Satelitski prijemnici za lovce na fidove!
    • Clarke-Tech 5000 HD Combo Plus
      2 High Definition Tuners: DVB-S/DVB-S2 Satellite & DVB-T Terrestrial compliant (MPEG2 / MPEG4 / H.264)
      Video resolution 576i & 576p, 720p & 1080i supported
      1 Smart Card Reader & 2 Common Interfaces (2CI)
      HDMI & Component Output (YPbPr) with Hardware Upscaler to Improve Picture Quality
      Very Fast & Detailed Hardware Blind Search (power scan)
      Ethernet Communication Port
      eSATA Port
      2x USB Ports ( 1x Front + 1x Rear Ports)
      10,000 TV & Radio Channels
      USB 2.0 PVR Ready via USB External Device
      USB PVR Features: Rewind/Forward, Slow Motion Rewind/Forward, Timeshift (Pause Live TV) & Record Scrambled/Free-To-Air (FTA) Channels & Record current channel and playback a recording at the same time
      Music player & JPEG viewer via USB 2.0
      Fast Software & Channel List download via USB 2.0
      2 Scart Outputs with RGB Support
      Fully Featured VFD text Front Panel Display
      Super sensitive tuner for very weak signals
      Dolby Digital Optical S/PDIF
      Dolby Digital by HDMI
      S-Video Output
      DiSEqC 1.0 / 1.1 / 1.2 & 1.3 (USALS) compatible
      Auto Navigation system – select as many satellites as you want to search
      On-screen display with true full color resolution
      Enhanced 16 Favorite channel groups
      Channel control by: Favorites, Lock, Skip, Move & Delete
      Channel sort by: All, Alphabet, Transponder & CAS
      Parental, Installation & Receiver Lock
      Multilingual OSD Menu: English, Spanish, Portuguese, French, Dutch, German, Italian, Turkish, Arabic, Russian, Greek, Czech, Romanian, Persian
      Fast & Easy-To-Use Menu System
      Extended EPG and program reservation on EPG
      Teletext & Subtitle by OSD and VBI
      Last channel memory function
      Factory default channel list
      Various games
      Software & channel list upgrade via RS-232C: PC to STB, STB to PC, STB-STB and USB
      Zoom function on Pause & Live channel
      Multi picture display
      SCPC & MCPC receivable from C/Ku band satellites LNBs supported: Universal, Single, Single S & C band wideband LNBs
      4:3 & 16:9 Screen Formats
      90-250V AC 50/60 Hz
      LNB Short Circuit protection onboard
    • Octagon SF-1028P HD Noblence FULL HD Twin Sat Receiver Linux PVR
      The Octagon SF 1028P HD Noblence is a digital twin-HDTV PVR receiver of both the normal digital as well as HDTV programs can be received. He has just about anything with what one of digital twin HDTV PVR receiver can do one himself. Internally, a 2.5 inch SATA hard disk can be built and also other additional external USB hard drives (if and what hard drive installed in this offer is for you see above).
      Linux operating system:
      The receiver used there in the operating system is Linux * open source . This can and will be improved and supplemented, the functionality of this receiver will continuously be expanded that. In this respect he is more versatile than almost any other receiver. Because this receiver with potential applications are virtually no limits to Sun
      * What is open source ?
      This means that the source code (source code) for this operating system is freely available. And this means that anyone who knows something about programming can help in their further development. This is so assured that it is constantly improved and new functionality added.
      Twin-Tuner with ausstauschbaren plug-tuners, HD and SD reception, Plug & Play.
      The following tuner modules are available (which are incorporated see above):
      DVB-S2 (SD / HD satellite)
      DVB-C (SD / HD cable TV)
      DVB-T2 (SD / HD Terrestrial)
      Full-HD 1080p
      Of The Octagon SF 1028P HD Noblence is a true full-HD receiver. It can all resolutions up to 1080p physically present so as individual picture elements and without extrapolation: frame of 1,920 x 1,080 pixel resolution at 24, 50 or 60 Hertz.
      Blind scan allows a search of the entire frequency spectrum of a satellite without the input of frequencies, symbol rates or use of preferences to search. Are hereby found stations that have joined new and not yet included in the network table of a satellite.
      mkv file support: About the MKV file format (Matroska), you can use a variety of additional media formats, including high-definition standards such as: WMV-HD and H-264 in HD.
      Timeshift allows time-shifted television, it can be stopped shipments and later replayed. The caching can be done on a built 2.5 inch SATA hard disk or to a USB 2.0 attached external hard drive.
      PiP - Picture in Picture
      The Twin-Tuner DVB that one, while allowing a record programs while watching a different one, and on different transponders or channels. Similarly, one can also record two shows at the same time on different transponders.
      Behind the front door is located 2 CI slots for CI modules and 2 Conax card reader - so he is well prepared for the decryption of pay-TV programs.
      2.5 "Hard Disk option - The advantages over 3.5-inch hard drives:
      - Less heat, less noise, less vibration
      - Silent operation and lower power consumption
      Other connections:
      The Extras:
      [COLOR="red"]The main features:[/COLOR]
      Twin Tuner (Plug & Play - interchangeable) Full HDTV PVR receiver, the following tuner modules are available (which are incorporated see above):
      DVB-S/S2 tuner, satellite
      MPEG4 / MPEG2 - HD / SD & DVB-S2 / DVB-S Compliant
      blind scan (SD & HD)
      Multi-LNB support DiseqC Control Version 1.0, 1.1, 1.2 and USALS
      Tuner DVB-C, cable (cable TV)
      MPEG4 / MPEG2 - HD / SD & DVB-C Compliant
      Tuner DVB-T2, Terrestrial
      MPEG4 / MPEG2 - HD / SD & DVB- T2 Compliant
      Operating System Linux OS
      Installation option of a 2.5 inch SATA hard drive (if and what hard drive installed in this offer is for you see above)
      Time-Shifting with internal and external hard drive (e-SATA or USB 2.0)
      View up to 3 transmitters and 2 recording channels LIVE (PIP)
      Simple recording programming from the EPG
      3x USB 2.0 ports (one behind the front door and two on the back)
      MP3 Player & JPEG viewer pictures
      Xvid MKV & Support
      Ethernet interface (10/100Mbps LAN)
      blind scan (SD / HD)
      Alphanumeric Premium VFD Display
      Universal Remote Control TV / SAT / DVD
      UNICABLE FastScan & Support
      High-resolution OSD interface
      Favorite groups for TV and Radio
      Channel sorting functions such as delete, rename, move, lock
      OSD in multiple languages
      Teletext and subtitle support
      10,000 program for TV & Radio
      PIP and multi-picture (PIP) function
      Parental Control
      HDMI output of audio and video (576i, 576p, 720p, 1080i, 1080p )
