RF and demodulator chipset and it’s built with the highest quality components such as tantalum capacitors. You can use it to watch UK Freesat or any other free to air(FAT) satellite TV programs in your region. With its’ low profile size, it’s ideal for building up HTPC or IPTV streaming server. With use of appropriate software, e.g. MediaPortal and its’ plugins, you may stream satellite TV contents to your IPhone, IPAD or IPOD. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for hunting unknown satellite feeds.
Main Features:
Watch Satellite TV & listen to Radio on PC
DVB-S2/DVB-S SD or HD TV Receiving
Broadband Internet via Satellite *
High-speed Data download via Satellite *
Real Time and Scheduled Program Recording(PVR)
Time Shifting to Pause Live TV
Unicable/One Cable compatible
Blindscan
High reliability
*Depends on service provider.
Applications:
HTPC
IPTV Streaming Server
Specifications:
Receiving Frequency: 950~2150 MHz Tuning Range
Input level: -69~-23dBm
DVB-S2/DVB-S DIRECTV 8PSK QPSK Demodulator
Symbol Rate:
DVB-S QPSK 1~45Msps
DVB-S2 QPSK/8PSK 1~45Msps
Carrier Capture Range: ±10MHz
8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10.
Support Data Burst & Tone Burst
Support DiSEqC2.X and Motor
Low profile size: 128x59mm (Length x Height)
System Requirements:
Windows 2000/XP/Vista/7 or Linux
DirectX9.0 or later Version
Available PCI Express x1,x4, x8 or x16 slot
Satellite Dish and LNB
For DVB-S:
1GHz CPU or above
256MB RAM or above
Graphic Card with at least 16MB RAM
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
Graphic Card with at Least 64MB RAM
Package Content:
1 x TBS6922 PCI-E DVB-S2 TV Tuner Card
1 x remote control
1 x IR receiver
1 x Software CD
Description:
Main Features:
Blindscan
High reliability
Applications:
HTPC
Specifications:
Symbol Rate:
DVB-S QPSK 1~45Msps
For DVB-S:
1GHz CPU or above
256MB RAM or above
For DVB-S2 HDTV:
Dualcore CPU
1GB RAM or Above
Package Content:
1 x remote control
1 x IR receiver
1 x Software CD