      YUV (component output)
      Cinch sockets for AV signal (composite video, stereo audio)
      CVBS, RGB and Y / C signal via SCART (TV)
      Optical (SPDIF) output of Dolby
      Software Updates on USB/RS-232/Netzwerk
      2x Conax CA and 2 CI PCMCIA
      1 watt stand-by consumption
      Delivery:
      Operating instructions in German and English
      Remote Control
      2x AAA batteries
      HDMI Cable
      Loop-through cable (for receivers with DVB-S2 satellite tuners)
      Power-cable
      [COLOR="red"]Technical data:[/COLOR]
      DVB-S2 tuners (which are built tuner see above)
      Input connectors:
      F-type, IEC 169-24, Female
      Line output:
      Input frequency range:
      950 MHz ~ 2150 MHz
      Input impedance:
      75 ohms, unbalanced
      Input Level:
      -65 To -25 dBm
      LNB supply:
      13/18 VDC, max. 400 mA
      22KHz Signal:
      (22 ± 2) KHz, (0.6 ± 0.2) V
      DiSEqC Level:
      1.0 / 1.2 / USALS Compatible
      Demodulation:
      QPSK / 8PSK
      Symbol Rate:
      2 ~ 45 Ms / s (QPSK of DVB-S)
      2 ~ 45 Ms / s (QPSK of DVB-S2)
      2 ~ 37 Ms / s (8PSK of DVB-S2)
      FEC:
      1 / 2, 2 / 3, 3 / 4, 5 / 6 and 7 / 8 with
      Constraint Length K = 7 (DVB-S)
      1 / 2, 3 / 5, 2 / 3, 3 / 4, 4 / 5, 5 / 6, 8 / 9 and 9 / 10 (DVB-S2)
      DVB-T2 tuner (which tuners are installed you can see above)
      Input connectors:
      IEC 169-2, Female
      Line output:
      IEC 169-2, Male
      VHF III: 174 ~ 230 MHz
      UHF IV: 470 ~ 606 MHz
      V UHF: 606 ~ 862 MHz
      Demodulation :
      OFDM
      Bandwidth :
      6, 7, 8 MHz
      FET mode :
      1K, 2K, 4K, 8K, 16K, 32K
      Code rate :
      1 / 2, 2 / 3, 3 / 4, 3 / 5 4 / 5, 5 / 6
      Guard Interval :
      1 / 4, 5 / 32, 1 / 8, 5 / 64, 1 / 16, 1 / 32, 1 / 64, 1 / 128
      DVB-C tuner (which tuners are installed you can see above)
      Input connectors:
      IEC 169-2, Female
      Line output:
      IEC 169-2, Male
      50MHz ~ 1GHz
      Demodulation :
      16, 32, 64, 128, 256 QAM (for Annex A / C)
      64, 256 QAM (for Annex B)
      IF bandwidth :
      8 MHz (-3dB) TYPE (for Annex A / C)
      6 MHz (-3dB) TYPE (for Annex B)
      Symbol Rate :
      1 Msps ~ 7 Msps (for Annex A / C)
      5057 Msps (for 64 QAM, Annex B)
      5361 Msps (for 256QAM, Annex B)
      MPEG Transport Stream A / V Decoding
      Transport Stream:
      H.264 (MPEG-4 part 10, MPEG-4/AVC and H26L)
      MPEG-II ISO / IEC 13818-2/11172-2
      Profile Level:
      MPEG-4/AVC MP @ L4, MPEG-II MP @ HL
      Eingansrate:
      Max 80Mbit / s
      Video formats:
      4:3 Letter Box, 4:3 Pan Scan, 16: 9
      Resolution:
      720 x 576i 720 x 576p, 720 x 480i 720 x 480p
      1280 x 720p, 1920 x 1080i, 1920 x 1080p (HDMI only supports)
      Audio Decoding:
      Dolby Digital, MPEG-1 Layer 1,2 and 3
      Audio Mode:
      Stereo / Joint stereo / mono, Dolby Digital bitstream
      Audio sample rate :
      32KHz, 44.1KHz and 48KHz (According to input)
      Hardware
      CPU:
      STi chipset
      Memory:
      Flash ROM: 64MB
      SDRAM: 256 Mbytes
      EEPROM: 256 bytes
      Audio - Video Interface
      TV SCART:
      RGB, Y / C, CVBS Video, Audio L, R Output
      VCR SCART:
      RGB video input, CVBS Video, Audio L, R input
      RCA:
      Video CVBS output, Audio L, R Output
      Components:
      YPbPr video output
      HDMI:
      Video & Audio Output
      OPTICAL:
      Dolby Digital (SPDIF)
      RS-232C:
      9 pin D-SUB (Male) type, Transfer rate 115Kbps
      USB:
      2x USB 2.0 host - rear
      1x USB 2.0 host - behind the front flap
      5V DC 500 mA Max
      Ethernet:
      RJ45 connector, 100 Mbps
      e-SATA:
      External SATA port
      Front panel
      Slot:
      1 USB 2.0 host port
      2 Common interface PCMCIA slot
      2 Smart Card slot
      Display:
      VFD (Vacuum Fluorescent Display) - 12 Digit
      Keys:
      5 buttons (Standby, Channel up / down, Volume up / down)
      Power Supply
      Input voltage:
      AC 100 ~ 250V, 50/60Hz
      Type:
      SMPS
      Power consumption:
      Up to 55 Watt
      Standby:
      Max 1 Watt
      Protection:
      Separate internal fuse
      Size and temperature
      Size (L x W x D):
      340 mm x 60 mm x 230 mm
      Weight:
      about 2.0 Kg (without hard drive)
      Ambient temperature:
      0 ° C ~ +45 ° C
      Storage temperature:
      -10 ° C ~ +70 ° C
      The remote control:
      More pictures of the screen:
      Detailed images:
      1. POWER button
      On / off (Standby / Operating)
      2. CH
      In normal mode to switch programs, menu mode to navigate the menu
      3. Vol
      In normal mode, adjust the volume, the menu mode to navigate the menu
      4. IR Sensor
      Infarotempfänger for the remote control
      5. VFD Display
      Program name and various information is displayed on the VFD display
      6. USB (front)
      USB port for USB storage devices
      7. Card Reader
      Smart cards (2xConax)
      8. CI Slot
      for Common Interface Module
      VFD Display
      1. FB LED remote display
      When a key is pressed on the remote, the LED lights.
      2. Information
      Program names.
      1. VCR SCART
      Connection for VCR or DVD player / recorder
      2. TV SCART
      Connection for TV
      3. SPDIF
      Digital Audio Output optical (AC3)
      4. VIDEO
      Video (analog composite video output / Yellow)
      5. AUDIO L / R
      Audio out (analog, stereo audio output / White, Red)
      6. Component
      Component output (YPbBr) YUV
      7. USB
      2x USB port for USB storage devices
      8. HDMI
      HDMI Output to TV
      9. RS-232C
      Serial interface (STB> PC) for firmware update and data transfer
      10. Ethernet
      Network connection 10/100 Mbit (LAN)
      11. e-SATA
      e-SATA port for external storage devices (HDD - hard disk)
      12. A / C Switch
      Power switch (power)
      13. A / C power cable socket
      for power cable
    • Vizyon Revolution 820 HD PVR USB LAN
      LINUX OS (some parts under the terms of GPL, accordingly expandable)
      DVB compliant, DVB-S2 with Blind Scan, DVB-S, DVB-T, DVB-C tuner module supported
      Smart tuner supported (Plug & Play)
      MPEG-2 MP@HL Video Decoder
      MPEG-4 AVC/H.264 HP@L4 Video Decoder
      1 X Smarcard reader
      DVB Common Interface (2 slots) supported
      XVID supported
      Dolby Digital decoder
      MP3 decoder
      HDMI with HDCP supported
      Multi-format Audio Decoder
      High Definition and Standard Definition
      Format resolution: 1080i, 720p, 576i
      USB 2.0 (Host) for DiVx, MP3, Photo Album, Video Player
      Network Interface Supported (High Speed Ethernet)
      Multi-point Mount Manager supports to Access to various media storages in one or many PCs.
      Software update via internet or USB memory stick
      SCPC and MCPC receivable from C/Ku-band satellites
      Channel list editing
      Favorite channel list editing
      True-color On-Screen Display (OSD)
      Full Picture In Graphic (PIG) function
      Electronic Program Guide (EPG) for on screen channel information
      Subtitle & Teletext supported
      Parental lock facility by channel and program event
      External SATA interface supported or internal SATA interface supported with 2.5’’ HDD bracket
      2 channel recording and 1 another channel watching in the TP at the same timeorted.
    • CubeRevo 250 HD PVR Blind Scan
      Brand New Linux Model with Hardware Blind Scan
      Full featured 'mini' high definition blind scan set top box with multi-crypt card reader, linux os, ethernet and USB PVR.
      Features:
      • LINUX OS (some parts under the terms of GPL, accordingly expandable)
      • Plug in and Add on supported
      • DVB compliant, DVB-S2 tuner with Blind Scan supported or Terrestrial DVB-T tuner supported
      • 1 x Smartcard reader(Xcrypt)
      • MPEG-2 MP@HL Video Decoder
      • MPEG-4 AVC/H.264 HP@L4 Video Decoder
      • Dolby digital decoder
      • HDMI with HDCP supported
      • Mutlicast and Unicast IPTV streamming supported for multiroom service
      • Multi-format Audio Decoder
      • High Definition and Standard Definition
      • Format resolution : 1080i, 720p, 576i
      • USB 2.0(Host) for DiVx, MP3, Photo Album, PVR and external multi-port USB HUB supported
      • Network Interface Supported (high speed Ethernet)
      • Multi-point Mount Manager supports to access to various media storages in one or many PCs.
      • Software update via internet or USB memory stick
      • TV SCART supported to CVBS only
      • SCPC and MCPC receivable from C/Ku-band satellites
      • Channel list editing
      • Favorite channel list editing
      • True-color On-Screen Display (OSD)
      • Full Picture In Graphic (PIG) function
      • Electronic Program Guide (EPG) for on screen channel information
      • DVB or VBI Subtitle & Teletext supported
      • Parental lock facility by channel and program event
      • 1 channel recording and 1 another channel watching in the TP at the same time
    • CubeRevo Twin Tuner HD PVR MKII Linux Enigma 2
      ALL SATELLITE TUNERS NOW INCLUDE 'HARDWARE BLIND SCAN'.
      Flagship Hi-Def Twin Tuner Box CubeRevo High-Def Linux Twin Tuner PVR with a massive 1TB drive option. As standard this unit ships with 2xDVB-S2 tuners (2xhigh definition satellite tuners). The CubeRevo is similar to the popular AB Com IP Box 9000 apart from it comes with a far superior updated front panel display which provides extended Tuner and Recording information, which is not available on the AB Com version. The CubeRevo is from the original manufacturer and software writers DGStation.
      To date the CubeRevo is by far the best box we have seen, they don't get much better than this, build quality and audio/video quality is excellent in both high and standard definition and across all DVB formats S/S2/T/C. The CubeRevo features are amazing and third party support on the internet is endless.
      The CubeRevo comes with two high definition Plug and Play satellite tuners (2xDVB-S2) which can be switched between Satellite, Cable and Terrestrial, we keep a full range of tuners in stock.
      Amongst the many connectors on the rear the CubeRevo sports an ethernet port which means you can share its connection as well as connect it to via your home network and drop files directly on the hard drive using ftp. On the internet you can also view the units menus via its Web Interface from anywhere, allowing you to see EPG's, set recordings and even download the recorded files.
      Furthermore the CubeRevo is very well supported with third party applications and Plug-Ins on internet forums offering a whole host of features such as sharing applications (gbox, newcs, cccam), emulators for the two in-built card slots and even email plugins. There are also two common interface CAM sots and DivX playback. Software updates can be performed over your LAN, via USB cable or USB Keyring. The remote is multi-functional control for TV and other items.
      •LINUX open source (some parts under the terms of GPL, accordingly expandable)
      •DVB-S compliant, DVB-S2 with hardware blind scan (satellite), DVB-T (terrestrial/freeview), DVB-C (cable) supported (shipped with 2xDVB-S2 as standard)
      •Smart tuner supported(Plug & Play)
      •MPEG-2 MP@HL Video Decoder
      •MPEG-4 AVC/H.264 HP@L4 Video Decoder
      •DIVX supported
      •MP3 decoder
      •Dolby AC3 downmix decoder
      •HDMI with HDCP supported
      •Multi-format Audio Decoder
      •High Definition and Standard Definition
      •DVB Common Interface (2 slots) supported
      •Format resolution: 1080i, 720p, 576p
      •USB 2.0(Host) supported
      •USB 1.0(Client) supported
      •Network Interface Supported( high speed Ethernet
      •VFD Display : Capability for display of various information
      •SCPC and MCPC receivable from C/Ku-band satellites
      •DiSEqC Control: Version 1.0 / 1.1 / 1.2 / 1.3 (USALS Compatible)
      •Channel list editing
      •Favorite channel list editing
      •True-color On-Screen Display (OSD)
      •Full Picture In Graphic (PIG) function
      •Electronic Program Guide (EPG) for on screen channel information
      •Subtitle & Teletext supported
      •Parental lock facility by channel and program event
      •Silver color and Black color supported
      •SATA-I(1.5Gbps) supported
      Added hardware parts for future use.
      •S-ATA cable and 3.5" HDD cradle(bracket)
      •2 x mini PCI socket for several kinds of tuner
      •2 x smartcard reader
      •IPTV function to be added
      -FREE HDMI CABLE!
      -FREE SCART CABLE!
    • Smart MX04 HDTV
      This device is designed to bring high-resolution television pictures on your flat screen in best quality. Thanks to its variety of connectivity options, the device can be connected via Y/Pb/Pr or HDMI cable with a suitable device.
      - HDMI output
      - 5000 TV and radio channels
      - DiSEqC support
      - Pre-programmed Astra, Hotbird, Türksat
      - 32 favorite lists
      - USB interface
      - Digital Audio Output: coax
      - Scart connector
      - Accessories: Remote control, batteries, user manual
      - Dimensions (W x H x D): 260 x 50 x 225 mm
      Smart MX04 HDCI
      - HDMI output
      - DiSEqC support
      - 8 favorite lists
      - USB interface
      - Scart connector
      - Dimensions (W x H x D): 260 x 50 x 220 mm
      Smart MX04 HDCA
      - HDMI output
      - DiSEqC support
      - 8 favorite lists
      - USB interface
      - Scart connector
    • Smart CX 42
      HDTV Satelliten Receiver der neuen Generation
      Dieser Receiver besitzt ein eingebauten Twin Tuner. Damit ermöglicht der CX42 Ihnen das Aufzeichnen einer Sendung, bei einer gleichzeitigen Wiedergabe eines anderen TV- Programms.
      Dank USB Anschluss nie etwas verpassen.
      Der CX 42 lässt sich durch den Anschluss eines externen USB Speichers (Festplatte, USB Speicherstick) als vollständigen Festplatten- Recorder nutzen. Mit der Common Interface (CI) Schnittstelle sind Sie auch für Pay-TV bestens gerüstet.
      - Twin Tuner
      - Common Interface (CI)
      - PVR-ready
      - HD Ready 1080i
      - USB-Schnittstelle zum Anschluss einer externen Festplatte
      - Save Energy
      - Receiver Automatik Programmierungs-System (RAPS)
      - 4-stelliges VF-Display
      - 5000 TV- und Radio Kanäle
      - Abmessungen (B x H x T): 260 x 50 x 225 mm
      - Zubehör: Fernbedienung, Batterien, Bedienungsanleitung
    • Optibox Koala HD
      Linux - XDIV - MKV - Enigma2
      - Digital Satellite receiver & PVR Ready
      - H.264 / MPEG4 - HD,SD / DVB-S2 Tuner
      - 1 Smart card reader and 2 Common Interface Slots
      - Powerful compatibility through Embedded Linux OS
      - Recording & Playback with External USB 2.0 Devices
      - Recording and Time Shifting Simultaneously
      - Recording and Playback Simultaneously
      - Powerful Extended EPG supports and Event Recording
      - USB 2.0 Host Support (MP3 Player & JPEG Viewer)
      - Xvid file play back supported
      - Ethernet port Supported
      - Intelligent Blind Scan for both SD and HD TV & Multi-Satellite Search
      - White VFD Display (8 Digit Alphanumeric)
      - HDMI Video & Audio Output (576i, 576p, 720p, 1080i)
      - PIP(Picture-in-Picture) & Multi-picture(*)
      - Multi-LNB Controlled by DiSEqC Control Version 1.0, 1.1, 1.2 and USALS
      - On-Screen Display with Full Color & Resolution
      - Favorite Service Groups
      - Powerful Service Control by Favorites, Lock, Skip, Move and Delete
      - Service Sorting by Alphabet, Transponder and CAS
      - User Friendly & Multi-language Supported (OSD & Menu)
      - Teletext Support
      - Maximum 10,000 Services Programmable
      - Parental Lock / System Lock / Installation Lock
      - Supports Y/Pb/Pr(component) Output in HD
      - CVBS(composite) Video & Audio Output via RCA
      - Optical Output for Digital Audio(SPDIF)
      - Software & Service channel Database upgrade via USB & RS-232C port
      - 1W Stand-by Power Consumption
      Tuner & Channel Decoder
      Input Connector: F-type, IEC 169-24, Female
      Loop through out: F-type, IEC 169-24, Female
      Frequency Range: 950MHz ~ 2150MHz
      Input Impedance: 75Ohm, unbalanced
      Signal Level: -65 to -25dBm
      LNB Power: 13/18VDC, max.400mA
      22KHz Tone: (22±2)KHz, (0.6±0.2)V
      DiSEqC Control: V1.0/1.2/USALS Compatible
      Demodulation: QPSK / 8PSK
      Input Symbol Rate: 1 ~ 45 Ms/s(QPSK of DVB-S)
      1 ~ 45 Ms/s(QPSK of DVB-S2)
      FEC Decoder: 1/2, 2/3, 3/4, 5/6 and 7/8 with Constraint Length K=7(DVB-S)
      1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9 and 9/10 (DVB-S2)
      MPEG Transport Stream A/V Decoding
      Transport Stream: H.264(MPEG-4 part 10, MPEG-4/AVC and H26L)
      Profile Level: MPEG-II ISO/IEC 13818-2/11172-2
      MPEG-4/AVC MP@L4, MPEG-II MP@HL
      Input Rate: Max. 15Mbit/s
      Video Formats: 4:3 Letter Box, 4:3 PanScan, 16 : 9
      Video Resolution: 720 x 576i, 720 x 576p, 720 x 480i, 720 x 480p
      Audio Decoding: Dolby Digital, MPEG-1 Layer 1,2 and 3
      Audio Mode: Stereo/Joint stereo/Mono, Dolby Digital bitstream
      Sampling Rate: 32KHz, 44.1KHz and 48KHz(According to input) Main System
      Main Processor: STi chipset
      Memory: Flash-ROM : 32 Mbyte
      SDRAM : 192 Mbytes
      EEPROM : 128 bytes
      Audio / Video & Data IN/OUT
      RCA: CVBS Video Output, Audio L, R Output
      Component: YPbPr Video Output
      HDMI: Video & Audio Output
      OPTICAL: Dolby Digital (SPDIF)
      RS-232C: 9 pin D-SUB (Male) type, Transfer rate 115Kbps
      USB: USB 2.0 Host Support. (5 Vdc 500 mA max.)
      Ethernet: RJ45 connector, 100 Mbps
      Front Panel
      Slot: 2 Common interface PCMCIA slot
      1 Smart Card Slot
      Display: VFD(Vacuum Fluorescent Display) - 8Digit
      Buttons: 3 Buttons (Standby, CH UP/DOWN)
      Power Supply
      Input Voltage: AC 100 ~ 250V, 50/60Hz
      Type: SMPS
      Power Consumption: Max. 30W
      Protection: Separate Internal Fuse & Lighting protection
      Physical Specification
      Size (W x H x D): 300mm X 60mm X 230mm
      Weight (Net): 1.6 Kg
      Operating Temp.: 0°C ~ +45°C
      Storage Temp.: -10°C ~ +70°C
    • Optibox Pantera HD
      - High Definition Digital Satellite Receiver
      - Compliant MPEG-4/H.264 & Fully DVB-S2 (DVB-S)
      - 2 Common Interface (CI) Slots
      - 2 Smart Card slot
      - Powerful 300MHz CPU
      - Embedded Linux OS
      - Blind scan
      - eSata and USB connections
      - PVR & Timeshifting functions using External Storage Devices
      - Clear VFD Display
      - Multi Language OSD
      - Dolby Digital Bitstream Out via Optical S/PDIF
      - Format resolution: 576p, 720p, 1080i
      - YPbPr, CVBS, annd HDMI Video Outputs
      - RJ-45 Ethernet Interface (10/100M)
      - Wifi connection (optional)
      DVB-S/S2 Tuner And Channel
      RF Input Range: 950MHz ~ 2150MHz
      Input Connector: F-Type Female (With Loop-Through Output)
      Input Impedance: 75[Ohm]
      Input Dynamic Range: -65dBm ~ -25dBm
      Multi Demodulation Standard: DVB-S, DVB-S2 : QPSK, 8PSK
      Symbol Rate: DVB-S : QPSK Maximum 45Msps @ 2~45Msps
      DVB-S2 : 8PSK/QPSK Maximum 30Msps @ 10~30Msps
      Multi Decoding Method Standard: LDPC/BCH DVB-S2(1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10)
      DVB-S/S2 MPEG TS A/V Decoding
      Transport Stream Format: MPEG-4 Part10 AVC/H.264 HD HP@L4.1 1920x1080@50Hz(ISO/IEC 13818 MPEG-2 TS Specifications)
      Profile Level: MPEG-2 MP@HL, MPEG-4 Part10 AVC/H.264 HD HP@L4.1
      Input Rate: Maximum 90Mb/s
      Video Aspect Ratio: 4:3, Letter Box, 16:9, Pan & Scan
      Video Display Resolution: 1920x1080i, 1280x720p, 720x576i/p, 720x480i/p @ 50/60Hz
      Audio Decoding Format: Dolby Digital bit-streams, MPEG-1 Layer 1,2,3
      Audio Output Mode: Mono, Left, Right, Stereo, Dolby Digital bit-streams(PCM 5.1 Channel, Stereo down-mixed Dolby ProLogic) A/V And Data Output
      Analog Component YPbPr: 1 Set(3xRCA Vertical Array Type)
      CVBS(Composite Video), Stereo Audio: 1 Set(3xRCA Vertical Array Type)
      S/PDIF Dolby Digital Interface: 1 Optical(Fiber Optic Type)
      HDMI (with HDCP Option): 1 Connector
      SCART Interface: TV/VCR
      USB2.0 Host Interface: 2 USB A-Type Connector
      Ethernet: 1 Connector RJ-45 10/100 Base-T
      RS-232C Data Port D-Sub9 Interface: Transfer Rate 115,200bps(Firmware Upgrade Port)
      Conditional Access Interface
      PCMCIA: 2 Slots For DVB Common Interface Standard
      Smart Card: 2 Smart Card Support
      Storage Device
      SATA(Serial ATA): 1 External eSATA Port
      System Resource Information
      Main Processor: 300MHz MIPS32TM/16-e class CPU
      Flash ROM: Default 32Mbytes
      DDR SDRAM: Default 256Mbytes
      Power Supply
      Input Voltage: AC 100-240V ~ 50/60Hz
      Power Consumption: Maximum 35Watts
      Type: SMPS(Switching Mode Power Supply)
      Safety And EMI: For Country Regulation
      Dimension(WxDxH): 340x268x60[mm]
      Net Weight: About 3.0Kg
      Operation Temperature: 5°C ~ 50°C
      Storage Temperature: -40°C ~ 65°C
    • Optibox Alligator HD
      - High Definition Digital Satellite & Terrestrial Receiver
      - Compliant MPEG-4/H.264 & Fully DVB-S2 (DVB-S), DVB-T
      - 2 Smart Card slot
      - Embedded Linux OS
      - Clear VFD Display
      DVB-T Tuner And Channel
      RF Input Range: VHF-High Band 149.5MHz ~ 426MHz,
      VHF-Low Band 50.5MHz ~ 142.5MHz, UHF-Band 434MHz ~ 858MHz
      Input/ Loop-Through Output Connector: 1 x Din Jack for DVB-T, 1x Din Jack for DVB-T Loop-Through Output
      (IEC 169-2 Female/Male)
      Input Impedance: 75[Ohms] Nominal
      Input Signal Level: -80dBm ~ -5dBm(64QAM, Code Rate 2/3, Guard Interval 1/32,
      Gaussian Channel)
      Digital Modulation Scheme: QPSK, 16-QAM, 64-QAM(Constellation)
      Guard Interval: 1/4, 1/8, 1/16 and 1/32
      Modulation Mode: 2K, 4k, 8K modes
      Supporting System: DVB-T(COFDM) Compliant (Frequency Band Modulation) ETSI 300 744
      IF BandWidth: 6/7/8MHz channel
      FEC Code Rates: 1/2, 2/3, 3/4, 5/6, 7/8 DVB-T MPEG TS A/V Decoding
      Transport Stream Format: MPEG-4 Part10 AVC/H.264 HD HP@L4.1 1920x1080@50/60Hz(MPEG-2 ISO/IEC 13818 Transport Stream Specification)
      Input Rate: Maximum 31.668450Mb/s, 27.709893Mb/s
      A/V And Data Output
      Storage Device
      Power Supply
    • Sat Hawk PVR 800 aka OPENBOX S9 HD or Solomend DVB-S & DVB-S2 FTA Satellite Receiver
      Advantages over other receivers:
      BLIND SEARCH: This receiver not only blind searches signals in DVB-S, but also DVB-S2. The Blind Search feature is very fast.
      AC3 Digital Sound: Digital sound through HDMI output
      Recording: Using an optional external Flash USB drive or HD, you can record your favorite shows and setup timer to do the same while you are out of the house.
      EASY HH Motor control and setup. If you decide to add an HH Motor (DiSEqC 1.2 or USALS) now or in the future to move your dish, this is the best receiver available to control your motor. It has the USALS feature which makes searching for other satellites in the sky a very simple procedure.
      MAIN FEATURES
      Receive Digital High Definition (HD) and Standard Definition (SD) Satellite Signal
      Supports DVB-S, DVB-S2, MPEG-2 & MPEG-4
      Digital Video Recorder through USB (external flash or hard drive are not included)
      The most affordable FTA HD receiver on the market today.
      Worldwide compatible
      Hardware Blind Search DVB-S and DVB-S2 (fast search less than 2 Minutes on most satellites)
      Linux MIPS Operating System
      STB main IC solution is ALI , demodulator model is M3501 from Ali
      HD DVB-S2 SHARP 7306 Tuner
      Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech
      Other Features
      300 MHz MIPS Processor - Linux OS
      Fully compliant MPEG-4 H.264/AVC Main Profile Level 3 & High Profile Level 4.1;
      Fully compliant MPEG-2 MP@HL & MP@ML;
      Fully compliant MPEG-1 Layer I & II & III,
      Dolby Digital Audio(AC3)
      Multiple LNB-Switching control (supports DiSEqC1.0/1.1/unicable)
      Motor Support: DiSEqC 1.2/1.3 (USALS - GoTo X)
      MHEG-5
      HDMI 1.3 output (HDMI cable not included)
      PVR (store on USB external disk)
      Multimedia files playback (by USB);
      7 Days Electronic Program Guide (EPG)
      Teletext and subtitle out through OSD
      Multi-lingual DVB subtitle and teletext
      Automatic and Manual Channel Scan
      Automatic Service Scan
      NIT search
      Hardware BLIND SEARCH
      Fast channel switching < 1 second
      OSD in many languages and skin-support
      Multilingual support on screen menu (OSD): English, French, Deutsch, Italian, Spanish, Swedish, Danish, Greece, Portuguese, Finland, Holland, Turkish, Czech, selectable;
      LED Display
      Multiple display mode: 1080i/720p/570p/576i/480p;
      MPEG-2 / H.264 hardware decoding
      Videotext Decoder
      Analog RCA audio output: stereo (L+R);
      Digital audio output: S/PDIF by coaxial
      S/PDIF Interface for digital bit stream out (AC-3)
      YCbCr Component Video Output
      2 x Scart (RGB, FBAS or S-Video)
      Screen format: Auto, 4:3, and 16:9;
      Upgrade software through USB2.0 port
      Powerful user interface program management function, parent lock
      1x CI built-in
      1x CA (smartcard reader) built-in
      10/100Mbit Ethernet Interface
      Notes:
      No 4:2:2 out of the box (not supported)
      No internal hard-drive included with receiver.
      You can connect an optional external HD or Flash Memory through USB.
      HDMI cable is sold seperately
      Receiver Specifications
      DVB-S2
      Input Frequency:950~2150MHz
      Loop Out Frequency:950~2150MHz
      Input Level:-65~-25dBm
      Input Impedance:75¦¸
      LNB Power: Auto/14v/18v/OFF, Imax = 500mA
      Video decoder
      Video Compression MPEG-2 and MPEG-1 compatible, H.246
      Video Formats 4:3 / 16:9
      Letterbox for 4:3 TV-Device
      Audio decoder
      Audio Compression MPEG-1 & MPEG-2 Layer I and II, MP3
      Audio Mode Dual (main/sub), Stereo
      Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
      Output digital
      Output Level 0,5 Vss on 75 Ohm
      Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
      S/PDIF-Output
      Video parameter
      Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
      Teletext filter in conformity with ETS 300 472 Standard
      TV-Scart
      Output: FBAS, RGB, S-Video
      Serial Interface RS 232
      RS232 bidirectional
      Bit rate 115,2 kBit/s max.
      Plug Connector SUB-D-9
      Function: Update of Firmware
      Ethernet
      10/100 MBit compatible interface
      USB
      1 x USB 2.0 Host, PVR
      LNB power and polarization per tuner
      LNB Current 500mA max.
      short-circuit-protected
      LNB Voltage vertical < 14V no load, > 11,5V at 400mA
      LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
      Physical specification
      Ambient Temperature +15 °C...+35 °C
      Humidity < 80%
      Size (W x D x H): 300 mm x 220 mm x 56 mm (12in x 8.7in x 2in)
      Weight: 1,8 kg (4 lbs) without HDD
      Power
      AC auto input range:100-240VAC 50/60Hz
      Consumption (Standby): Max. 10W (<1 W)
      What is included in the box:
      SatHawk PVR800 Receiver
      IR Remote Control
      RCA Composite Audio Video cable
      CD (owners manual)
      [video=youtube;2mxGVZ6hf3s]http://www.youtube.com/watch?v=2mxGVZ6hf3s&feature=player_embedded[/video] [video=youtube;K0SE-anHI5w]http://www.youtube.com/watch?v=K0SE-anHI5w&feature=player_embedded[/video]
    • Digitalbox Imperial HD 2 Plus
      Features:
      •MPEG 2/4 digital & fully DVB-S 2 (SD/HD) compliant
      •Alphanumeric display (VF-display 12-figure)
      •Slot to the admission of 1 CI (Pay-TV)
      •4.000 channels TV and Radio programmable
      •USB-port for Photos, Music, Record and Replay from extern Media
      •Comfortable pre-programmed program list
      •Multi-language menu with 10 languages: D/GB/F/E/I /P /T /PL/NL/GR
      •8 different favourite group?s selection
      •8 programmable timers for USB and VCR / Sleep Timer
      •Teletext support and subtitle support (OSD)
      •EPG now/next for 14-days
      •Blind Search & Multi-Satellite Search
      •Software update over Satellite (OTA) and USB
      •Parental control for channels and menu
      •DiSEqC 1.0/1.1/1.2 & Unicabel
      •Picture formats: 4:3 LetterBox, PanScan/16:9, Automatic change-over 16:9/4:3
      •3 games (Tetris/Snake/Othello)
      •7 buttons on the front (Standby, CH +/-, VOL +/-, Menu, OK)
      •Low Power Consumption < 1 Watt in Standby
      Connections:
      •USB 2.0-Port (PVR-Ready)
      •HDMI digital output with upscale for the formats 480i/p, 576i/p, 720p and 1080i
      •YUV Componenten (Y/Pb/Pr) Video Cinch Output
      •1 Scart connections for TV
      •Optical and electrical digital output (S/PDIF)
      •2 x Cinch Audio (R/L)
      •1 x Cinch (Video Out)
      •Loop-through tuner to connect a second receiver
      •Power Switch (rear side)
      Accessories:
      •Remote control (incl. batteries)
      •Installation Guide (GB/G) Art.-Nr.: 77-517-00
      •Dimensions (W x H x D): 310 x 65 x 20 mm
      [video=youtube;Q700IvK_esA]http://www.youtube.com/watch?v=Q700IvK_esA[/video]
    • EYCOS E 95.15 Twin HD Receiver
      Of particular interest is the receiver for DXers he has 20000 memory locations, and there are 195 satellites manageable. He owns two highly sensitive Sharp tuner. In the blind scan transponders to be a symbol rate of 1000 g with no problems.
      This twin receiver is available through its Linux software for many applications. So from October Enigma can also be installed on this receiver in dual boot. Thus, all of Enigma Plugins are available.
      Through its intelligent blind scan in 20 MHz steps, he is super fast. This is especially Feedhunter very interesting. The quality of display is in dB and reacts very quickly. Thus, motor systems, which are controlled by DiSEqC 1.2 very best optimized to each satellite. 4:2:2 feeds are also on the network using the NFS server on the PC with a slight delay of <1 s with the smplayer-0.6.9 representable.
      Technical data:
      - 20,000 channels storable
      - 2 Sharp blind scan tuner
      - 195 satellites storable
      - 2 card reader built in (Conax)
      - 2 CI interface, 2 USB ports (1 front - 1 rear)
      - SATA-port internal, eSATA port on the back (it can only A SATA port can be used)
      - 14-digit VFD DOT display for station name display with additional display of picture resolution
      - Dolby Digital
      - Timer, etc.
      - NFS server and client installed
      - STi Linux operating system
      - Plug-in Tuner (twin satellite - Twin cable, etc.) - YouTube - Short Cast Radio - Internet browser - installed (for Web browser, keyboard / mouse is required) - Funk-Tastatur/Maus in preparation
      - Menu PlugIn for future extensions (even einspielbar via USB)
      - PIP (Picture in Picture)
      - JPEG and MP3 Player
      - xVID playable (movies must be converted only into xVID - free converter available)
      films from Eycos S8012HD and the 8215 series are playable - 1080p video output via HDMI - 1 Scart, YUV output, video and audio output , S / PDIF fiber output - power switch - Network connector - Remote control
      Size: 37 x 7 x 28 cm (width / height / depth - depth without connector)
      Current Consumption: Deep Standby <1W, Standby time with about 2.5 watts, operating with an integrated hard drive and twin LNB about 19 ​​watts.
    • TBS 6925 PCI-E DVB-S2
      TBS6925 PCI-E DVB-S2 Card is a professional satellite PC tuner card, a versatile PC tuner card. Besides supporting blind scan and 32APSK Demodulator, it also supports CCM, VCM, ACM mode, supports multiple Transport Stream receiving, supports Generic Stream capture, and supports up to 190 Mbit/s channel bit rate capture. TBS6925 is fully compatible with windows 7 Media Center and many other popular satellite applications, e.g. DVBDream, DVBViewer, DVBlogic, ProgDVB, Skynet, TSreader…
      Main Features:
      1. DVB-S2/S Transponders Receiving
      2. CCM, VCM and ACM mode support
      3 .Support Multiple Transport Stream Receiving
      4. Support Generic Stream capture
      5. Transponders blind scan
      6. Up to 190 Mbit/s channel bit rate capture
      7. Wide range symbol rates support, from 200Ksps to 45Msps
      8.High-speed Data download via Satellite
      9. Windows 7 Media Center compatible
      10.Supported by DVBDream, DVBViewer, DVBlogic, ProgDVB, Skynet, TSreader…
      Specifications:
      1.Receiving Frequency: 925~2175 MHz Tuning Range
      2.Input level: -69~ -23dBm
      3.DVB-S2/DVB-S DIRECTV 8PSK QPSK 16APSK 32APSK Demodulator
      4. 8PSK /QPSK/16APSK/32APSK mode
      5. Symbol Rates:
      DVB-S2 QPSK: 200Ksps~45 Msps
      DVB-S2 8PSK: 200Ksps~45 Msps
      6. Code Rates:
      DVB-S: 1/2, 2/3, 3/4, 5/6, 7/8
      DVB-S2 QPSK: 1/4,1/3,2/5,1/2,3/5,2/3,3/4,4/5,5/6,8/9,8/10
      DVB-S2 8PSK: 3/5,2/3,3/4,5/6,8/9,9/10
      16APSK: 2/3,3/4,4/5,5/6,8/9,9/10
      32APSK: 3/4,4/5,5/6,8/9,9/10
      7. Automatic Acquisition Range: ±10MHz
      8. DiSEqC 2.x compliant
      9. PCI Express interface
      10. Low profile size
      [video=youtube;m-ADjQfW9lg]http://www.youtube.com/watch?v=m-ADjQfW9lg[/video]
      [video=youtube;Y85WqeJ9uAI]http://www.youtube.com/watch?v=Y85WqeJ9uAI&feature=related[/video]
    • TBS 5925 USB DVB-S2
      TBS5925 is a Professional level digital satellite TV Tuner box with USB2.0 connection to PC. TBS5925 supports not only normal DVB-S2/DVB-S QPSK, 8PSK which is supported by normal satellite receivers, but also ACM, VCM, Multi Input Stream, 16APSK and 32APSK mode, which most satellite receiving devices can’t support. With use of dedicated TBS tools, those special streams can be captured. Both Windows BDA driver and Linux driver up to the latest kernel 3.X are provided.
      Description:
      TBS 5925 USB DVB-S2 Professional TV Tuner external box, built with the highest industry standard, with its rock reliability is the device that any personal enthusiasts or engineers in digital satellite TV industry dream to have. The applying of an unique DVB-S2 demodulator chipset makes it possible to receive special streams broadcasted with ACM, VCM, Multi Input Stream, 16APSK, 32APSK. The built in hardware blind scan feature allows scanning of unknown satellite transponder with symbol rate as low as 200ksps, while most satellite receiving device can receive no less than 1Msps symbol rate. Such blind scan feature can be achieved by dedicated TBS tool or Crazyscan tool.
      TBS 5925 is the USB version of its’ equivalent device: TBS6925 PCIe DVB-S2 Professional TV Tuner card.
      Main Features:
      CCM, VCM,ACM and Multi Input Stream Support
      Wide range symbol rates support from 200Ksps to 45Msps
      Unicable/One Cable compatible
      Blindscan
      High reliability
      Applications:
      Satellite feed hunting
      Satellite Data download
      Lock of special transponders
      Specifications:
      Receiving Frequency: 950~2150 MHz Tuning Range
      Input level: -69~-23dBm
      DVB-S2/DVB-S 8PSK QPSK 16APSK 32APSK Demodulator
      Symbol Rate:
      DVB-S QPSK 0.2~45Msps
      DVB-S2 QPSK/8PSK 0.2~45Msps
      Carrier Capture Range: ±10MHz
      DVB-S2 8PSK Puncture codes: 3/5,2/3,3/4,5/6,8/9,9/10
      DVB-S2 QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10
      DVB-S2 16PSK Puncture codes: 2/3,3/4,4/5,5/6,8/9,9/10
      DVB-S2 32PSK Puncture codes: 3/4,4/5,5/6,8/9,9/10
      Support Data Burst & Tone Burst
      Support DiSEqC2.X and Motor
      TV Box Size: 78x64x26mm (Length x Width x Height)
      TV Box Weight: 137 Gram
      Package Gift Box Size: 200x162x55mm (Length x Width x Height)
      Package Gift Box Weight: 647 Gram
      System Requirements:
      Windows 2000/XP/Vista/7 or Linux
      DirectX9.0 or later Version
      Available USB2.0 Port
      Satellite Dish and LNB
      For DVB-S
      1GHz CPU or above
      256MB RAM or above
      Graphic Card with at least 16MB RAM
      For DVB-S2 HDTV
      Dualcore CPU
      1GB RAM or Above
      Graphic Card with at Least 64MB RAM
      Package Content:
      1 x TBS5925 USB DVB-S2 TV Tuner Box
      1 x remote control
      1 x Power Adapter
      1 x USB Cable
      1 x Software CD
    • TBS 6991 PCI-E DVB-S2 Dual Tuner Dual CI
      TBS 6991 is a Twin Tuner digital satellite TV card with dual common interface for watching and recording digital satellite PayTV on PC. You may use one tuner to watch one TV channel while using another tuner to record/watch another channel from another transponder/ satellite simultaneously. It can be either used for watching Free to Air TV or satellite Pay TV since it’s integrated with two CI slots(By inserting the correct CAM and subscription smartcard into the CI slot, encrypted pay tv will be available). This device is provided with both Windows BDA driver and Linux driver up to the latest kernel. The unique TBS MCE tool makes it possible to read CAM/Smartcard on Windows7 Media Center, thus your satellite subscription TV can be watched/recorded on Windows7 Media Center. On Linux platform, you can also watch PayTV by using relative software on Linux. TBS6991 is compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
      Description:
      TBS 6991 PCI-E DVB-S2 Dual Tuner Dual CI card is the high end satellite TV tuner built with dual Common Interface support, which allows insertion of two CAMs and two smartcards for recording two different paytv channels at the same time. It’s good choice especially for IPTV server streaming PayTV contents. With use of appropriate software, e.g. MediaPortal and its’ plugins, you may stream satellite TV contents to your iPhone, iPad or iPod. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for hunting unknown satellite feeds.
      Main Features:
      Watch Satellite TV & listen to Radio on PC
      DVB-S2/DVB-S SD or HD TV Receiving
      Real Time and Scheduled Program Recording(PVR)
      Time Shifting to Pause Live TV
      Dual Tuner for Recording Two Different Channels/Transponders
      Dual Common Interface Support
      Blindscan
      High reliability
      Applications:
      HTPC
      IPTV Streaming Server
      Specifications:
      2x DVB-S2/DVB-S 8PSK QPSK Demodulator
      Symbol Rate:
      DVB-S QPSK 1~45Msps
      DVB-S2 QPSK/8PSK 1~45Msps
      QPSK Puncture codes: 1/2,3/5,2/3,3/4,4/5,5/6,8/9,9/10.
      Dual CI Slot
      Standard Profile TV Card Size: 145x92mm (Length x Height)
      TV Card Weight: 133 Gram
      Package Gift Box Size: 200x140x50mm (Length x Width x Height)
      Package Gift Box Weight: 352 Gram
      Available PCI Express x1,x4, x8 or x16 slot
      For DVB-S:
      1GHz CPU or above
      256MB RAM or above
      For DVB-S2 HDTV:
      Dualcore CPU
      1GB RAM or Above
      ]Package Content:
      1 x TBS6991 PCI-E DVB-S2 Dual Tuner Dual CI Card
      1 x remote control
      1 x IR receiver
      1 x Software CD
    • TBS 6928 PCI-E DVB-S2 TV Tuner CI
      TBS 6928 is a PCI Express interface digital satellite TV Tuner card for watching and recording digital satellite TV on PC. With integrated CI slot, it can be used for watching Free to Air TV and Pay TV(if correct CAM and subscription smartcard are equipped). Both Windows BDA driver and Linux driver up to the latest kernel are provided. The unique TBS MCE tool makes it possible to read CAM/Smartcard on Windows7 Media Center, thus your satellite subscription TV can be watched/recorded on Windows7 Media Center. On Linux platform, you can also watch paytv by using correct software. TBS6928 is compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC, MythTV,VDR and many other popular softwares.
      Description:
      TBS 6928 PCI-E DVB-S2 TV Tuner CI card is the advanced satellite TV tuner built with Common Interface support, which allows insertion of CAM and smartcard for paytv. It uses advanced DVB-S2 RF and demodulator chipset and it’s built with the highest quality components such as tantalum capacitors. It’s good choice especially for IPTV server streaming paytv contents. With use of appropriate software, e.g. MediaPortal and its’ plugins, you may stream satellite TV contents to your IPhone, IPAD or IPOD. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for hunting unknown satellite feeds.
      Main Features:
      Broadband Internet via Satellite *
      High-speed Data download via Satellite *
      Blindscan
      High reliability
      Applications:
      HTPC
      Specifications:
      DVB-S2/DVB-S DIRECTV 8PSK QPSK Demodulator
      Symbol Rate:
      DVB-S QPSK 1~45Msps
      Single CI Slot
      Standard Profile TV Card Size: 140x83mm (Length x Height)
      TV Card Weight: 90 Gram
      Package Gift Box Weight: 285 Gram
      For DVB-S:
      1GHz CPU or above
      256MB RAM or above
      For DVB-S2 HDTV:
      Dualcore CPU
      1GB RAM or Above
      Package Content:
      1 x TBS6928 PCI-E DVB-S2 TV Tuner Card
      1 x remote control
      1 x IR receiver
      1 x Software CD
    • TBS 5980 USB DVB-S2 TV Box CI
      TBS 5980 is a digital satellite TV Tuner external box with USB connection for watching and recording digital satellite TV on PC. With integrated CI slot, it can be used for watching Free to Air TV and PayTV(By inserting the correct CAM and subscription smartcard into the CI slot, encrypted pay TV will be available). Both Windows BDA driver and Linux driver up to the latest kernel are provided. The unique TBS MCE tool makes it possible to read CAM/Smartcard on Windows7 Media Center, thus your satellite subscription TV can be watched/recorded on Windows7 Media Center. On Linux platform, you can also watch paytv by using correct software. TBS5980 is compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
      Description:
      TBS 5980 USB DVB-S2 TV Box CI is the high end satellite TV tuner box built with Common Interface support, which allows insertion of CAM and smartcard for pay TV. You may also use it to watch/record Free to Air satellite TV on PC if you don’t want to use the CAM/Smartcard. With use of appropriate software, e.g. MediaPortal and its’ plugins, you may stream satellite TV contents to your iPhone, iPad or iPod. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for hunting unknown satellite feeds.
      Main Features:
      Common Interface and CAM Support
      Blindscan
      High reliability
      Specifications:
      Symbol Rate:
      DVB-S QPSK 1~45Msps
      Single CI Slot
      TV Box Size: 103x88x22mm (Length x Width x Height)
      TV Box Weight: 200 Gram
      Package Gift Box Size: 210x175x55mm (Length x Width x Height)
      Package Gift Box Weight: 726 Gram
      For DVB-S:
      1GHz CPU or above
      256MB RAM or above
      For DVB-S2 HDTV:
      Dualcore CPU
      1GB RAM or Above
      Package Content:
      1 x TBS5980 USB DVB-S2 TV CI Box
      1 x remote control
      1 x Power Adapter
      1 x USB Cable
      1 x Software CD
    • TBS 8922 PCI DVB-S2 TV
      TBS 8922 is a PCI interface digital satellite TV Tuner card for watching and recording Free to Air satellite TV on PC. It supports both DVB-S2 and DVB-S programs receiving. It’s ready with Windows BDA driver and Linux driver up to the latest kernel 3.X
      Tested on Ubuntu,Fedora,Opensuse and other Linux distributions). It’s compatible with Windows7 Media Center, MediaPortal, DVBlink, DVBDream, DVBViewer, ProgDVB, Skynet, TSreader, XBMC,MythTV,VDR and many other popular softwares.
      Description:
      TBS 8922 PCI DVB-S2 TV Tuner card is the latest release of TBS PCI series satellite TV cards. It’s built with the highest quality components such as tantalum capacitors. You can use it to watch UK Freesat or any other satellite TV programs in your region. With its’ low profile size, it’s ideal for building up HTPC or IPTV server. The built in hardware blindscan capability allows you to scan satellite programs without knowing exact transponder details, this is especially useful for satellite feed hunting.
      Main Features:
      Blindscan
      High reliability
      *Depends on service provider.
      Applications:
      HTPC
      Specifications:
      Symbol Rate:
      DVB-S QPSK 1~45Msps
      Low profile size: 143x56mm (Length x Height)
      Available PCI slot
      For DVB-S:
      1GHz CPU or above
      256MB RAM or above
      For DVB-S2 HDTV:
      Dualcore CPU
      1GB RAM or Above
      Package Content:
      1 x TBS8922 PCI-E DVB-S2 TV Tuner Card
      1 x remote control
      1 x IR receiver
      1 x Software CD
